Blocky triggered but not activated?
PABben
Post by PABben »
I have a Xiaomi wireless switch and a dummy switch. (I've made it this simple to exclude as many other factors as possible).
When i click the button it appears in the log as "EventSystem: Event triggered <name of script>_1 but nothing happens.
What am i doing wrong here?
Version: 2020.2
Build Hash: b63341bc0
Rpi 4
blocky doesnt work.jpg (246.83 KiB) Viewed 771 times
jvdz
Domoticz version: 4.107
Re: Blocky triggered but not activated?
Post by jvdz »
Are you sure you should test for "Click" in stead of "On"?
What does the log for that switch tell you?
PABben
Post by PABben »
Thx for reply :)
The log is saying "Click", "Double Click" and so on. On my old server (version 4.10717) it is working fine with the same script.
blocky click.jpg (125.45 KiB) Viewed 767 times
jvdz
Post by jvdz »
Maybe you need to test the LEVEL sinds this seems to be a Selector switch.
Off = 0%; Click =10% ; etc.
Jos
PABben
Post by PABben »
I created a virtual trigger switch so i ended with 2 dummy-switches.
Still same result.
It cannot get it any more basic than this so what happens when i am to include more than 2 switches :shock:
blocky fail again.jpg (216.79 KiB) Viewed 747 times
PABben
Post by PABben »
No blocky scripts have ever worked. I tried to disable then re-enable "EventSystem" but no changes
eventsytem active.jpg (25.76 KiB) Viewed 746 times
jvdz
Post by jvdz »
Just tried a similar basic test on my VM test machine and that works fine on the latest Beta build, so have no idea what is going wrong on your system.
Maybe try creating another test dummy switch to set by the script in stead of "Testbryter" ?
PABben
Post by PABben »
No good. It seems to be a problem with the eventsystem or blocky system it self.
I gave up (again), reinstalled (7th time :S ) and now it's working fine. For now...
