GarbageCalendar (new version) lua scripts
- Xenomes
- Domoticz version: 2025.2
Re: GarbageCalendar (new version) lua scripts
Ok we gonna try!
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
- jvdz
- Domoticz version: 4.107
What about when I write a generic module that wil take a CSV file as input that contains GarbageDate en GarbageType? This way the CSV file can contain the whole years data and the nightly "Web update" will then read it and convert it into de required DATA file.
Jos
Jos
- Xenomes
I managed to make a dummy and created a data file (made from another zip code) and alter it to my garbage service dates.
That will be a better solution! Now i had to change the paths in the config and create a dummy file (org m_mijnafvalwijzer.lua) where i commit out the 'web update' section.jvdz wrote: Wednesday 16 September 2020 9:33 What about when I write a generic module that wil take a CSV file as input that contains GarbageDate en GarbageType? This way the CSV file can contain the whole years data and the nightly "Web update" will then read it and convert it into de required DATA file.
websitemodule = "m_dummy"
-- Switch on mydebug in case of issues and initially and check the domoticz log for any issues or missing
mydebug = false -- (true/false)
testdataload = false -- (true/false)
-- Specify the appropriate directories (Raspberry Pi example)
datafilepath = '/home/pi/domoticz/scripts/lua' -- specify the directory where the garbagecalendar.data & garbagecalendar.log will be stored
scriptpath = '/home/pi/domoticz/scripts/lua' -- specify the directory for the main "script_time_garbagecalendar.lua" script
domoticzjsonpath = '/home/pi/domoticz/scripts/lua' -- specify the path to domoticz where the JSON.lua file can be found
- jvdz
The module m_csv_file is available in the Github Development branch. The module itself contains the in expected input format and the variable that needs to be defined in the garbagecalendarconfig.lua file.:
Have a try and see whether that works for you as well.
Jos
ver="20200916-1600"
websitemodule="m_csv_file"
This module requires an inputfile defined by this variable in the configfile:
input_csv_file = "garbagecalendar/garbage_input.csv"
--With the following format:--
garbagedate;garbagetype
20-8-2020;papier
23-8-2020;GFT
1-9-2020;Rest
10-9-2020;papier
21-9-2020;GFT
30-9-2020;Rest
3-10-2020;papier
4-10-2020;GFT
5-10-2020;Rest
--]]Jos
wauw , can you make it work for OMRIN also?
in leeuwarden works only OMRIN i think
- Xenomes
Thnx, I have set is all up, tomorrow the first notification will be triggered.
- jvdz
I'll have a look later this week to see what is needed to make it work.martin82 wrote: Saturday 19 September 2020 16:22 wauw , can you make it work for OMRIN also?
Hann1BaL
- Domoticz version: 2022.2
Curious, did you get it to work? And did you populate all dates manually in the csv?
Since its broken I realize why I made it work in the first place! I really rely on the light in my room to tell me to put the bin out and which bin that day..
Also, what is the best way to update the script? Just download and write over the files?
- Xenomes
Yes i did, but i had made a error in my csv file so i mist the test dayHann1BaL wrote: Friday 25 September 2020 12:19Curious, did you get it to work? And did you populate all dates manually in the csv?Xenomes wrote: Sunday 20 September 2020 9:34 Thnx, I have set is all up, tomorrow the first notification will be triggered.
- jvdz
I've used Excel to edit/update the csv.
- Rolandet
- Domoticz version: 2021.1
@jvdz
I gave this script a try. Works like a charm for Omrin
At the first attempt I forgot to add
websitemodule = "m_omrin" to the garbagecalendarconfig.lua
But it's working now.
Only thing I can't get to work, is the icon. It still gives me the default 'text'
any thoughts on that?
Custodes Septentrionum
- jvdz
This is something you need to do in Domoticz yourself with custom ico's.Rolandet wrote: Sunday 27 September 2020 18:46 Only thing I can't get to work, is the icon. It still gives me the default 'text'
I haven't played with custom icon myself as I am not working much with the webinterface so didn't bother.
