Dashticz Graphs - Features, Fixes & Updates
clinkadink
Re: Dashticz Graphs - Features, Fixes & Updates
Post by clinkadink »
There isn't a block param, but you can achieve this with custom data.
https://dashticz.readthedocs.io/en/beta ... the-y-axes
dennis075
Post by dennis075 »
clinkadink wrote: Sunday 03 May 2020 18:10 There isn't a block param, but you can achieve this with custom data.
I'm using custom data, for example:
blocks['my_graph2'] = {
	devices:[108],
	graph: ['bar'],
	legend: false,
	maxTicksLimit: 15,
	barWidth: 0.8,
	borderWidth: 13,
	height: 350,
	beginAtZero: true,
	datasetColors:['white'],
	custom : {
		"last day": {
				ylabels: ['kWh'],
				range: 'day',
				filter: '1 day',
				data: {
					Verbruik: 'd.v_108'
Tried some options from the link you provided but can't find the right one....
Jimster
Post by Jimster »
clinkadink wrote: Sunday 03 May 2020 10:33
Jimster wrote: Sunday 03 May 2020 10:31 Great! This works. Thanks a lot!
Thanks for confirming. I will get this fixed ;)
Hi clickadink, is May 4th also already visible in your graphs? Mine is showing May 4th with data from today I guess.
JanvdW
Post by JanvdW »
clinkadink wrote: Sunday 03 May 2020 9:41
JanvdW wrote: Saturday 02 May 2020 23:46 Yes, this piece of code is in the en_US.json
Ok, thanks for confirming. Is your Dashticz set to en_US or another language? If it is another language, please can you check that language file too.
When you hover over the graph, are there any errors in DevTools?
This is how my block looks:
blocks['all_zones'] = {
  title: 'Room Temperatures',
  devices: [6, 11, 12, 8, 14, 9, 15, 235, 10, 13],
  datasetColors: ['dodgerblue','chocolate', 'darkred', 'gold'],
  groupByDevice: true
It appears that my problem is caused by this parameter in the config:
groupByDevice: 'horizontal',
When I change this to your config setting it's displaying the setpoint values too.
groupByDevice: true
Jimster
Post by Jimster »
clinkadink wrote: Sunday 03 May 2020 10:25 OK, it seems that if the locale isn't set to en_US, it doesn't understand "Monday".
In js/components/graph.js line 639, if you change this ...
.day("Monday")
To this ...
.day(1)
It works for me with my language set to nl_NL. Please test and confirm, I will then raise the change.
I did some testing. When I change .day(1) to .day(2), the week will start on tuesday. But the graphs are exactly the same, it doesn't matter on which day the week starts.
JediMax
Post by JediMax »
Hallo!
Thank you for your work.
I start to use Dashticz beta and I have some problem.
1. I can't hide graph buttons. Code like
.block_multigraph_outside .graph_buttons {
  display: none
or
.block_multigraph_outside .graph_header {
  display: none;
not working.
2. Code
options: {
        	scales: {
            		yAxes: [{
                		ticks: {
                    		min: 45,
                    		max: 55
on beta not working, but work on non-beta.
3. I try to add camera view. [---SOLVED---]
Code like
frames.camera123 = {
	frameurl: "http://192.168.1.150/cgi-bin/snapshot.cgi?loginuse=domoticz&loginpas=Domo1234?channel=0",
	height: 320, //height of the block in pixels
	width: 6,
	refresh: 3000
working, but without refresh.
But this
blocks['camera_1'] = {
        type: 'camera',
        image: 'http://192.168.1.150/cgi-bin/snapshot.cgi?loginuse=domoticz&loginpas=Domo1234?channel=0',
        refresh: 3000,
        width: 12,
	height: '300px'
not working at all.[---SOLVED---]
4. Sometimes I see black sircles near left-bottom corner of graphs.
Can you help me? What I do wrong?
nfuse
Post by nfuse »
JediMax wrote: Thursday 07 May 2020 12:07 Hallo!
  display: none
not working.
