Dashticz - Module - Garbage collector Topic is solved
HansieNL
Re: Dashticz - Module - Garbage collector
Post by HansieNL »
herbod wrote: Sunday 27 September 2020 22:16
HansieNL wrote: Sunday 27 September 2020 21:48 @herbod
Thank you! it is working again. I have sett ['garbage_use_cors_prefix'] to true but wat does it do? I am trying to understand what i did.
Answer: You can find a description here: https://dashticz.readthedocs.io/en/mast ... cors-proxy
What is the option "calendar_parse_locally" - This is an old setting and not used anymore.
So I can remove it?
Answer: Yes
The days are mentioned in English, can I get them in Dutch?
I have : var config = {}
config['language'] = 'nl_NL';
So I expected them to be in dutch.
Answer: try adding
config['calendarlanguage'] = 'nl_NL';
to your config.js
Thanks!! Sometimes it can be so simple. Was looking for this for a while.
Can I change the date 06-10-2020 in the garbage collector dinsdag (tuesday) 06-10-2020, so adding the day?
As far as I know is this not possible.
If the garbage pickup is within a week/day, the date will be changed to the weekday, tomorrow. If it’s today, today will be shown.
Blah blah blah
geertvercamer
Post by geertvercamer »
recycleapp is not working here.
not in 3.5.2 anymore, not in 3.6
cors setting is set to true
3.5.2 has garbage_company still on 'ophaalkalender'
3.6 has garbage_company set to 'recycleapp'
both just show 'loading'
geertvercamer
3.6.2 now gives 'no data found' (in Dutch)
garbage.js line 999: shouldn't that read 'identifier' instead of 'identified'?
Lokonli
Post by Lokonli »
It seems recycleapp.be doesn't work at the moment:
(and you are right on your remark on line 999. Thanks! but not related to this issue)
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
The recycleapp website is working again after being down for some days. However the dashticz garbage doesn't get any data on 3.6.0 and 3.6.2 beta.
Probably the API that's still down...
Lokonli
Post by Lokonli »
sammyke007 wrote:The recycleapp website is working again after being down for some days. However the dashticz garbage doesn't get any data on 3.6.0 and 3.6.2 beta.
No, it was my mistake. I filtered the data until September. I'll create a fix tomorrow.
Lokonli
Post by Lokonli »
sammyke007 wrote: Wednesday 30 September 2020 22:48 The recycleapp website is working again after being down for some days. However the dashticz garbage doesn't get any data on 3.6.0 and 3.6.2 beta.
Fixed in latest beta.
sammyke007
Fast fix once again and working again. Tnx Lokonli!
cever
Post by cever »
Just updated to 3.6.5 beta, the garbage doesn't work with recycleapp (BE), looking (very) quickly in garbage.js I could not find any url to fetch the data, is this a known issue ?
Lokonli
Post by Lokonli »
I just discovered a bug in 3.6.5.
Please update to beta 3.6.6 and retry.
recycleapp is working on my system.
Ultimato
Post by Ultimato »
hi,
Mijn Afvalwijzer is not working here.
The error I get is because it is trying to get it's info from http://192.168.1.247:8083/0https://www. ... /*censored*/
this is the part of the config concerning the garbage collection:
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_icalurl'] = 0;
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = '*censored*';
config['garbage_street'] = 0;
config['garbage_housenumber'] = '*censored*';
config['garbage_housenumberadd'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
// --------------------------------------- afvalinzameling -----------------------------------------------------------
config['garbage_mapping'] = {
rest: ['grof', 'grey', 'rest', 'grijs','grijze'],
gft: ['gft', 'tuin', 'refuse bin', 'green', 'groen', 'Biodégradables', 'snoei'],
pmd: ['plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
papier: ['papier', 'blauw', 'blue', 'recycling bin collection'],
kca: ['chemisch', 'kca','kga'],
brown: ['brown', 'verre'],
black: ['black', 'zwart'],
milieu: ['milieu'],
kerstboom: ['kerst'],
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
any idea how I could solve this?
I'm running dashticz 3.6.6
I'm Running domoticz beta on a Rpi 4
Lokonli
Post by Lokonli »
Ultimato wrote: Saturday 31 October 2020 22:32 hi,
milieu: ['milieu'],
It seems that your CORS proxy setting is incorrectly set to 0.
Did you add a config['default_cors_url'] setting in CONFIG.js? I would recommend to remove it.
Ultimato
Post by Ultimato »
:shock: when I checked the previous posts I found a ['default_cors_url'] setting set to 1.
I thought that might have been the problem so I removed it.
This morning, checking the config line by line again, I did indeed find another instance of ['default_cors_url'] which was set to 0
Garbage collection working as expected now, thanks!
Timbau
Post by Timbau »
Do you have the option to add?
https://afvalstoffendienstkalender.nl/
My zipcode 5251 be
Regards Tim
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Is it possible to make a custom block of the Garbage output.
Now the only way is to are the line to the columns, but not configure it as a block.
I like to reduce the width to 6 instead of the stand 12 (complete width of the column)
Lokonli
Post by Lokonli »
I'm rewriting the garbage module at the moment. It will then just behave like any other custom block. I'll also use it for auto testing as well. Currently I'm more or less half way testing all the garbage providers. See below for an intermediate result:
As soon as I've finalized the conversion, I'll add afvalstoffendienstkalender.nl
smaus
Post by smaus »
since a month I no longer receive a notification about residual waste, and I get the following notification in my log.
@AFOpzet Error: Waste type not defined in the "waste type_cfg" table for found Waste type: Residual waste.
concerns the city of Purmerend
Lokonli
Post by Lokonli »
smaus wrote: Tuesday 03 November 2020 19:55 since a month I no longer receive a notification about residual waste, and I get the following notification in my log.
I don't recognize your log. Is it related to Dashticz?
Support for purmerend garbage collection has been added to latest beta.
Lokonli
Post by Lokonli »
Timbau wrote: Monday 02 November 2020 9:13 Do you have the option to add?
My zipcode 5251 be
Regards Tim
afvalstoffendienst has been added to latest beta.
Antoinne
Post by Antoinne »
Previsously I used this module with a custom 'ical' calender. After the recent update, I now get an "Error loading garbage data" on start-up. Would love to use the new block method. But can you add support for Grondstoffen- en Afvalstoffendienst regio Gooi en Vechtstreek (https://inzamelkalender.gad.nl)?
