Dashticz v3.7.4 beta
Lokonli
Dashticz v3.7.4 has just been released.
This release mainly contains some dial related improvements:
* Text devices are supported.
* The formatting of values changed. If needed add 'decimals: 0' to your block definition to remove the digits behind the decimal point.
For a description of all changes check the release notes:
https://dashticz.readthedocs.io/en/beta ... -20-2-2021
- madpatrick
- Domoticz version: 2026.1
Re: Dashticz v3.7.4 beta
Hi Lokonli,
I tried the 'decimals: 0' parameter with a dimmer, but this still give a decimal in the dial
blocks['dimmer_hal'] = {idx: 154, type: 'dial', color: '#ffff00', width: 2, last_update: false, title:' ', shownumbers: true, showring: true, showunit: true,decimals: 0}-= HP server GEN11 =- ZwaveJS-=- Domoticz v2026.2 -=- Dashticz =-
Foxhill67
- Domoticz version: 2020.2
Hi Lokonli,
since update to V3.7.4 beta (from V3.7.2 beta), my combined calendars block only shows text 'Button'.
Any suggestions how to fix this?
calendars.combined = {width: 10, maxitems:15, calFormat:1, dateFormat: "dd DD MMM", timeFormat: "HH.mm", calendars: [{ color:'white',calendar:calendars.x},{ color:'aqua',calendar:calendars.y},{ color:'lightcoral',calendar:calendars.z},{ color:'yellow',calendar:calendars.w},{ color:'lightgreen',calendar:calendars.holiday}]}
- HansieNL
The parameter calFormat is absolute since V3.7.3. You have to use one of the layout formats.Foxhill67 wrote: Saturday 20 February 2021 20:37 Hi Lokonli,
since update to V3.7.4 beta (from V3.7.2 beta), my combined calendars block only shows text 'Button'.Any suggestions how to fix this?Code: Select all
See https://dashticz.readthedocs.io/en/bet ... endar.html
Blah blah blah
Krenstik
I miss a usage el. dial. but all other dial ( mostly with temp, CO2) working
Also any idea how to set setpoint, for example here on the value 1500. ...
Or for ppm dial:
Thank you.
blocks['spotreba'] = { type: 'dial', title: 'Odběr', width: 6, min: 100, max: 3500, showunit: false, shownumbers: true, last_update:false, showring: true,
values : [ { value: 'Data', idx: 66 },
{ value:'Data', idx: 63, },
{ value:'CounterToday', idx: 65, }, ]}
Or for ppm dial:
ocks['oco'] = { type: 'dial', width: 2, title: 'Obyvak', showunit: true, switch: true, shownumbers: true, showring: true, last_update: true, setpoint: 1300, min: 450, max: 2700,
values : [ { value: 'Data', idx: 47 },
{ value: 'Data', idx: 48 , icon: 'fas fa-volume-up', unit:' dB', },
{ value: 'Data', idx: 22 , unit:' LUX', }, ]}-
Foxhill67
Thanks, must have missed this while reading the release notes. Have updated my config.js and everything works like a charm again!HansieNL wrote: Saturday 20 February 2021 22:21The parameter calFormat is absolute since V3.7.3. You have to use one of the layout formats.Foxhill67 wrote: Saturday 20 February 2021 20:37 Hi Lokonli,
Lokonli
Should be fixed in latest beta. Can you test?madpatrick wrote: Saturday 20 February 2021 19:31 Hi Lokonli,
- madpatrick
It is working now.
Lokonli
I don't understand your remark. Can you clarify?
Can you add the Domoticz json output of the device you want to show:
http://domoticzip:port/json.htm?type=devices&rid=123
Can you also indicate which field you would like to use for the dial?
