Python Plugin: Shelly MQTT
josemi
Re: Python Plugin: Shelly MQTT
Before opening an issue in github repo, could you watch in your domoticz if your Shelly 2.5 energy devices are updating (Last Seen column)?
My 8 Shelly 2.5 have quit of updating since september 2019.
My version: 0.4.6
Thank you
My version: 0.4.6
Thank you
MikeyMan
General question; is there a minimum of power consumption to be measured?
Maeasured my Modem this night; using 12 watts; adding up to (naturally) 12Wh.
Now switched to measuring my router, using 5 watts. However, consumption stays at 0?
pro2call
- Domoticz version: 2020.2
Yes this is indeed working all OK.niekbruggeman wrote: Sunday 05 July 2020 13:53 I can confirm that the new shelly dimmer 2 works correct with Domoticz.
I use the native firmware of the Shelly, and the Shelly MQTT plugin for Domoticz 2020.2.
fransiefrans
- Domoticz version: stable
I have an issue with the hardware plugin.
I'm running domoticz stable.
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: None
As you can see Python Version: None.
I tried:
Sadly that didn't fix the python issue.
Is there something else I can do to get Shelly Mqtt hardware visible in the domoticz hardware list?
Version: 2020.2
I tried:
sudo apt-get install libpython3.5-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libpython3.5-dev is already the newest version (3.5.4-4).
The following package was automatically installed and is no longer required:
rpi-eeprom-images
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
alanf wrote: Sunday 08 December 2019 18:47 When I was trying to get the Shelly MQTT working I came across this: https://www.domoticz.com/forum/viewtopi ... 2&start=20
What worked for me on Pi : Raspbian GNU/Linux 9 (stretch): the build already includes Python 3.5.3 (reported by python3 -V), but it needs libpython3.5-dev, my cut and paste notes from command line at the time have:
Then restart Domoticz and check the log, it should include lines:Code: Select all
cd domoticz/plugins git clone https://github.com/enesbcs/Shelly_MQTT cd Shelly_MQTT/ chmod +x plugin.py chmod +x mqtt.py sudo apt-get install libpython3.5-dev sudo systemctl restart domoticz.service
And Domoticz "About" reports:Code: Select all
[timestamp]Status: PluginSystem: Started, Python version '3.5.3'. ... and a couple of seconds later [timestamp]Status: Python EventSystem: Initalizing event module. [timestamp]Status: EventSystem: Started [timestamp]Status: EventSystem: Queue thread started...
Version: 4.10717 Build Hash: b38b49e5 Compile Date: 2019-05-09 12:04:08 dzVents Version: 2.4.19 Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
lwolf
Your system may contain several python versions: 3.5, 3.6, 3.7 or 3.8fransiefrans wrote: Wednesday 26 August 2020 6:29 And Domoticz "About" reports:
Delete all except one, or try to select the default.
python --version
update-alternatives --list python-
Atis
Good plugin
snellejellep
if you mean the i3, yes it is.Gerwin wrote: Thursday 30 July 2020 20:01 Hello,
The Shelly button is that one impemented ???
does someone knows that
Gerwin
just the button is a case for a shelly 1 which obviously is supported
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
fransiefrans
Thank you for the hint.lwolf wrote: Tuesday 01 September 2020 17:06Your system may contain several python versions: 3.5, 3.6, 3.7 or 3.8fransiefrans wrote: Wednesday 26 August 2020 6:29 And Domoticz "About" reports:
python --version update-alternatives --list python
I removed Phyton 2.7
sudo apt-get remove python2.7 --purgePython Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
Shelly MQTT was visible in Hardware.
darrepac
I am quite happy with this plugin: it works well.
Yet, when this plugin has been released the sole solution to get info from Shelly was MQTT but it means to deactivate cloud.
Now, Shelly has introduced other mean to access Shelly data using CoAP and REST and keep cloud connection.
Do you plan to support it?
If not, probably I will give a try to this other plugin supporting it: viewtopic.php?f=65&t=32616
thx
thx
lwolf
The one and biggest benefit of the Shelly that i can get rid of the Cloud without changing its firmware.darrepac wrote: Sunday 20 September 2020 18:43 Yet, when this plugin has been released the sole solution to get info from Shelly was MQTT but it means to deactivate cloud.