2. Code
options: {
        	scales: {
            		yAxes: [{
                		ticks: {
                    		min: 45,
                    		max: 55
3. I try to add camera view. Code like
	width: 6,
	refresh: 3000
But this
        type: 'camera',
        refresh: 3000,
        width: 12,
	height: '300px'
not working at all.
this works for me
blocks['frontdoor_cam'] = {
   type: 'camera',
   imageUrl: 'http://192.168.2.9:8080/camsnapshot.jpg?idx=1',
   videoUrl: 'http://192.168.2.9:8080/camsnapshot.jpg?idx=1',
   refresh: 1000,
   width: 12,
   height: 355
the only thing not working is the fullscreen image when i click the image (no streaming video)
docker with sonos http api / mosquitto / zigbee2mqtt assistant / portainer / dashticz / nodeJS on windows with Zigbee2Mqtt, and some flask builds of my own
JediMax
Post by JediMax »
nfuse wrote: Thursday 07 May 2020 13:17
this works for me
   type: 'camera',
   refresh: 1000,
   width: 12,
   height: 355
This code works for me too. Thank you.
Jimster
Post by Jimster »
I have a strange issue with my water meter graph.
I have different views, 6h, 24h and also month, week etc.
The 24h view doesn't show the bars, the tooltip shows a value. But when I change the graph to line, the line is visible.
The 6h view also behaves strange. The bars are visible, but when a new day starts, the bars dissapears. After 6AM in the morning, they appear again.
Output from the debug button:
  "mountPoint": "#block_47",
  "block": {
    "width": 12,
    "datasetColors": [
      "lightblue"
    "barWidth": 0.9,
    "beginAtZero": true,
    "borderDash": [],
    "borderWidth": 2,
    "buttonsBorder": "white",
    "buttonsColor": "black",
    "buttonsFill": "white",
    "buttonsIcon": "#686868",
    "buttonsMarginX": 2,
    "buttonsMarginY": 0,
    "buttonsPadX": 6,
    "buttonsPadY": 2,
    "buttonsRadius": 0,
    "buttonsShadow": false,
    "buttonsSize": 14,
    "buttonsText": false,
    "cartesian": "linear",
    "custom": {
      "6u": {
        "range": "day",
        "filter": "6 hours",
        "data": {
          "verbruik": "d.v_126*100"
      "24u": {
        "range": "day",
        "filter": "24 hours",
        "data": {
      "Mnd": {
        "range": "month",
        "filter": "month",
        "data": {
          "verbruik": "d.v_126*1000"
      "Jr/wk": {
        "range": "year",
        "filter": "year",
        "groupBy": "week",
        "aggregate": "sum",
        "data": {
      "Jr/mnd": {
        "range": "year",
        "filter": "year",
        "groupBy": "month",
        "aggregate": "sum",
        "data": {
    "customHeader": false,
    "debugButton": "true",
    "displayFormats": false,
    "drawOrderDay": false,
    "drawOrderLast": false,
    "drawOrderMonth": false,
    "flash": false,
    "format": true,
    "gradients": false,
    "graph": "bar",
    "graphTypes": false,
    "groupBy": false,
    "groupByDevice": false,
    "height": "250px",
    "iconColour": "grey",
    "interval": 1,
    "legend": false,
    "lineFill": false,
    "lineTension": 0.1,
    "maxTicksLimit": null,
    "method": 1,
    "pointBorderColor": [
      "grey"
    "pointBorderWidth": 0,
    "pointRadius": 0,
    "pointStyle": false,
    "range": "initial",
    "refresh": 300,
    "reverseTime": false,
    "sortDevices": false,
    "spanGaps": false,
    "stacked": false,
    "title": "Water",
    "tooltiptotal": false,
    "zoom": false,
    "devices": [
      126
    "key": "Water-graph"
  "key": "Water-graph",
  "name": "graph",
  "graphDevices": [
      "AddjMulti": 1,
      "AddjMulti2": 1,
      "AddjValue": 0,
      "AddjValue2": 0,
      "BatteryLevel": 255,
      "Counter": "1416.612 m3",
      "CounterToday": "227 Liter",
      "CustomImage": 0,
      "Data": "1416.612 m3",
      "Description": "",
