Blockly does not work with door contact and dummy Topic is solved
jellex87
Post by jellex87 »
why does this one doesn't work?
i"m trying to trigger a dummy that shows the window is open or closed. Trying that with a Kerui D026 which has a 'normal' and 'alarm' status.
The Raamsensor 1 does its work. The dummy does not change status.
jellex87
Re: Blockly does not work with door contact and dummy
Post by jellex87 »
Anyone?
Dave21w
Domoticz version: Stable
Post by Dave21w »
You probably need to change the alarm and normal values to text values, use the light green box option and type the status between the quotes like this:-
jellex87
Post by jellex87 »
Thanks for your advice. It works for 50%. See my script. The Dummy light goes on when the sensor says "Normal", but does not turn off when status is "Alarm". Is "Alarm" maybe the wrong key word?
script raam.jpg (66.32 KiB) Viewed 1035 times
jellex87
Post by jellex87 »
Found the problem. The "alarm' status is wrong. instead it listens to 'Open' and 'Normal'.
Works like a charm.
Dave21w
Post by Dave21w »
Glad to hear it :)