So no, i have no plans to support other communication forms, as MQTT is the best i know.
darrepac
I have some problem with energy: sometimes it goes to 0 while there are power
Any idea how I can debug this? I saw nothing in the log:
2020-10-09 18:04:18.878 (ShellyMQTT) 3a 30 7d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. :0}
2020-10-09 18:04:18.879 (ShellyMQTT) MQTT message: shellies/shelly1-B9CB90/relay/0 off
2020-10-09 18:04:18.879 (ShellyMQTT) >>> Looking for device: shelly1-B9CB90-0
2020-10-09 18:04:18.880 (ShellyMQTT) MQTT message: shellies/shelly1-B9CB90/input/0 0
2020-10-09 18:04:18.880 (ShellyMQTT) >>> Looking for device: shelly1-B9CB90-0-input
2020-10-09 18:04:18.880 (ShellyMQTT) MQTT message: shellies/shelly1-B9CB90/input_event/0 {'event': '', 'event_cnt': 0}
2020-10-09 18:04:18.880 (ShellyMQTT) >>> Looking for device: shelly1-B9CB90-input_event0
2020-10-09 18:04:19.282 (ShellyMQTT) Heartbeating...
2020-10-09 18:04:19.282 (ShellyMQTT) MqttClient::ping
2020-10-09 18:04:19.282 (ShellyMQTT) Sending 2 bytes of data
2020-10-09 18:04:19.282 (ShellyMQTT) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2020-10-09 18:04:19.333 (ShellyMQTT) Received 2 bytes of data
2020-10-09 18:04:19.333 (ShellyMQTT) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2020-10-09 18:04:29.262 (ShellyMQTT) Heartbeating...
2020-10-09 18:04:29.262 (ShellyMQTT) MqttClient::ping
2020-10-09 18:04:29.262 (ShellyMQTT) Sending 2 bytes of data
2020-10-09 18:04:29.262 (ShellyMQTT) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2020-10-09 18:04:29.314 (ShellyMQTT) Received 2 bytes of data
2020-10-09 18:04:29.314 (ShellyMQTT) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2020-10-09 18:04:34.326 (ShellyMQTT) Received 51 bytes of data
2020-10-09 18:04:34.326 (ShellyMQTT) 30 31 00 2a 73 68 65 6c 6c 69 65 73 2f 73 68 65 6c 6c 79 70 01.*shellies/shellyp
2020-10-09 18:04:34.327 (ShellyMQTT) 6c 75 67 2d 73 2d 37 41 33 32 37 39 2f 72 65 6c 61 79 2f 30 lug-s-7A3279/relay/0
2020-10-09 18:04:34.327 (ShellyMQTT) 2f 70 6f 77 65 72 34 30 2e 34 36 .. .. .. .. .. .. .. .. .. /power40.46
2020-10-09 18:04:34.327 (ShellyMQTT) Received 53 bytes of data
2020-10-09 18:04:34.327 (ShellyMQTT) 30 33 00 2b 73 68 65 6c 6c 69 65 73 2f 73 68 65 6c 6c 79 70 03.+shellies/shellyp
2020-10-09 18:04:34.327 (ShellyMQTT) 2f 65 6e 65 72 67 79 31 30 38 37 38 35 .. .. .. .. .. .. .. /energy108785
2020-10-09 18:04:34.327 (ShellyMQTT) Received 42 bytes of data
2020-10-09 18:04:34.327 (ShellyMQTT) 30 28 00 24 73 68 65 6c 6c 69 65 73 2f 73 68 65 6c 6c 79 70 0(.$shellies/shellyp
2020-10-09 18:04:34.328 (ShellyMQTT) 6c 75 67 2d 73 2d 37 41 33 32 37 39 2f 72 65 6c 61 79 2f 30 lug-s-7A3279/relay/0
2020-10-09 18:04:34.328 (ShellyMQTT) 6f 6e .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. on
2020-10-09 18:04:34.328 (ShellyMQTT) Received 49 bytes of data
2020-10-09 18:04:34.328 (ShellyMQTT) 30 2f 00 28 73 68 65 6c 6c 69 65 73 2f 73 68 65 6c 6c 79 70 0/.(shellies/shellyp