      "Favorite": 0,
      "HardwareID": 29,
      "HardwareName": "Unknown?",
      "HardwareType": "Unknown?",
      "HardwareTypeVal": 0,
      "HaveTimeout": false,
      "ID": "140CE",
      "LastUpdate": "2020-06-09 13:15:41",
      "Name": "Waterverbruik",
      "Notifications": "false",
      "PlanID": "0",
      "PlanIDs": [
        0
      "Protected": false,
      "ShowNotifications": true,
      "SignalLevel": "-",
      "SubType": "RFXMeter counter",
      "SwitchTypeVal": 2,
      "Timers": "false",
      "Type": "RFXMeter",
      "TypeImg": "counter",
      "Unit": 1,
      "Used": 1,
      "ValueQuantity": "",
      "ValueUnits": "",
      "XOffset": "0",
      "YOffset": "0",
      "idx": 126,
      "currentValue": "227 Liter",
      "name": "Waterverbruik",
      "sensor": "counter",
      "subtype": "RFXMeter counter",
      "title": "Waterverbruik",
      "txtUnit": "Liter",
      "txtUnits": [],
      "type": "RFXMeter",
      "decimals": 0
  "decimals": 0,
  "graphIdx": "block_47",
  "lastRefreshTime": 1591701338,
  "range": "day",
  "title": "Water",
  "params": [
    "type=graph&sensor=counter&idx=126&range=day&method=1"
  "txtUnits": [
    "Liter"
  "data": {
    "result": [
        "d": "2020-06-08 13:20",
        "v_126": "0.000"
        "d": "2020-06-08 13:25",
        "v_126": "0.000"
        "d": "2020-06-08 13:30",
        "v_126": "0.000"
        "d": "2020-06-08 13:35",
        "v_126": "0.000"
        "d": "2020-06-08 13:40",
        "v_126": "0.000"
        "d": "2020-06-08 13:45",
        "v_126": "0.000"
        "d": "2020-06-08 13:50",
        "v_126": "0.000"
        "d": "2020-06-08 13:55",
        "v_126": "0.000"
        "d": "2020-06-08 14:00",
        "v_126": "0.000"
        "d": "2020-06-08 14:05",
        "v_126": "0.000"
        "d": "2020-06-08 14:10",
        "v_126": "0.000"
        "d": "2020-06-08 14:15",
        "v_126": "0.204"
        "d": "2020-06-08 14:20",
        "v_126": "0.252"
        "d": "2020-06-08 14:25",
        "v_126": "0.096"
        "d": "2020-06-08 14:30",
        "v_126": "0.000"
        "d": "2020-06-08 14:35",
        "v_126": "0.084"
        "d": "2020-06-08 14:40",
        "v_126": "0.000"
        "d": "2020-06-08 14:45",
        "v_126": "0.072"
        "d": "2020-06-08 14:50",
        "v_126": "0.060"
        "d": "2020-06-08 14:55",
        "v_126": "0.012"
        "d": "2020-06-08 15:00",
        "v_126": "0.000"
        "d": "2020-06-08 15:05",
        "v_126": "0.000"
        "d": "2020-06-08 15:10",
        "v_126": "0.024"
        "d": "2020-06-08 15:15",
        "v_126": "0.000"
        "d": "2020-06-08 15:20",
        "v_126": "0.000"
        "d": "2020-06-08 15:25",
        "v_126": "0.000"
        "d": "2020-06-08 15:30",
        "v_126": "0.000"
        "d": "2020-06-08 15:35",
        "v_126": "0.000"
        "d": "2020-06-08 15:40",
        "v_126": "0.024"
        "d": "2020-06-08 15:45",
        "v_126": "0.000"
        "d": "2020-06-08 15:50",
        "v_126": "0.000"
        "d": "2020-06-08 15:55",
        "v_126": "0.000"
        "d": "2020-06-08 16:00",
        "v_126": "0.072"
        "d": "2020-06-08 16:05",
        "v_126": "0.072"
        "d": "2020-06-08 16:10",
        "v_126": "0.000"
        "d": "2020-06-08 16:15",
        "v_126": "0.000"
        "d": "2020-06-08 16:20",
        "v_126": "0.000"
        "d": "2020-06-08 16:25",
        "v_126": "0.000"
        "d": "2020-06-08 16:30",
        "v_126": "0.000"
        "d": "2020-06-08 16:35",
        "v_126": "0.000"
        "d": "2020-06-08 16:40",
        "v_126": "0.000"
        "d": "2020-06-08 16:45",
        "v_126": "0.060"
        "d": "2020-06-08 16:50",
        "v_126": "0.000"
        "d": "2020-06-08 16:55",
        "v_126": "0.000"
        "d": "2020-06-08 17:00",
