GarbageCalendar (new version) lua scripts
- jvdz
- Domoticz version: 4.107
Re: GarbageCalendar (new version) lua scripts
@iTDB, I think I found the issue you have: I tested with a streetname that contains a space and was able to replicate your issue.
( believe this the info for your zipcode/housnr/street: restafval: vri 9 okt ; pmd: vri 9 okt ; gft: vri 16 okt ; ?)
This is fixed in the current version on GitHub, so could you test that and let me know?
When you still have issues, please Email your logfiles as indicated so I can check the details.
Jos
Jos
iTDB
- Domoticz version: Stable
It works. Thxjvdz wrote: Wednesday 07 October 2020 17:31 @iTDB, I think I found the issue you have: I tested with a streetname that contains a space and was able to replicate your issue.
When you still have issues, please Email your logfiles as indicated so I can can the details.
Jos
- Rolandet
- Domoticz version: 2021.1
JvdZ.
I'm trying to get the notifications up and running, but tbh I can't figure out what to do with this line:
Notificationsystem = '' -- Specify notification system eg "telegram/pushover/gcm/http/kodi/lms/nma/prowl/pushalot/pushbullet/pushsafer" leave empty to skip
I could enter 'mail' , but is that enough? Or should it be smtp or something?
tnx
tnx
Custodes Septentrionum
- jvdz
Mail is not an option in that list.
It is basically pretty strait forward: You have these 3 options which you can define:
So:
- When you want to receive Email notifications you use the first line and define 1 or more Email addresses.
- When you want to use any of the other Domoticz internal Notification systems you specify that option in the second line.
- When you want to run a script to handle the notifications you use the third line.
All clear?
Jos
NotificationEmailAdress = {'',''} -- Specify multiple Email Addresses for the notifications. Leave empty to skip email notification
Notificationscript = '' -- Specify personal notification script/command eg: lua sendmessage.lua "@TEXT@" (where @TEXT@ will be replaced by the notification text.)
All clear?
Jos
- Rolandet
aaah
quite clear
I have entered an emailaddress, but haven't received any notifications sofar.
- jvdz
You did specify the appropriate information in the garbagetype_cfg table?
Should you have received one already?
If so ... check the logs when it should have been send so you can see whether there is an error.
Jos
Jos
- Rolandet
Yeah, this is my _cfg table:jvdz wrote: Thursday 08 October 2020 21:54 You did specify the appropriate information in the garbagetype_cfg table?
Jos
garbagetype_cfg = {
-- Add any missing records below this line
["pmd"] ={hour=19,min=22,daysbefore=1,reminder=1,text="pmd"},
["gft"] ={hour=19,min=22,daysbefore=1,reminder=1,text="gft"},
["papier"] ={hour=19,min=22,daysbefore=1,reminder=1,text="papier"},
["biobak1"] ={hour=19,min=22,daysbefore=1,reminder=1,text="Groene Container"},
["sortibak0"] ={hour=19,min=22,daysbefore=1,reminder=1,text="Grijze Container"},
["oud papier en karton3"] ={hour=19,min=22,daysbefore=1,reminder=1,text="Papiercontainer"},
["grofvuil (3 keer gratis)5"] ={hour=19,min=22,daysbefore=1,reminder=1,text="Grofvuil"},
["chemisch afval4"] ={hour=19,min=22,daysbefore=1,reminder=1,text="KCA"},
This is the entire garbagecalendar_run_m_omrin.log
@GarbageCal(m_omrin): #### Fri Oct 9 16:20:00 2020 ### Start garbagecalendar script v20200906-1400
@GarbageCal(m_omrin): #### Debuging dataload each cycle in the foreground because "testdataload=true" in garbagecalendarconfig.lua
@GarbageCal(m_omrin): #### please change it back to "testdataload=false" when done testing to avoid growing a big domoticz log and slowing down the event system.
@GarbageCal(m_omrin): #### Debuging with extra messages because "mydebug=true" in garbagecalendarconfig.lua
@GarbageCal(m_omrin): #### please change it back to "mydebug=false" when done testing to avoid growing a big domoticz log.
@GarbageCal(m_omrin): domoticzjsonpath: /home/pi/domoticz/scripts/lua/
@GarbageCal(m_omrin): datafilepath: /var/tmp/
@GarbageCal(m_omrin): scriptpath: /home/pi/domoticz/scripts/lua/
@GarbageCal(m_omrin): Loaded /home/pi/domoticz/scripts/lua/garbagecalendar/garbagecalendarconfig.lua.
