I have a Xiaomi wireless switch and a dummy switch. (I've made it this simple to exclude as many other factors as possible).
When i click the button it appears in the log as "EventSystem: Event triggered <name of script>_1 but nothing happens.
What am i doing wrong here?
Version: 2020.2
Build Hash: b63341bc0
Rpi 4
Blocky triggered but not activated?
PABben
- blocky doesnt work.jpg (246.83 KiB) Viewed 1113 times
- jvdz
- Domoticz version: 4.107
Re: Blocky triggered but not activated?
Are you sure you should test for "Click" in stead of "On"?
What does the log for that switch tell you?
PABben
Thx for reply
The log is saying "Click", "Double Click" and so on. On my old server (version 4.10717) it is working fine with the same script.
- blocky click.jpg (125.45 KiB) Viewed 1109 times
- jvdz
Maybe you need to test the LEVEL sinds this seems to be a Selector switch.
Off = 0%; Click =10% ; etc.
Jos
Jos
PABben
I created a virtual trigger switch so i ended with 2 dummy-switches.
Still same result.
It cannot get it any more basic than this so what happens when i am to include more than 2 switches
Still same result.
- blocky fail again.jpg (216.79 KiB) Viewed 1089 times
PABben
No blocky scripts have ever worked. I tried to disable then re-enable "EventSystem" but no changes
- eventsytem active.jpg (25.76 KiB) Viewed 1088 times
- jvdz
Just tried a similar basic test on my VM test machine and that works fine on the latest Beta build, so have no idea what is going wrong on your system.
Maybe try creating another test dummy switch to set by the script in stead of "Testbryter" ?
PABben
No good. It seems to be a problem with the eventsystem or blocky system it self.
I gave up (again), reinstalled (7th time :S ) and now it's working fine. For now...