        "v_126": "0.000"
        "d": "2020-06-08 17:05",
        "v_126": "0.000"
        "d": "2020-06-08 17:10",
        "v_126": "0.144"
        "d": "2020-06-08 17:15",
        "v_126": "0.012"
        "d": "2020-06-08 17:20",
        "v_126": "0.060"
        "d": "2020-06-08 17:25",
        "v_126": "0.000"
        "d": "2020-06-08 17:30",
        "v_126": "0.000"
        "d": "2020-06-08 17:35",
        "v_126": "0.000"
        "d": "2020-06-08 17:40",
        "v_126": "0.000"
        "d": "2020-06-08 17:45",
        "v_126": "0.000"
        "d": "2020-06-08 17:50",
        "v_126": "0.000"
        "d": "2020-06-08 17:55",
        "v_126": "0.000"
        "d": "2020-06-08 18:00",
        "v_126": "0.000"
        "d": "2020-06-08 18:05",
        "v_126": "0.000"
        "d": "2020-06-08 18:10",
        "v_126": "0.000"
        "d": "2020-06-08 18:15",
        "v_126": "0.060"
        "d": "2020-06-08 18:20",
        "v_126": "0.000"
        "d": "2020-06-08 18:25",
        "v_126": "0.000"
        "d": "2020-06-08 18:30",
        "v_126": "0.000"
        "d": "2020-06-08 18:35",
        "v_126": "0.000"
        "d": "2020-06-08 18:40",
        "v_126": "0.084"
        "d": "2020-06-08 18:45",
        "v_126": "0.060"
        "d": "2020-06-08 18:50",
        "v_126": "0.000"
        "d": "2020-06-08 18:55",
        "v_126": "0.000"
        "d": "2020-06-08 19:00",
        "v_126": "0.024"
        "d": "2020-06-08 19:05",
        "v_126": "0.012"
        "d": "2020-06-08 19:10",
        "v_126": "0.033"
        "d": "2020-06-08 19:15",
        "v_126": "0.000"
        "d": "2020-06-08 19:20",
        "v_126": "0.000"
        "d": "2020-06-08 19:25",
        "v_126": "0.011"
        "d": "2020-06-08 19:30",
        "v_126": "0.024"
        "d": "2020-06-08 19:35",
        "v_126": "0.012"
        "d": "2020-06-08 19:40",
        "v_126": "0.000"
        "d": "2020-06-08 19:45",
        "v_126": "0.209"
        "d": "2020-06-08 19:50",
        "v_126": "0.384"
        "d": "2020-06-08 19:55",
        "v_126": "0.252"
        "d": "2020-06-08 20:00",
        "v_126": "0.022"
        "d": "2020-06-08 20:05",
        "v_126": "0.000"
        "d": "2020-06-08 20:10",
        "v_126": "0.000"
        "d": "2020-06-08 20:15",
        "v_126": "0.048"
        "d": "2020-06-08 20:20",
        "v_126": "0.036"
        "d": "2020-06-08 20:25",
        "v_126": "0.099"
        "d": "2020-06-08 20:30",
        "v_126": "0.000"
        "d": "2020-06-08 20:35",
        "v_126": "0.000"
        "d": "2020-06-08 20:40",
        "v_126": "0.000"
        "d": "2020-06-08 20:45",
        "v_126": "0.000"
        "d": "2020-06-08 20:50",
        "v_126": "0.000"
        "d": "2020-06-08 20:55",
        "v_126": "0.072"
        "d": "2020-06-08 21:00",
        "v_126": "0.012"
        "d": "2020-06-08 21:05",
        "v_126": "0.048"
        "d": "2020-06-08 21:10",
        "v_126": "0.060"
        "d": "2020-06-08 21:15",
        "v_126": "0.000"
        "d": "2020-06-08 21:20",
        "v_126": "0.000"
        "d": "2020-06-08 21:25",
        "v_126": "0.000"
        "d": "2020-06-08 21:30",
        "v_126": "0.000"
        "d": "2020-06-08 21:35",
        "v_126": "0.036"
        "d": "2020-06-08 21:40",
        "v_126": "0.000"
        "d": "2020-06-08 21:45",
        "v_126": "0.000"
        "d": "2020-06-08 21:50",
        "v_126": "0.000"
        "d": "2020-06-08 21:55",
        "v_126": "0.000"
        "d": "2020-06-08 22:00",
        "v_126": "0.000"
        "d": "2020-06-08 22:05",
        "v_126": "0.000"
        "d": "2020-06-08 22:10",
        "v_126": "0.000"
        "d": "2020-06-08 22:15",
        "v_126": "0.000"
        "d": "2020-06-08 22:20",
        "v_126": "0.000"
        "d": "2020-06-08 22:25",
        "v_126": "0.036"
        "d": "2020-06-08 22:30",
