Send email notifications when someone ring at the door
florfilla19
Domoticz version: 4.10717
Post by florfilla19 »
Hello Team,
I'm requesting your help regarding a Ziglint Doorbell which I used with a homemade Rflink.
Actually the doorbell is detected like a Mertik_GV60 device.
Email sending is allready configured and works well
Good news, I have a new line created under the logs when someone is pressing the button.
Can you help me to send an email notification when this event happen ?
Link to the used Doorbell: https://www.amazon.co.uk/ZIGLINT-Waterp ... B07JGNXGL6
Logs from domoticz:
2020-11-28 22:29:26.724 Sunrise: 07:19:00 SunSet: 15:58:00
2020-11-28 22:29:26.725 Day length: 08:39:00 Sun at south: 11:39:00
2020-11-28 22:29:26.725 Civil twilight start: 06:43:00 Civil twilight end: 16:34:00
2020-11-28 22:29:26.725 Nautical twilight start: 06:04:00 Nautical twilight end: 17:13:00
2020-11-28 22:29:26.725 Astronomical twilight start: 05:26:00 Astronomical twilight end: 17:51:00
2020-11-28 22:29:26.553 Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2020-11-28 22:29:26.553 Status: Build Hash: b63341bc0, Date: 2020-04-26 12:47:55
2020-11-28 22:29:26.554 Status: Startup Path: /home/pi/domoticz/
2020-11-28 22:29:27.066 Active notification Subsystems: email (1/13)
2020-11-28 22:29:27.163 Starting shared server on: :::6144
2020-11-28 22:29:27.051 Status: PluginSystem: Started, Python version '3.6.8'.
2020-11-28 22:29:27.087 Status: WebServer(HTTP) started on address: :: with port 8080
2020-11-28 22:29:27.109 Status: WebServer(SSL) started on address: :: with port 443
2020-11-28 22:29:27.163 Status: TCPServer: shared server started...
2020-11-28 22:29:27.164 Status: RxQueue: queue worker started...
2020-11-28 22:29:29.166 Status: EventSystem: reset all events...
2020-11-28 22:29:29.167 Status: NotificationSystem: thread started...
2020-11-28 22:29:29.172 Status: EventSystem: reset all device statuses...
2020-11-28 22:29:29.245 Status: PluginSystem: Entering work loop.
2020-11-28 22:29:29.316 Status: Python EventSystem: Initalizing event module.
2020-11-28 22:29:29.317 Status: EventSystem: Started
2020-11-28 22:29:29.317 Status: EventSystem: Queue thread started...
2020-11-28 22:29:29.368 Status: RFLink: Using serial port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
2020-11-28 22:29:30.293 Status: RFLink: Controller Initialized!...
2020-11-28 22:29:30.369 Status: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2020-11-29 00:00:00.723 Sunrise: 07:21:00 SunSet: 15:57:00
2020-11-29 00:00:00.723 Day length: 08:37:00 Sun at south: 11:39:00
2020-11-29 00:00:00.723 Civil twilight start: 06:45:00 Civil twilight end: 16:33:00
2020-11-29 00:00:00.723 Nautical twilight start: 06:05:00 Nautical twilight end: 17:13:00
2020-11-29 00:00:00.723 Astronomical twilight start: 05:27:00 Astronomical twilight end: 17:51:00
2020-11-29 00:00:00.724 Status: EventSystem: reset all events...
2020-11-29 11:09:43.149 Status: Incoming connection from: 192.168.1.111
2020-11-30 00:00:00.671 Sunrise: 07:22:00 SunSet: 15:57:00
2020-11-30 00:00:00.671 Day length: 08:35:00 Sun at south: 11:39:00
2020-11-30 00:00:00.671 Civil twilight start: 06:46:00 Civil twilight end: 16:33:00
2020-11-30 00:00:00.671 Nautical twilight start: 06:06:00 Nautical twilight end: 17:12:00
2020-11-30 00:00:00.671 Astronomical twilight start: 05:28:00 Astronomical twilight end: 17:50:00
2020-11-30 00:00:00.672 Status: EventSystem: reset all events...
