HI,
i have been trying to get an energy saving event running through Blockly.
Which most of the time works. but now almost once a day it shutsdown the AV plug without a good reason.
i have it setup the following way:
but the Shelly Plug now gets randomly shutdown by Step 2 that doesn't even contain the Shelly Plug inside the event.
of by an not existing timer.
i hope to find a way to eliminate these strange errors.
will plage screenshots of the log in second post because of limit of 3 attachments.
Blockly/Domoticz acting weird
Domostiaan
Domostiaan
Re: Blockly/Domoticz acting weird
log and general log
- the Shelly Plug Log, in RED the latest random shutdown when usage was 200Watt+ in YELLOW a timer shutdown (i don't have timers set for this device) in BLUE random shutdown, after this one i deleted all events en created them again in case something went wrong behind the scene.
- log.jpg (185.89 KiB) Viewed 562 times
- General log, it sees step 1 and 2. but at the time of shutdown 21:51:16 is sees nothing.
- general log.jpg (63.06 KiB) Viewed 562 times
- waaren
I see in the screenshots that you set the 3 Blockly scripts to trigger at 'All' , implying on every device update in the system and every minute. Is this as intended?
The (relatively new) user field in the log cannot be trusted yet.
see this forum post and this github issue