        "v_126": "0.000"
        "d": "2020-06-08 22:35",
        "v_126": "0.000"
        "d": "2020-06-08 22:40",
        "v_126": "0.000"
        "d": "2020-06-08 22:45",
        "v_126": "0.072"
        "d": "2020-06-08 22:50",
        "v_126": "0.000"
        "d": "2020-06-08 22:55",
        "v_126": "0.000"
        "d": "2020-06-08 23:00",
        "v_126": "0.000"
        "d": "2020-06-08 23:05",
        "v_126": "0.000"
        "d": "2020-06-08 23:10",
        "v_126": "0.012"
        "d": "2020-06-08 23:15",
        "v_126": "0.024"
        "d": "2020-06-08 23:20",
        "v_126": "0.024"
        "d": "2020-06-08 23:25",
        "v_126": "0.000"
        "d": "2020-06-08 23:30",
        "v_126": "0.000"
        "d": "2020-06-08 23:35",
        "v_126": "0.180"
        "d": "2020-06-08 23:40",
        "v_126": "0.000"
        "d": "2020-06-08 23:45",
        "v_126": "0.000"
        "d": "2020-06-08 23:50",
        "v_126": "0.000"
        "d": "2020-06-08 23:55",
        "v_126": "0.000"
        "d": "2020-06-09",
        "v_126": "0.000"
        "d": "2020-06-09 00:00",
        "v_126": "0.000"
        "d": "2020-06-09 00:05",
        "v_126": "0.000"
        "d": "2020-06-09 00:10",
        "v_126": "0.000"
        "d": "2020-06-09 00:15",
        "v_126": "0.000"
        "d": "2020-06-09 00:20",
        "v_126": "0.012"
        "d": "2020-06-09 00:25",
        "v_126": "0.144"
        "d": "2020-06-09 00:30",
        "v_126": "0.396"
        "d": "2020-06-09 00:35",
        "v_126": "0.228"
        "d": "2020-06-09 00:40",
        "v_126": "0.000"
        "d": "2020-06-09 00:45",
        "v_126": "0.000"
        "d": "2020-06-09 00:50",
        "v_126": "0.000"
        "d": "2020-06-09 00:55",
        "v_126": "0.000"
        "d": "2020-06-09 01:00",
        "v_126": "0.000"
        "d": "2020-06-09 01:05",
        "v_126": "0.000"
        "d": "2020-06-09 01:10",
        "v_126": "0.000"
        "d": "2020-06-09 01:15",
        "v_126": "0.000"
        "d": "2020-06-09 01:20",
        "v_126": "0.000"
        "d": "2020-06-09 01:25",
        "v_126": "0.000"
        "d": "2020-06-09 01:30",
        "v_126": "0.000"
        "d": "2020-06-09 01:35",
        "v_126": "0.000"
        "d": "2020-06-09 01:40",
        "v_126": "0.000"
        "d": "2020-06-09 01:45",
        "v_126": "0.000"
        "d": "2020-06-09 01:50",
        "v_126": "0.000"
        "d": "2020-06-09 01:55",
        "v_126": "0.000"
        "d": "2020-06-09 02:00",
        "v_126": "0.000"
        "d": "2020-06-09 02:05",
        "v_126": "0.000"
        "d": "2020-06-09 02:10",
        "v_126": "0.000"
        "d": "2020-06-09 02:15",
        "v_126": "0.000"
        "d": "2020-06-09 02:20",
        "v_126": "0.000"
        "d": "2020-06-09 02:25",
        "v_126": "0.000"
        "d": "2020-06-09 02:30",
        "v_126": "0.000"
        "d": "2020-06-09 02:35",
        "v_126": "0.000"
        "d": "2020-06-09 02:40",
        "v_126": "0.000"
        "d": "2020-06-09 02:45",
        "v_126": "0.000"
        "d": "2020-06-09 02:50",
        "v_126": "0.000"
        "d": "2020-06-09 02:55",
        "v_126": "0.000"
        "d": "2020-06-09 03:00",
        "v_126": "0.000"
        "d": "2020-06-09 03:05",
        "v_126": "0.000"
        "d": "2020-06-09 03:10",
        "v_126": "0.000"
        "d": "2020-06-09 03:15",
        "v_126": "0.000"
        "d": "2020-06-09 03:20",
        "v_126": "0.000"
        "d": "2020-06-09 03:25",
        "v_126": "0.000"
        "d": "2020-06-09 03:30",
        "v_126": "0.000"
        "d": "2020-06-09 03:35",
        "v_126": "0.000"
        "d": "2020-06-09 03:40",
        "v_126": "0.000"
        "d": "2020-06-09 03:45",
        "v_126": "0.000"
        "d": "2020-06-09 03:50",
        "v_126": "0.000"