@GarbageCal(m_omrin): Loaded /home/pi/domoticz/scripts/lua/garbagecalendar/generalfuncs.lua.
@GarbageCal(m_omrin): 16:20:00 start new foreground webupdate for module m_omrin of file /var/tmp/garbagecalendar_m_omrin.data
@GarbageCal(m_omrin_api): 16:20:00 webupdate done.
@GarbageCal(m_omrin_api): Start checking garbagetype_cfg table:
@GarbageCal(m_omrin_api): -> NotificationTime=19:22 Garbagetype=gft
@GarbageCal(m_omrin_api): -> NotificationTime=19:22 Garbagetype=chemisch afval4
@GarbageCal(m_omrin_api): -> NotificationTime=19:22 Garbagetype=sortibak0
@GarbageCal(m_omrin_api): -> NotificationTime=02:30 Garbagetype=reloaddata
@GarbageCal(m_omrin_api): -> NotificationTime=19:22 Garbagetype=papier
@GarbageCal(m_omrin_api): -> NotificationTime=19:22 Garbagetype=biobak1
@GarbageCal(m_omrin_api): -> NotificationTime=19:22 Garbagetype=pmd
@GarbageCal(m_omrin_api): -> NotificationTime=19:22 Garbagetype=oud papier en karton3
@GarbageCal(m_omrin_api): -> NotificationTime=02:31 Garbagetype=dummy1
@GarbageCal(m_omrin_api): -> NotificationTime=19:22 Garbagetype=grofvuil (3 keer gratis)5
@GarbageCal(m_omrin_api): Start update for text device:
@GarbageCal(m_omrin_api): - Start looping through data from the website to find the first 4 event to show: /var/tmp/garbagecalendar_m_omrin.data
==> GarbageDate:2020-10-9 GarbageType:sortibak0; Notify: Active=on Time=19:22 DaysBefore=1 reminder=1 Calc Days Diff=0
==> GarbageDate:2020-10-15 GarbageType:oud papier en karton3; Notify: Active=on Time=19:22 DaysBefore=1 reminder=1 Calc Days Diff=6
==> GarbageDate:2020-10-16 GarbageType:chemisch afval4; Notify: Active=on Time=19:22 DaysBefore=1 reminder=1 Calc Days Diff=7
==> GarbageDate:2020-10-16 GarbageType:biobak1; Notify: Active=on Time=19:22 DaysBefore=1 reminder=1 Calc Days Diff=7
@GarbageCal(m_omrin_api): - End -----------------
@GarbageCal(m_omrin_api): ==> found schedule:Grijze Container: Vr 9 Okt ; Papiercontainer: Do 15 Okt ; KCA: Vr 16 Okt ; Groene Container: Vr 16 Okt ;
@GarbageCal(m_omrin_api): Update device from:
KCA: Vr 16 Okt
replace with:
KCA: Vr 16 Okt
@GarbageCal(m_omrin_api): #### 16:20:00 End garbagecalendar script v20200919-1600
- jvdz
Yea as in you did define, but not Yea as in you should have receive a message.
These lines tell you why:
When you want to test this, just change the settings temporarily in de ConFIg so it should send a notification and then check the log when it did't work.
Jos
This script ran at 16:20 and the notification times are set at 19:22 on 1 day before.#### Fri Oct 9 16:20:00 2020 ### Start garbagecalendar script v20200906-1400
--snip--
Jos
- Rolandet
If I understand this correctly (and I may not, it's been known to happenjvdz wrote: Friday 09 October 2020 16:32 Yea as in you did define, but not Yea as in you should have receive a message.
These lines tell you why:This script ran at 16:20 and the notification times are set at 19:22 on 1 day before.#### Fri Oct 9 16:20:00 2020 ### Start garbagecalendar script v20200906-1400
--snip--
Jos
- Rolandet
btw, problem with checking the logs right after when it should've sent a notification, is that the logfiles seem to update every minute (and overwrite the old entries)
- jvdz
Yes I know, but didn't want to make a always growing logfile, so simply set the setting in the config so that it should trigger the notification a minute away... save the file .... wait for the actual run ... open the run log file and check what it did.
