Zigbee2mqtt network map
ak97
- Domoticz version: latest
Simple network map for zigbee2mqtt plugin using custom template page
https://github.com/kovainfo/Domoticz-zi ... etwork-map
Re: Zigbee2mqtt network map
Nice. I have to get a workaround because 2020.1 does not work for me (yet) because of Zwave problems.
ak97
This solution should work on previous versions of Domoticz, but I did not check)EddyG wrote: Sunday 05 April 2020 13:04 Nice. I have to get a workaround because 2020.1 does not work for me (yet) because of Zwave problems.
Bigted
- Domoticz version: 2020.1
Domoticz 4.10717
I can see raw.json gets populated
However the custom panel under Zigbee is blank
ak97
Absolute paths are specified in the template and script. are they right?Bigted wrote: Sunday 05 April 2020 13:47 Domoticz 4.10717
eleutscher
I did also the install and facing same problem as Bigted.
Zigbee, KAKU, Hue, Google, Honeywell, MotionEye, Telegram, Tasmota, Shelly, IFTTT, etc
ak97
What OS and platform for Domoticz you use?
eleutscher
Domoticz v4.10935
Operating System: Raspbian GNU/Linux 9 (stretch)
Kernel: Linux 4.19.42-v7+
ak97
Do you have a file:
/home/pi/domoticz/www/js/jquery-3.4.1.min.js
may be this file is missing in Domoticz less than v2020?
eleutscher
I have this oneak97 wrote: Sunday 05 April 2020 14:15 Do you have a file:
jquery-3.3.1.min.js
so the 3.4.1 is indeed missing
ak97
ok! that's it!
try modify file in /templates/zigbeemap/zigbeemap.html
and change
and change
to:<script type="text/javascript" src="/js/jquery-3.4.1.min.js"></script>
<script type="text/javascript" src="/js/jquery-3.3.1.min.js"></script>
eleutscher
Yep, I have images now! Great.ak97 wrote: Sunday 05 April 2020 14:20 ok! that's it!
and changeto:<script type="text/javascript" src="/js/jquery-3.4.1.min.js"></script><script type="text/javascript" src="/js/jquery-3.3.1.min.js"></script>
But.... I only see the orginal sensors. Your sensors. How do I get my sensors?
ak97
1. Mosquitto clients are installed?
2. dzVents support is enabled in Domoticz?
3. you must create dzVents script from readme:
customEvents = {
'CreateZigbeeMap' -- event triggered by emitEvent
data = {},
logger = {},
execute = function(domoticz, triggeredItem)
function SendCommand()
cmd = "/home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh"
domoticz.utils.osExecute(cmd)
if (triggeredItem.isCustomEvent) then
domoticz.utils._.print(triggeredItem.data)
SendCommand()
ak97
may be need add eXecute attribute for /home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh:
chmod +x /home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh-
Bigted
That solved the issue for meak97 wrote: Sunday 05 April 2020 14:20 ok! that's it!
eleutscher
1. Yesak97 wrote: Sunday 05 April 2020 14:32 1. Mosquitto clients are installed?
}[/code]
2. Yes
3. Maybe stupid question
Where should the file be located?
a. /home/pi/domoticz/scripts/dzVents/scripts or
b. /home/pi/domoticz/scripts/dzVents/generated_scripts
and what is the extension?
a. lua
b. dzvents
Thanks for your time/help
ak97
1. Open Domoticz web-interfaceeleutscher wrote: Sunday 05 April 2020 14:511. Yesak97 wrote: Sunday 05 April 2020 14:32 1. Mosquitto clients are installed?
}[/code]
2. Yes
a. lua
b. dzvents
2. Setup -> More Options -> Events
3. Create dzVents envent
4. Copy&Paste content of script
eleutscher
[/quote]
That is what I did. But still no luck. Could it be because ! am still on dzVents version: 2.4.24?
ak97
Here is what I found:eleutscher wrote: Sunday 05 April 2020 18:50 That is what I did. But still no luck. Could it be because ! am still on dzVents version: 2.4.24?
https://www.domoticz.com/wiki/Domoticz_ ... ents_3.0.0
Yes, dzVents must be a 3.0 and above
Maybe there is another way to call the script to create a network map, but I did not think about it. generating an event when opening a page is the easiest solution for me ...
I am on version 4.10717 and in that version CustomEvents where not implemented yet.