        "d": "2020-06-09 03:55",
        "v_126": "0.000"
        "d": "2020-06-09 04:00",
        "v_126": "0.000"
        "d": "2020-06-09 04:05",
        "v_126": "0.000"
        "d": "2020-06-09 04:10",
        "v_126": "0.000"
        "d": "2020-06-09 04:15",
        "v_126": "0.000"
        "d": "2020-06-09 04:20",
        "v_126": "0.000"
        "d": "2020-06-09 04:25",
        "v_126": "0.000"
        "d": "2020-06-09 04:30",
        "v_126": "0.055"
        "d": "2020-06-09 04:35",
        "v_126": "0.132"
        "d": "2020-06-09 04:40",
        "v_126": "0.000"
        "d": "2020-06-09 04:45",
        "v_126": "0.000"
        "d": "2020-06-09 04:50",
        "v_126": "0.000"
        "d": "2020-06-09 04:55",
        "v_126": "0.000"
        "d": "2020-06-09 05:00",
        "v_126": "0.000"
        "d": "2020-06-09 05:05",
        "v_126": "0.000"
        "d": "2020-06-09 05:10",
        "v_126": "0.000"
        "d": "2020-06-09 05:15",
        "v_126": "0.000"
        "d": "2020-06-09 05:20",
        "v_126": "0.000"
        "d": "2020-06-09 05:25",
        "v_126": "0.000"
        "d": "2020-06-09 05:30",
        "v_126": "0.000"
        "d": "2020-06-09 05:35",
        "v_126": "0.000"
        "d": "2020-06-09 05:40",
        "v_126": "0.000"
        "d": "2020-06-09 05:45",
        "v_126": "0.000"
        "d": "2020-06-09 05:50",
        "v_126": "0.000"
        "d": "2020-06-09 05:55",
        "v_126": "0.000"
        "d": "2020-06-09 06:00",
        "v_126": "0.000"
        "d": "2020-06-09 06:05",
        "v_126": "0.000"
        "d": "2020-06-09 06:10",
        "v_126": "0.000"
        "d": "2020-06-09 06:15",
        "v_126": "0.000"
        "d": "2020-06-09 06:20",
        "v_126": "0.000"
        "d": "2020-06-09 06:25",
        "v_126": "0.000"
        "d": "2020-06-09 06:30",
        "v_126": "0.000"
        "d": "2020-06-09 06:35",
        "v_126": "0.000"
        "d": "2020-06-09 06:40",
        "v_126": "0.000"
        "d": "2020-06-09 06:45",
        "v_126": "0.000"
        "d": "2020-06-09 06:50",
        "v_126": "0.000"
        "d": "2020-06-09 06:55",
        "v_126": "0.000"
        "d": "2020-06-09 07:00",
        "v_126": "0.000"
        "d": "2020-06-09 07:05",
        "v_126": "0.000"
        "d": "2020-06-09 07:10",
        "v_126": "0.000"
        "d": "2020-06-09 07:15",
        "v_126": "0.000"
        "d": "2020-06-09 07:20",
        "v_126": "0.000"
        "d": "2020-06-09 07:25",
        "v_126": "0.000"
        "d": "2020-06-09 07:30",
        "v_126": "0.000"
        "d": "2020-06-09 07:35",
        "v_126": "0.000"
        "d": "2020-06-09 07:40",
        "v_126": "0.000"
        "d": "2020-06-09 07:45",
        "v_126": "0.000"
        "d": "2020-06-09 07:50",
        "v_126": "0.048"
        "d": "2020-06-09 07:55",
        "v_126": "0.024"
        "d": "2020-06-09 08:00",
        "v_126": "0.000"
        "d": "2020-06-09 08:05",
        "v_126": "0.012"
        "d": "2020-06-09 08:10",
        "v_126": "0.000"
        "d": "2020-06-09 08:15",
        "v_126": "0.000"
        "d": "2020-06-09 08:20",
        "v_126": "0.000"
        "d": "2020-06-09 08:25",
        "v_126": "0.000"
        "d": "2020-06-09 08:30",
        "v_126": "0.000"
        "d": "2020-06-09 08:35",
        "v_126": "0.000"
        "d": "2020-06-09 08:40",
        "v_126": "0.000"
        "d": "2020-06-09 08:45",
        "v_126": "0.000"
        "d": "2020-06-09 08:50",
        "v_126": "0.000"
        "d": "2020-06-09 08:55",
        "v_126": "0.000"
        "d": "2020-06-09 09:00",
        "v_126": "0.024"
        "d": "2020-06-09 09:05",
        "v_126": "0.000"
        "d": "2020-06-09 09:10",
        "v_126": "0.000"
        "d": "2020-06-09 09:15",
        "v_126": "0.000"
        "d": "2020-06-09 09:20",