Jos
- Rolandet
ok thanks. I'll try figure it out. Thanks for the scriptjvdz wrote: Sunday 27 September 2020 18:55This is something you need to do in Domoticz yourself with custom ico's.Rolandet wrote: Sunday 27 September 2020 18:46 Only thing I can't get to work, is the icon. It still gives me the default 'text'
Jos
yes thanx for the script en thanx for all the help.
greetz martin
greetz martin
- Xenomes
Hi jvdz, i have a issue with the m_csv_file module. It is showing two old notifications. i just enable debugging to create a log, normally the script updates 2:30.
Log:
- Spoiler: show
- jvdz
I see a couple of strange things in the log that I don't understand, so could you Email me the following files in a zip file, so I can have a closer look? :
Thanks, Jos
- Garbagecalendarconfig.lua
- Your input datafile with the csv dates as defined in the config.
- /var/tmp/garbagecalendar_m_csv_file.data
- /var/tmp/garbage_run_m_csv_file.log
- /var/tmp/garbage_run_update_m_csv_file.log
- /var/tmp/garbage_web_m_csv_file.log
Thanks, Jos
iTDB
- Domoticz version: Stable
Because my Domoticz no longer worked properly, I reinstalled it completely. I took a test raspberry for the Garbage calendar (m_recycleapp-be is now used) and it doesn't work at all anymore.
I get the following error:
2020-10-07 14:38:00.927 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_garbagecalendar.lua: ...domoticz/scripts/lua/garbagecalendar/m_recycleapp-be.lua:78: attempt to index a nil value (field '?')
2020-10-07 14:38:00.338 Status: LUA: @GarbageCal(m_recycleapp-be): #### Wed Oct 7 14:38:00 2020 ### Start garbagecalendar script v20200906-1400
2020-10-07 14:38:00.338 Status: LUA: @GarbageCal(m_recycleapp-be): #### Debuging with extra messages because "mydebug=true" in garbagecalendarconfig.lua
2020-10-07 14:38:00.338 Status: LUA: @GarbageCal(m_recycleapp-be): #### please change it back to "mydebug=false" when done testing to avoid growing a big domoticz log.
2020-10-07 14:38:00.339 Status: LUA: @GarbageCal(m_recycleapp-be): domoticzjsonpath: /home/pi/domoticz/scripts/lua/
2020-10-07 14:38:00.339 Status: LUA: @GarbageCal(m_recycleapp-be): datafilepath: /home/pi/domoticz/logs/
2020-10-07 14:38:00.339 Status: LUA: @GarbageCal(m_recycleapp-be): scriptpath: /home/pi/domoticz/scripts/lua/
2020-10-07 14:38:00.339 Status: LUA: @GarbageCal(m_recycleapp-be): Loaded /home/pi/domoticz/scripts/lua/garbagecalendar/garbagecalendarconfig.lua.
2020-10-07 14:38:00.341 Status: LUA: @GarbageCal(m_recycleapp-be): Loaded /home/pi/domoticz/scripts/lua/garbagecalendar/generalfuncs.lua.
2020-10-07 14:38:00.341 Status: LUA: @GarbageCal(m_recycleapp-be): Start checking garbagetype_cfg table:
2020-10-07 14:38:00.342 Status: LUA: @GarbageCal(m_recycleapp-be): -> NotificationTime=19:22 Garbagetype=papier
2020-10-07 14:38:00.342 Status: LUA: @GarbageCal(m_recycleapp-be): -> NotificationTime=02:31 Garbagetype=dummy1
2020-10-07 14:38:00.342 Status: LUA: @GarbageCal(m_recycleapp-be): -> NotificationTime=19:22 Garbagetype=pmd
2020-10-07 14:38:00.342 Status: LUA: @GarbageCal(m_recycleapp-be): -> NotificationTime=02:30 Garbagetype=reloaddata
2020-10-07 14:38:00.342 Status: LUA: @GarbageCal(m_recycleapp-be): -> NotificationTime=19:22 Garbagetype=gft
2020-10-07 14:38:00.342 Status: LUA: @GarbageCal(m_recycleapp-be): Start update for text device:
2020-10-07 14:38:00.342 Status: LUA: !!! table.load error:cannot open /home/pi/domoticz/logs/garbagecalendar_m_recycleapp-be.data: No such file or directory
2020-10-07 14:38:00.343 Status: LUA: !!! unable to read Data from /home/pi/domoticz/logs/garbagecalendar_m_recycleapp-be.data
2020-10-07 14:38:00.343 Status: LUA: @GarbageCal(m_recycleapp-be): ### Warning: Datafile not found:/home/pi/domoticz/logs/garbagecalendar_m_recycleapp-be.data . Start webupdate now.
