With scriptVersion = '0.201911091100' no more errors
Get weather data from LAN based ObserverIP PWS [Solved]
Re: Get weather data from LAN based ObserverIP PWS
eddieb
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
domopat24
Hello
first thank you for this dzvents, I am a beginner domoticz and I installed the last version.
I have a little difference for the wind.
The speed are not the same in the different widgets compared to the livedata.htm page ????
Domoticz Version: 4.10717
Last edited by domopat24 on Tuesday 17 December 2019 17:01, edited 5 times in total.
eddieb
Wind is changing rapidly, it depends on the exact moment of measurment if livedata and the probe match ...
It almost matches here, the speed and direction changed in livedata while taking snapshots. livedata changes almost every second while the dzevent probe runs every 5 min ...
running domoticz 4.11570 here
domopat24
I have changed the link of my screenshots
In the dzvent script the update is every 5 minutes.
I have take the screenshots under 5 minutes and in 2 widgets custom sensor the data are good.
The all widgets has the same time.
A new sreenshot with widgets and devices, all data are good except Speed and Gust in Wind widget
Last edited by domopat24 on Tuesday 17 December 2019 16:59, edited 1 time in total.
- waaren
Can you please try and change the x-as of the windspeed and gust devices to m/sec as descibed in the comments of the script ?domopat24 wrote: Tuesday 17 December 2019 15:39 A new sreenshot with widgets and devices, all data are good except Speed and Gust in Wind widget
And please post images as attached ones and not as links. The images in these links will be gone at a certain time in future and then your postings will no longer make sense.
Thx
domopat24
OK for the link
but the wind data in the weh page livedata.htm of my weatherstation are in Km/h, it is necessary to put m/s in weatherstation?change the x-as of the windspeed and gust devices to m/sec
Toulon7559
- Domoticz version: <2025
Perhaps the idea behind this 'sniffer-function' is another solution for this type of case:
https://github.com/matthewwall/weewx-interceptor
Lebo2d9
- Domoticz version: L stab
Hi Warren,
I used the interceptWH2600 code of allan-gam but the latest,time I had a lot of problems with it. I found this tread and i have implemented it.
For now it is working without any problems
Thanks for this solution.
Koen Deschepper
Koen Deschepper
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
eddieb
Hi Koen
nice to hear it works for you to.
Please tell us your exact hardware and current firmware ?
I am running a conrad WH2600 running ambientweather 4.5.7
Eddie
Eddie
Lebo2d9
Hi Eddie,
I have also the Conrad WH2600, I did a firmware to the latest abientweather (don't remember the version), but that one wasn't working.
The reciever was always loosing the connection with the outdoorstation.
Now i'm running ambient weather observerIP 1.0 version 1.0.9
For the moment I'me trying to get the battery status also
Koen
Koen
More to come
More to come
eddieb
Hi Koen,
I am not familiar with that 1.0.9 version.
I am running Ambientweather 4.5.7 on the observerip for about a year now and it is working fine
The battery status is in de live.htm page and should be easy to get, but in what domoticz sensor are you going to set it ?
Eddie
Eddie
Quark0ne
- Domoticz version: 3.0.8
Good Morning,
I'm getting the following code issue. Could I have some help?
lua: ambiantweather.lua:256: ambiguous syntax (function call x new statement) near '('
>Exit code: 1
if wind ~= nil then wind.updateWind
Line 256 -> (
fields.windDirection,
windDirectionName(fields.windDirection),
fields.windSpeed,
fields.windGust,
fields.outdoorTemperature,
windChill(fields.windSpeed, fields.outdoorTemperature)
) end
Picture Link to my /livedata.htm
https://ibb.co/MP08RQj
or you can get to the live date from here: http://q0ne.dyndns.org/livedata.htm
The Weather staion is an Aercus Weather Sleuth : Wh2600, but now with AmbientWeather 4.6.1 firmware as its stable, version 2.2 on Aercus was dropping out all the time.
Thank you
Paul
>Exit code: 1
Line 256 -> (
fields.windSpeed,
fields.windGust,
) end
Thank you
Paul
eddieb
Hi, I guess @waaren should be able to help here ...
- waaren
Maybe but there is no real log, no version information and the error code is not a dzVents one. So not much to work on.
Lebo2d9
Hi, for the moment my weatherstation is no longer responding to the http requests. But is is still sending its data to wunderground. As i'm not at home i can't reboot my weatherstation. So I'm now reading again the values via the wunderground api...
More to come
More to come
eddieb
Sometimes I have the problem that the ObserverIP station becomes unresponsive.
To prevent that I have a timed switch between te power supply and power cycle the ObserverIP every 24h ...
eddieb wrote: Monday 13 July 2020 12:30 Sometimes I have the problem that the ObserverIP station becomes unresponsive.
This interests me greatly because I have the same concerns.
Could you tell me what you did
Thank you
eddieb
I used a sonoff switch in the powerline of the ObserverIP and switch that off for 3 minutes at 04:00 every day ...Doudy wrote: Saturday 17 October 2020 16:38 This interests me greatly because I have the same concerns.
Could you tell me what you did![]()
Thank you