        "v_126": "0.000"
        "d": "2020-06-09 09:25",
        "v_126": "0.176"
        "d": "2020-06-09 09:30",
        "v_126": "0.132"
        "d": "2020-06-09 09:35",
        "v_126": "0.096"
        "d": "2020-06-09 09:40",
        "v_126": "0.036"
        "d": "2020-06-09 09:45",
        "v_126": "0.120"
        "d": "2020-06-09 09:50",
        "v_126": "0.036"
        "d": "2020-06-09 09:55",
        "v_126": "0.000"
        "d": "2020-06-09 10:00",
        "v_126": "0.012"
        "d": "2020-06-09 10:05",
        "v_126": "0.000"
        "d": "2020-06-09 10:10",
        "v_126": "0.012"
        "d": "2020-06-09 10:15",
        "v_126": "0.000"
        "d": "2020-06-09 10:20",
        "v_126": "0.012"
        "d": "2020-06-09 10:25",
        "v_126": "0.000"
        "d": "2020-06-09 10:30",
        "v_126": "0.012"
        "d": "2020-06-09 10:35",
        "v_126": "0.000"
        "d": "2020-06-09 10:40",
        "v_126": "0.000"
        "d": "2020-06-09 10:45",
        "v_126": "0.000"
        "d": "2020-06-09 10:50",
        "v_126": "0.000"
        "d": "2020-06-09 10:55",
        "v_126": "0.000"
        "d": "2020-06-09 11:00",
        "v_126": "0.168"
        "d": "2020-06-09 11:05",
        "v_126": "0.048"
        "d": "2020-06-09 11:10",
        "v_126": "0.000"
        "d": "2020-06-09 11:15",
        "v_126": "0.072"
        "d": "2020-06-09 11:20",
        "v_126": "0.000"
        "d": "2020-06-09 11:25",
        "v_126": "0.000"
        "d": "2020-06-09 11:30",
        "v_126": "0.000"
        "d": "2020-06-09 11:35",
        "v_126": "0.024"
        "d": "2020-06-09 11:40",
        "v_126": "0.000"
        "d": "2020-06-09 11:45",
        "v_126": "0.000"
        "d": "2020-06-09 11:50",
        "v_126": "0.000"
        "d": "2020-06-09 11:55",
        "v_126": "0.036"
        "d": "2020-06-09 12:00",
        "v_126": "0.168"
        "d": "2020-06-09 12:05",
        "v_126": "0.192"
        "d": "2020-06-09 12:10",
        "v_126": "0.000"
        "d": "2020-06-09 12:15",
        "v_126": "0.000"
        "d": "2020-06-09 12:20",
        "v_126": "0.000"
        "d": "2020-06-09 12:25",
        "v_126": "0.012"
        "d": "2020-06-09 12:30",
        "v_126": "0.000"
        "d": "2020-06-09 12:35",
        "v_126": "0.000"
        "d": "2020-06-09 12:40",
        "v_126": "0.000"
        "d": "2020-06-09 12:45",
        "v_126": "0.000"
        "d": "2020-06-09 12:50",
        "v_126": "0.000"
        "d": "2020-06-09 12:55",
        "v_126": "0.060"
        "d": "2020-06-09 13:00",
        "v_126": "0.000"
        "d": "2020-06-09 13:05",
        "v_126": "0.168"
        "d": "2020-06-09 13:10",
        "v_126": "0.033"
        "d": "2020-06-09 13:15",
        "v_126": "0.000"
    "status": "OK",
    "title": "Graph day",
  "realrange": "day",
  "dataFilterCount": 24,
  "dataFilterUnit": "hours",
  "groupBy": false,
  "customRange": true,
  "customRangeName": "6u",
  "graphConfig": {
    "range": "day",
    "data": {
  "keys": [
    "v"
  "ykeys": [
    "verbruik"
  "txtUnit": "Liter",
  "ylabels": [
    "Liter"
  "chartctx": "graphoutput_block_47",
  "_width": 420.656,
  "loadingTooltip": false
[code]
clinkadink
Jimster wrote: Tuesday 09 June 2020 13:06 Output from the debug button:
	"ActTime" : 1591700828,
	"AstrTwilightEnd" : "00:00",
	"AstrTwilightStart" : "00:00",
	"CivTwilightEnd" : "22:46",
	"CivTwilightStart" : "04:36",
	"DayLength" : "16:35",
	"NautTwilightEnd" : "23:59",
	"NautTwilightStart" : "03:22",
	"ServerTime" : "2020-06-09 13:07:08",
	"SunAtSouth" : "13:41",
	"Sunrise" : "05:23",
	"Sunset" : "21:58",
	"app_version" : "2020.2",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"Counter" : "1416.612 m3",
			"CounterToday" : "227 Liter",
			"CustomImage" : 0,
			"Data" : "1416.612 m3",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 29,