2020-10-07 14:38:00.343 Status: LUA: @GarbageCal(m_recycleapp-be): 14:38:00 start new foreground webupdate for module m_recycleapp-be of file /home/pi/domoticz/logs/garbagecalendar_m_recycleapp-be.data
2020-10-07 14:38:00.350 Status: LUA: -H "x-secret: Qp4KmgmK2We1ydc9Hxso5D6K0frz3a9raj2tqLjWN5n53TnEijmmYz78pKlcma54sjKLKogt6f9WdnNUci6Gbujnz6b34hNbYo4DzyYRZL5yzdJyagFHS15PSi2kPUc4v2yMck81yFKhlk2aWCTe93" -H "x-consumer: recycleapp.be"
- jvdz
@iTDB,
So it tries to do a web update since the data files doesn't exists yet so I need to see the output for that: What is the contents of the garbage_web_m_recycleapp-be.log?
Jos
Jos
iTDB
@m_recycleapp-be: #### Wed Oct 7 14:56:00 2020 ### Start garbagecalendar module m_recycleapp-be (v202008018-1700)
@m_recycleapp-be: Loaded JSON.lua.
@m_recycleapp-be: !!! perform background update to /home/pi/domoticz/logs/garbagecalendar_m_recycleapp-be.data for Zipcode 9000 - 59 (optional) Host$
@m_recycleapp-be: ---- web update ----------------------------------------------------------------------------
@m_recycleapp-be: sQuery=curl -k -H "x-secret: Qp4KmgmK2We1ydc9Hxso5D6K0frz3a9raj2tqLjWN5n53TnEijmmYz78pKlcma54sjKLKogt6f9WdnNUci6Gbujnz6b34hNbYo4Dz$
@m_recycleapp-be: ---- web data ----------------------------------------------------------------------------
@m_recycleapp-be: {"accessToken":"eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpYXQiOjE2MDIwNzUzNjAsImV4cCI6MTYwMjA3ODk2MCwiYXVkIjoicmVjeWNsZWFwcC5iZSJ9.n$
@m_recycleapp-be: ---- web err ------------------------------------------------------------------------
@m_recycleapp-be: Web_Err= % Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
^M 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0^M100 175 100 175 0 0 1325 0 --:--:-- --:--:-- --:$
@m_recycleapp-be: ---- end web data ------------------------------------------------------------------------
@m_recycleapp-be: accessToken:eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpYXQiOjE2MDIwNzUzNjAsImV4cCI6MTYwMjA3ODk2MCwiYXVkIjoicmVjeWNsZWFwcC5iZSJ9.nqKMh$
@m_recycleapp-be: {"items":[{"city":{"names":{"nl":"Gent","fr":"Gand","de":"Gent","en":"Gent"},"zipcodes":["9000-44021","9030-44021","9031-44021","90$
^M 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0^M100 789 0 789 0 0 5759 0 --:--:-- --:--:-- --:$
@m_recycleapp-be: postcode_id:9000-44021
@m_recycleapp-be: {"items":[],"total":0,"pages":0,"page":1,"size":20,"self":"http://datatank-datatank-http:8080/v1/s ... odes%5B0%5$
^M 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0^M100 469 0 469 0 0 3692 0 --:--:-- --:--:-- --:$
- jvdz
I really need the whole file as attachment in an EMail as I can only see the first 150 characters.
My current guess is that the streetname isn't found, but I can only determine that when I have access to the whole file.
see next post
Jos
see next post
Jos