2020-11-30 09:24:52.347 Status: Incoming connection from: 192.168.1.11
[b]2020-11-30 12:30:15.549 (RFLink433) Light/Switch (DoorBell)[/b]
2020-11-30 12:32:17.833 Status: Incoming connection from: 192.168.1.74
[b]2020-11-30 16:52:38.998 (RFLink433) Light/Switch (DoorBell)[/b]
2020-12-01 00:00:00.791 Sunrise: 07:23:00 SunSet: 15:56:00
2020-12-01 00:00:00.791 Day length: 08:33:00 Sun at south: 11:40:00
2020-12-01 00:00:00.791 Civil twilight start: 06:47:00 Civil twilight end: 16:32:00
2020-12-01 00:00:00.791 Nautical twilight start: 06:07:00 Nautical twilight end: 17:12:00
2020-12-01 00:00:00.791 Astronomical twilight start: 05:29:00 Astronomical twilight end: 17:50:00
2020-12-01 00:00:00.792 Status: EventSystem: reset all events...
2020-12-01 13:17:38.819 Status: Incoming connection from: 192.168.1.11
[b]2020-12-01 15:42:57.447 (RFLink433) Light/Switch (DoorBell)[/b]
2020-12-01 16:35:30.368 Status: Incoming connection from: 192.168.1.11
Re: Send email notifications when someone ring at the door
florfilla19 wrote: Tuesday 01 December 2020 21:39 Email sending is already configured and works well
If you goto the switches tab and press [Notifications] on the DoorBell device, you get a new page like below
set the values as per the above screen and press press [Add] The next time the device is activated you should receive an Email.
2020-12-01 22:03:13.931  Status: Notification: Someone at the door
2020-12-01 22:03:13.933  (RFtrx433) Lighting 2 (Doorbell)
2020-12-01 22:03:16.293  Notification sent (email) => Success
Doorbell 2.png (4.95 KiB) Viewed 1222 times
florfilla19
@waaren Thanks for your reply
I have modified the notification according to your recommandations.
Will see if working tomoorow morning, It is too late for testing now :)
florfilla19
Tested today and no notifications received after pressing the doorbell.
Still able to find it in the logs btw
2020-12-03 08:32:53.789 (RFLink433) Light/Switch (DoorBell) :cry:
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
This setup is working well here. But I'm using telegram and did not select the ignore interval.
In my opinion Telegram is more faster and reliable then a message by mail.
EddyG
Post by EddyG »
florfilla19 wrote: Thursday 03 December 2020 21:01 Hello,
Did you configure Setup -> Settings -> Email ? AND press 'Test' to confirm sending email is working?
florfilla19
@EddyG Yes I have allready configure setting email for gmail and test email is received properly.
I change parameter "ignore interval" to disable
Can you verify the setting for your notifications interval at the end of Notification Tab ?
I have sensor 12hours and switches direct.
Under switches 'Doorbell Status is stop'
Log / Edit / Timers buttons below are blue only notifications button is purple
Did I need to change something from this switches tab ?
AllesVanZelf
sensors 12 hours, switches direct
Just to make sure:
On the settings pages, tab other (overige in dutch) doorbell command: group on.
In my case.
EddyG
Post by EddyG »
florfilla19 wrote: Friday 04 December 2020 9:15 Under switches 'Doorbell Status is stop'
Mine is type Doorbell
I use dzVents to send a message with picture, default to Telegram. Email is to slow.
Rest of settings is as yours.
florfilla19
Hello mates,
Allready Doorbell Command : Command Group On
On the other hand device type is light/switch
AllesVanZelf
Switchtype is doorbell here.
florfilla19
Finnaly we made it ! Thanks all for your help.
So the clue was switching to DoorBell rather than Light Switch and creating a second Alert for Switch On or Off.
Don't remember which one it was.
RFLink433 000355C8 19 DoorBell Light/Switch Mertik_GV60 Stop -
Will now look to connect something else because this raspberry + rflink is supposed to work a little more.
If you have any ideas to make life more simple with it I'm really interested.
I used this one: https://projetsdiy.fr/mini-gateway-rfli ... oitier-3d/
