why does this one doesn't work?
i"m trying to trigger a dummy that shows the window is open or closed. Trying that with a Kerui D026 which has a 'normal' and 'alarm' status.
The Raamsensor 1 does its work. The dummy does not change status.
Blockly does not work with door contact and dummy Topic is solved
jellex87
- DSC05847%20-TIEL1%20kopie[1].jpg (37.61 KiB) Viewed 1387 times
Dave21w
- Domoticz version: Stable
Re: Blockly does not work with door contact and dummy
You probably need to change the alarm and normal values to text values, use the light green box option and type the status between the quotes like this:-
jellex87
Thanks for your advice. It works for 50%. See my script. The Dummy light goes on when the sensor says "Normal", but does not turn off when status is "Alarm". Is "Alarm" maybe the wrong key word?
- script raam.jpg (66.32 KiB) Viewed 1329 times
jellex87
Found the problem. The "alarm' status is wrong. instead it listens to 'Open' and 'Normal'.
Works like a charm.
Works like a charm.
Dave21w
Glad to hear it