2020-10-09 18:04:34.328 (ShellyMQTT) 6c 75 67 2d 73 2d 37 41 33 32 37 39 2f 74 65 6d 70 65 72 61 lug-s-7A3279/tempera
2020-10-09 18:04:34.328 (ShellyMQTT) 74 75 72 65 32 39 2e 38 31 .. .. .. .. .. .. .. .. .. .. .. ture29.81
2020-10-09 18:04:34.328 (ShellyMQTT) Received 51 bytes of data
2020-10-09 18:04:34.328 (ShellyMQTT) 30 31 00 2a 73 68 65 6c 6c 69 65 73 2f 73 68 65 6c 6c 79 70 01.*shellies/shellyp
2020-10-09 18:04:34.329 (ShellyMQTT) 74 75 72 65 5f 66 38 35 2e 36 35 .. .. .. .. .. .. .. .. .. ture_f85.65
2020-10-09 18:04:34.329 (ShellyMQTT) Received 49 bytes of data
2020-10-09 18:04:34.329 (ShellyMQTT) 30 2f 00 2c 73 68 65 6c 6c 69 65 73 2f 73 68 65 6c 6c 79 70 0/.,shellies/shellyp
2020-10-09 18:04:34.329 (ShellyMQTT) 6c 75 67 2d 73 2d 37 41 33 32 37 39 2f 6f 76 65 72 74 65 6d lug-s-7A3279/overtem
2020-10-09 18:04:34.329 (ShellyMQTT) 70 65 72 61 74 75 72 65 30 .. .. .. .. .. .. .. .. .. .. .. perature0
2020-10-09 18:04:34.330 (ShellyMQTT) MQTT message: shellies/shellyplug-s-7A3279/relay/0/power 40.46
2020-10-09 18:04:34.331 (ShellyMQTT) >>> Looking for device: shellyplug-s-7A3279-0-energy
2020-10-09 18:04:34.331 (Shelly Plug S) Updating device from 0:'41.57;1849.345' to have values 0:'40.46;1849.345'.
2020-10-09 18:04:34.362 (ShellyMQTT) MQTT message: shellies/shellyplug-s-7A3279/relay/0/energy 108785
2020-10-09 18:04:34.362 (ShellyMQTT) >>> Looking for device: shellyplug-s-7A3279-0-energy
2020-10-09 18:04:34.363 (Shelly Plug S) Updating device from 0:'40.46;1849.345' to have values 0:'40.46;1849.345'.
2020-10-09 18:04:34.394 (ShellyMQTT) MQTT message: shellies/shellyplug-s-7A3279/relay/0 on
2020-10-09 18:04:34.394 (ShellyMQTT) >>> Looking for device: shellyplug-s-7A3279-0
2020-10-09 18:04:34.395 (ShellyMQTT) MQTT message: shellies/shellyplug-s-7A3279/temperature 29.81
2020-10-09 18:04:34.395 (ShellyMQTT) >>> Looking for device: shellyplug-s-7A3279-temp
2020-10-09 18:04:34.395 (Plug S) Updating device from 0:'29.81' to have values 0:'29.81'.
2020-10-09 18:04:34.412 (ShellyMQTT) MQTT message: shellies/shellyplug-s-7A3279/temperature_f 85.65
2020-10-09 18:04:34.412 (ShellyMQTT) MQTT message: shellies/shellyplug-s-7A3279/overtemperature 0
2020-10-09 18:05:29.315 (ShellyMQTT) Heartbeating...
2020-10-09 18:05:29.315 (ShellyMQTT) MqttClient::ping
2020-10-09 18:05:29.316 (ShellyMQTT) Sending 2 bytes of data
2020-10-09 18:05:29.316 (ShellyMQTT) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2020-10-09 18:05:29.366 (ShellyMQTT) Received 2 bytes of data
2020-10-09 18:05:29.366 (ShellyMQTT) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2020-10-09 18:05:29.366 (ShellyMQTT) Disconnect directive received for '127.0.0.1:1883'.
2020-10-09 18:05:29.366 (ShellyMQTT) Handling TCP disconnect, socket (127.0.0.1:1883) is connected
2020-10-09 18:05:29.367 (ShellyMQTT) Queued asynchronous read aborted (127.0.0.1:1883), [125] Operation canceled.