Krenstik
is a power concuption. In last beta was fully working: but now I have just name:
And here a json:
and dial:
And here a json:
ActTime: 1613922038,
AstrTwilightEnd: "19:10",
AstrTwilightStart: "05:05",
CivTwilightEnd: "17:56",
CivTwilightStart: "06:19",
DayLength: "10:33",
NautTwilightEnd: "18:33",
NautTwilightStart: "05:42",
ServerTime: "2021-02-21 16:40:38",
SunAtSouth: "12:07",
Sunrise: "06:51",
Sunset: "17:24",
app_version: "2020.2 (build 12738)",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "521.6 Watt",
Description: "",
Favorite: 1,
HardwareDisabled: false,
HardwareID: 6,
HardwareName: "Z-wave",
HardwareType: "OpenZWave USB",
HardwareTypeVal: 21,
HaveTimeout: false,
LastUpdate: "2021-02-21 16:40:35",
Name: "Spotřeba komplet",
Notifications: "false",
PlanID: "9",
PlanIDs: [
9
Protected: false,
ShowNotifications: true,
SignalLevel: "-",
SubType: "Electric",
Timers: "false",
Type: "Usage",
TypeImg: "current",
Unit: 2,
Used: 1,
XOffset: "767",
YOffset: "148",
idx: "66"
status: "OK",
title: "Devices"
}Code: Select all
{ value:'CounterToday', idx: 65, },]}-
Lokonli
Could you post the Domoticz json output for device 63 and 65 as well?Krenstik wrote: Sunday 21 February 2021 16:42 Hi,
is a power concuption. In last beta was fully working:Snímek obrazovky 2021-02-21 163912.jpg
And here a json:and dial:Code: Select all
{ ActTime: 1613922038, AstrTwilightEnd: "19:10", AstrTwilightStart: "05:05", CivTwilightEnd: "17:56", CivTwilightStart: "06:19", DayLength: "10:33", NautTwilightEnd: "18:33", NautTwilightStart: "05:42", ServerTime: "2021-02-21 16:40:38", SunAtSouth: "12:07", Sunrise: "06:51", Sunset: "17:24", app_version: "2020.2 (build 12738)", result: [ { AddjMulti: 1, AddjMulti2: 1, AddjValue: 0, AddjValue2: 0, BatteryLevel: 255, CustomImage: 0, Data: "521.6 Watt", Description: "", Favorite: 1, HardwareDisabled: false, HardwareID: 6, HardwareName: "Z-wave", HardwareType: "OpenZWave USB", HardwareTypeVal: 21, HaveTimeout: false, ID: "0000201", LastUpdate: "2021-02-21 16:40:35", Name: "Spotřeba komplet", Notifications: "false", PlanID: "9", PlanIDs: [ 9 ], Protected: false, ShowNotifications: true, SignalLevel: "-", SubType: "Electric", Timers: "false", Type: "Usage", TypeImg: "current", Unit: 2, Used: 1, XOffset: "767", YOffset: "148", idx: "66" } ], status: "OK", title: "Devices" }Code: Select all
blocks['spotreba'] = { type: 'dial', title: 'Odběr', width: 6, min: 100, max: 3500, showunit: false, shownumbers: true, last_update:false, showring: true, values : [ { value: 'Data', idx: 66 }, { value:'Data', idx: 63, }, { value:'CounterToday', idx: 65, },]}
Krenstik
Here 63:
and here 65:
ActTime: 1613931558,
DayLength: "10:33",
ServerTime: "2021-02-21 19:19:18",
Sunrise: "06:51",
Sunset: "17:24",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "236.47 V",
Description: "",
Favorite: 0,
HardwareID: 6,
HaveTimeout: false,
LastUpdate: "2021-02-21 19:15:59",
PlanID: "0",
PlanIDs: [
0
Protected: false,
SignalLevel: "-",
SubType: "Voltage",
Timers: "false",
Type: "General",
TypeImg: "current",
Unit: 1,
Used: 1,
Voltage: 236.47,
XOffset: "0",
YOffset: "0",
idx: "63"
status: "OK",
title: "Devices"Code: Select all
ActTime: 1613931674,
DayLength: "10:33",
ServerTime: "2021-02-21 19:21:14",
Sunrise: "06:51",
Sunset: "17:24",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CounterToday: "8.000 kWh",
CustomImage: 0,
Data: "1311.800 kWh",
Description: "",
EnergyMeterMode: "",
Favorite: 0,
HardwareID: 6,
HaveTimeout: false,
LastUpdate: "2021-02-21 19:21:05",
Name: "Denní spotřeba",
PlanID: "9",
PlanIDs: [
9
Protected: false,
SignalLevel: "-",
SubType: "kWh",
SwitchTypeVal: 0,
Timers: "false",
Type: "General",
TypeImg: "current",
Unit: 1,
Usage: "506.5 Watt",
Used: 1,
XOffset: "766",
YOffset: "87",
idx: "65"
status: "OK",
title: "Devices"-
Lokonli
I can reproduce your issue if you have defined the following in CONFIG.js:Krenstik wrote: Sunday 21 February 2021 16:42 Hi,
config['use_favorites'] = 1
So, change this setting to:
config['use_favorites'] = 0
Can you test with latest beta?
Krenstik
config['use_favorites'] = 0But select those two Domoticz as a favourite help.
Thank you.
For sure, the latest beta, I´ve updated now.
And regarding setpoint for ppm, or this power consumption?
Lokonli
Should work in latest beta. Can you test?Krenstik wrote: Sunday 21 February 2021 22:56 And regarding setpoint for ppm, or this power consumption?
Krenstik
Working well.
NIce
Thank you.
NIce
pvklink
- Domoticz version: latest b
I have the latest beta running without any problems.
I have several dials, and want to get my p1 dial ok.
Its a dial for a energie p1 device with two meters, day and night
I like to show the two values/data 9835192 and 9763855 instead of -3.99 it is showing now..
Can somebody give me a hint how to acomplish this?
Jablotron connection, Ikea
Lokonli
Add the following to your block:pvklink wrote: Tuesday 23 February 2021 20:30 I have the latest beta running without any problems.
values:['Counter', 'CounterDeliv']
https://dashticz.readthedocs.io/en/beta ... neric-dial
pvklink
thanks, and i am gonne read the beta doc
pvklink
OK,
This is the total of the two vaues together.
How do i show both seperate?
When i want to check my bill
day and night counters