			"HardwareName" : "Unknown?",
			"HardwareType" : "Unknown?",
			"HardwareTypeVal" : 0,
			"HaveTimeout" : false,
			"ID" : "140CE",
			"LastUpdate" : "2020-06-09 13:05:55",
			"Name" : "Waterverbruik",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "RFXMeter counter",
			"SwitchTypeVal" : 2,
			"Timers" : "false",
			"Type" : "RFXMeter",
			"TypeImg" : "counter",
			"Unit" : 1,
			"Used" : 1,
			"ValueQuantity" : "",
			"ValueUnits" : "",
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "126"
	"status" : "OK",
	"title" : "Devices"
Thats not the debugButton. See here: https://www.domoticz.com/forum/viewtopi ... on#p237106
Jimster
Post by Jimster »
clinkadink wrote: Tuesday 09 June 2020 13:12
	"Sunset" : "21:58",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"CustomImage" : 0,
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 29,
			"ID" : "140CE",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Timers" : "false",
			"Unit" : 1,
			"Used" : 1,
			"ValueUnits" : "",
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "126"
	"status" : "OK",
	"title" : "Devices"
Something went wrong with copy-paste. Changed it now.
Droid
Post by Droid »
How can I change the text colors of the x and y axis?
Im working on a light theme, but I can't find that..
clinkadink
Jimster wrote: Tuesday 09 June 2020 13:06 The 24h view doesn't show the bars, the tooltip shows a value. But when I change the graph to line, the line is visible.
Hi Jimster, apologies for the delay in responding - things have been manic at work. I have created a dummy water meter (RFX meter) and added your block. I cannot replicate this. The graph correctly displays bars for each range.
clinkadink
Droid wrote: Saturday 20 June 2020 8:52 How can I change the text colors of the x and y axis?
Do you mean the axis labels or ticks? I am guessing both. Currently there is no method to change these. They are drawn as part of the graph canvas. I will see what I can do to provide this capability.
Droid
Post by Droid »
clinkadink wrote: Saturday 20 June 2020 10:20
Yeah both... I can pratically change all colors, except those.
On a white background, white text doesn't show :)
clinkadink
Droid wrote: Saturday 20 June 2020 10:35 Yeah both... I can pratically change all colors, except those.
This is now been added to the latest beta.
fontColor: 'black',    // default is white
Let me know how you get on ;)
Jimster
Post by Jimster »
clinkadink wrote: Saturday 20 June 2020 9:37
Hi clickadink, as far as I remember, it worked the first day. Can you check if it still works for you the next days?
clinkadink
Jimster wrote: Sunday 21 June 2020 13:01 Hi clickadink, as far as I remember, it worked the first day. Can you check if it still works for you the next days?
Yes, it still shows the same graph today, same as above. But don't forget, I am using a dummy device, with no data.
Droid
Post by Droid »
clinkadink wrote: Saturday 20 June 2020 13:01
Thanks, I haven't been able to test it yet.
I first got my Dashboards set up... now I'll probably start on my light theme
webrazor
Post by webrazor »
I updated dashticz to version 3.5 but now all the graph dont show any bar/line anymore:
The standard graph works when i click on the button:
But the custom graph is empty, it show total in left top corner:
Here is the code for graph:
blocks['graph_5'] = {
	height:	['210px'],
	graph: ['bar','bar'],
    custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
                usage: 'd.v+d.v2',
                generation: '-d.r1-d.r2'
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
                usage: 'd.v+d.v2',
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
                usage: 'd.v+d.v2',
    legend: false,
    datasetColors:['white','white']
