Aqara vibration sensor
GilbertvH
Post by GilbertvH »
I've paired an Aqara vibration sensor to my Zigate but how can I adjust the sensitivity?
Damsee
Domoticz version: 4.10717
Re: Aqara vibration sensor
Post by Damsee »
You need to set the paramter through the Zigate web admin page which should be available at http://yourIP:9440/
Go to "Settings" and you should get the following:
Documentation is available : https://github.com/pipiche38/Domoticz-Z ... nf.json.md
You can set the sensitivity to low, medium, high
RPI3 Raspbian Buster + Domoticz v2020.1 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
GilbertvH
Post by GilbertvH »
Damn... Missed that one! Thanks!
dheuts
Post by dheuts »
I have two of these, connected with Zigbee2mqtt.
One of the sensors is going back to Off after one second, the other one stays on Vibration or Tilt, so I have to put it back to off state with a Blockly command after a couple of seconds after movement.
What is normal behaviour? How does it work at your places?
Any idea how to get them both working the same way?
Raspberry Pi 4 With Domoticz - RFXCom - Tuya Wifi LED lights - Chuango Alarm - Zwave+ - Zigbee2MQTT - Anna Thermostat - Broadlink IR, P1 - Eufy Robo Vacuum - Worx Robo Mower