Also check the domoticz log as all it really does is one of these:
So in de domoticz.log you should see the result of the processing of these commands.
Jos
commandArray[x] = {['SendEmail'] = inotificationtitle .. '#' .. inotificationtext .. '#' .. emailaddress}
commandArray['SendNotification']=inotificationtitle .. '#' .. inotificationtext .. '####'..Notificationsystem
Jos
- jvdz
Oh,... I actually did add an undocumented notification test option to the script a while ago you could try to add to the config too:
You could try this, but this will trigger the notification with each 1 minute loop.
Jos
testnotification = true -- (true/false) -- this will trigger a test notification for the first record for testingJos
- jvdz
By the way: this statement is not totally valid as there are 2 run logs generated:Rolandet wrote: Friday 09 October 2020 16:39 btw, problem with checking the logs right after when it should've sent a notification, is that the logfiles seem to update every minute (and overwrite the old entries)
garbagecalendar_run_m_module.log -> Each minute log
garbagecalendar_run_update_m_module.log -> Last update run log, which is at one of the times defined in the config table
This obviously is only valid when you have a debugging options disabled, which should always be the case when not debugging!
Jos
- Rolandet
Allrighty, we have some progressjvdz wrote: Friday 09 October 2020 16:49 Yes I know, but didn't want to make a always growing logfile, so simply set the setting in the config so that it should trigger the notification a minute away... save the file .... wait for the actual run ... open the run log file and check what it did.
Also check the domoticz log as all it really does is one of these:So in de domoticz.log you should see the result of the processing of these commands.Code: Select all
commandArray[x] = {['SendEmail'] = inotificationtitle .. '#' .. inotificationtext .. '#' .. emailaddress} commandArray['SendNotification']=inotificationtitle .. '#' .. inotificationtext .. '####'..Notificationsystem
Jos
The run_log showed:
@GarbageCal(m_omrin_api): ---->Notification Email send for biobak1 |GarbageCalendar: over 7 dagen de Groene Container aan de weg zetten!#Groene Container wordt over 7 dagen opgehaald! ()|
Also, no email received
- jvdz
Do you have the EMail notification settings in Domoticz defined in the EMAIL tab and it is working successfully?
edit:
edit:
It should just show up in the Web interface LOG window without searching as it happens now.No entries in domoticz log though (looked for the lines/keywords you suggested)
- Rolandet
and there we go..........my email settings were NOT correct.jvdz wrote: Friday 09 October 2020 17:03 Do you have the EMail notification settings in Domoticz defined in the EMAIL tab and it is working successfully?
edit:It should just show up in the Web interface LOG window without searching as it happens now.No entries in domoticz log though (looked for the lines/keywords you suggested)![]()
Thanks for debugging m8, it works !
- Xenomes
- Domoticz version: 2025.2
I found the problem, was a human error. i used plastic instead of gmdjvdz wrote: Tuesday 06 October 2020 16:25 I see a couple of strange things in the log that I don't understand, so could you Email me the following files in a zip file, so I can have a closer look? :.. but it feels like something is going in the nightly run. This info is located in the garbage_web_m_csv_file.log.
- Garbagecalendarconfig.lua
- Your input datafile with the csv dates as defined in the config.
- /var/tmp/garbagecalendar_m_csv_file.data
- /var/tmp/garbage_run_m_csv_file.log
- /var/tmp/garbage_run_update_m_csv_file.log
- /var/tmp/garbage_web_m_csv_file.log
Thanks, Jos
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
- jvdz
Great you found the issue, but I would still have expected some data to be shown in your posted log when it was just a GarbageType name being wrong.Xenomes wrote: Saturday 10 October 2020 8:59 I found the problem, was a human error. i used plastic instead of gmd![]()
Jos
mikeoo
Saw there is a new version and want to test is but it is missing my garbage collector
Can you also make it work for: inzamelkalender.stadswerk072.nl
Zipcode: 1486 MK
Number: 88
Zipcode: 1486 MK
Number: 88
- jvdz
Should work fine with these settings:
Jos
wmodule=m_opzet_api
Hostname=inzamelkalender.stadswerk072.nl
Zipcode=1486MK
Housenr=88
Schedule: gft & etensresten: maa 19 okt ; plastic, blik & drinkpakken: vri 23 okt ; restafval.: maa 26 okt ;
Done...
