Blockly/Domoticz acting weird
Domostiaan
Post by Domostiaan »
HI,
i have been trying to get an energy saving event running through Blockly.
Which most of the time works. but now almost once a day it shutsdown the AV plug without a good reason.
i have it setup the following way:
Step 1 is seeing that the usage is lower than 10Watt.
step 1 usage lower .jpg (75.94 KiB) Viewed 424 times
Step 2 seeing usage is again above 10 watt after 2100seconds (20 minutes) and cancel shutdown.
step 2 usage high again.jpg (86.69 KiB) Viewed 424 times
Step 3 is seeing usage still is lower than 10Watt after 20 minutes. and shutdown Shelly Plug S.
step 3 usage stays low.jpg (88.65 KiB) Viewed 424 times
but the Shelly Plug now gets randomly shutdown by Step 2 that doesn't even contain the Shelly Plug inside the event.
of by an not existing timer.
i hope to find a way to eliminate these strange errors.
will plage screenshots of the log in second post because of limit of 3 attachments.
Domostiaan
Re: Blockly/Domoticz acting weird
log and general log
the Shelly Plug Log, in RED the latest random shutdown when usage was 200Watt+ in YELLOW a timer shutdown (i don't have timers set for this device) in BLUE random shutdown, after this one i deleted all events en created them again in case something went wrong behind the scene.
General log, it sees step 1 and 2. but at the time of shutdown 21:51:16 is sees nothing.
general log.jpg (63.06 KiB) Viewed 423 times
Domostiaan wrote: Thursday 17 September 2020 23:03 log and general log
I see in the screenshots that you set the 3 Blockly scripts to trigger at 'All' , implying on every device update in the system and every minute. Is this as intended?
The (relatively new) user field in the log cannot be trusted yet.
see this forum post and this github issue