2020-10-09 18:05:29.417 (ShellyMQTT) Disconnect event received for '127.0.0.1:1883'.
2020-10-09 18:05:29.418 (ShellyMQTT) MqttClient::onDisonnect
2020-10-09 18:05:29.418 (ShellyMQTT) MqttClient::close
2020-10-09 18:05:29.418 (ShellyMQTT) onMQTTDisconnected
2020-10-09 18:05:29.418 (ShellyMQTT) Deallocating connection object '127.0.0.1' (127.0.0.1:1883).
2020-10-09 18:05:29.418 (ShellyMQTT) onStop called-
grenouilles
Bonjour,
Je viens d'acheter un module Shelly EM et un Shelly HT pour les intégrer dans Domoticz en passant par MQTT.
Pour ce faire, j'ai installé le plug-in Shelly-MQTT.
Le Shelly HT ne remonte pas dans Domoticz et pour le EM je n'ai uniquement la valeur "Voltage".
Je vous remercie pour votre aide.
grenouilles
I have two PI 3B with Domoticz, one with a ShellyEM.
I would like to transfert the Shelly data between PI.
I have MQTT + Node-Red to the 2 PI.
The first PI send Shelly data over MQTT to the second in "Domoticz/in" topic.
The second do not create module automaticly (as if the shelly send data directly to the second PI)
Thx for your help,
Thx for your help,
darrepac
I just got a Shelly EM
In Shelly app, I see the Power Factor, isn't a value you have access through MQTT? (I do not see it populated...)
lwolf
Sorry i do not understand what do you want to achieve. Shellies do not use Domoticz/in topic, neither this plugin.grenouilles wrote: Thursday 19 November 2020 19:42 Hi,
Thx for your help,
lwolf
Power factor is supported in this plugin since Jul 23 2020. In case you upgraded the plugin, did not use MQTT prefix and enabled power reading in plugin setting at hardware page...darrepac wrote: Monday 30 November 2020 18:26 I just got a Shelly EM
darrepac
I missed the upgrade part but now I did it (only downloaded the new plugin.py as recommended) and still got nothing.
Except stop/start domoticz during the plugin update, do I have to do something?
I read well power, energy, voltage but do not see power factor
lwolf
Could you check incoming MQTT messages from EM?darrepac wrote: Friday 01 January 2021 23:21 I missed the upgrade part but now I did it (only downloaded the new plugin.py as recommended) and still got nothing.
It should be something like that: (this example is from EM3 API)
shellies/shellyem3-<deviceid>/emeter/<i>/pf
If your device did not send such an MQTT message, than power factor will never appear on Domoticz side, for sure.
darrepac
Here is what Shelly EM deliver (using mosquitto_sub):
So seems, it has to be computed as the reactive power is availableshellies/shellyem-C7F472/emeter/0/energy 564
shellies/shellyem-C7F472/emeter/0/returned_energy 0
shellies/shellyem-C7F472/emeter/1/energy 8
shellies/shellyem-C7F472/emeter/1/returned_energy 0
shellies/shellyem-C7F472/emeter/0/power 510.87
shellies/shellyem-C7F472/emeter/0/reactive_power -163.25
shellies/shellyem-C7F472/emeter/0/voltage 241.89
shellies/shellyem-C7F472/emeter/0/total 842430.4
shellies/shellyem-C7F472/emeter/0/total_returned 1887.5
shellies/shellyem-C7F472/emeter/1/power 8.54
shellies/shellyem-C7F472/emeter/1/reactive_power 7.32
shellies/shellyem-C7F472/emeter/1/voltage 241.89
shellies/shellyem-C7F472/emeter/1/total 439115.3
shellies/shellyem-C7F472/emeter/1/total_returned 0.0
darrepac
I have a problem with Shelly duo RGB.
I can get it into domoticz but then if I want to turn it on, it doesn't work. If I turn it on thanks to shelly localwebserver, the status is updated in Domoticz, but then I cannot turn it off in domoticz.
If the light is on, I can change the color in domoticz.
So color changing works but not on/off... I guess I miss something. EDIt: going back 1 hour later without touching anything, I succesfully turned on one light... but then I was not able to turn it off. It is like if there was traffic jam in the commands...
EDIT2: I cannot find a reason that sometimes it works, sometimes not
