Zigbee2mqtt network map
ak97
Domoticz version: latest
Post by ak97 »
Simple network map for zigbee2mqtt plugin using custom template page
https://github.com/kovainfo/Domoticz-zi ... etwork-map
EddyG
Re: Zigbee2mqtt network map
Post by EddyG »
Nice. I have to get a workaround because 2020.1 does not work for me (yet) because of Zwave problems.
ak97
Post by ak97 »
EddyG wrote: Sunday 05 April 2020 13:04 Nice. I have to get a workaround because 2020.1 does not work for me (yet) because of Zwave problems.
This solution should work on previous versions of Domoticz, but I did not check)
Bigted
Domoticz version: 2020.1
Post by Bigted »
Domoticz 4.10717
I can see raw.json gets populated
However the custom panel under Zigbee is blank
ak97
Post by ak97 »
Bigted wrote: Sunday 05 April 2020 13:47 Domoticz 4.10717
Absolute paths are specified in the template and script. are they right?
eleutscher
Post by eleutscher »
I did also the install and facing same problem as Bigted.
Zigbee, KAKU, Hue, Google, Honeywell, MotionEye, Telegram, Tasmota, Shelly, IFTTT, etc
ak97
Post by ak97 »
What OS and platform for Domoticz you use?
eleutscher
ak97 wrote: Sunday 05 April 2020 14:07 What OS and platform for Domoticz you use?
Domoticz v4.10935
Operating System: Raspbian GNU/Linux 9 (stretch)
Kernel: Linux 4.19.42-v7+
ak97
Post by ak97 »
Do you have a file:
/home/pi/domoticz/www/js/jquery-3.4.1.min.js
may be this file is missing in Domoticz less than v2020?
eleutscher
ak97 wrote: Sunday 05 April 2020 14:15 Do you have a file:
I have this one
jquery-3.3.1.min.js
so the 3.4.1 is indeed missing
ak97
Post by ak97 »
ok! that's it!
try modify file in /templates/zigbeemap/zigbeemap.html
and change
<script type="text/javascript" src="/js/jquery-3.4.1.min.js"></script>
to:
<script type="text/javascript" src="/js/jquery-3.3.1.min.js"></script>
eleutscher
ak97 wrote: Sunday 05 April 2020 14:20 ok! that's it!
and change
to:
Yep, I have images now! Great.
But.... I only see the orginal sensors. Your sensors. How do I get my sensors? :-)
ak97
Post by ak97 »
1. Mosquitto clients are installed?
2. dzVents support is enabled in Domoticz?
3. you must create dzVents script from readme:
		customEvents = {
			'CreateZigbeeMap' -- event triggered by emitEvent
	data = {},
	logger = {},
	execute = function(domoticz, triggeredItem)
	    function SendCommand()
            cmd = "/home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh"
            domoticz.utils.osExecute(cmd)
		if (triggeredItem.isCustomEvent) then
			domoticz.utils._.print(triggeredItem.data)
			SendCommand()
ak97
Post by ak97 »
may be need add eXecute attribute for /home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh:
chmod +x /home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh
Bigted
Post by Bigted »
and change
to:
That solved the issue for me
eleutscher
ak97 wrote: Sunday 05 April 2020 14:32 1. Mosquitto clients are installed?
}[/code]
1. Yes
2. Yes
3. Maybe stupid question :-)
Where should the file be located?
a. /home/pi/domoticz/scripts/dzVents/scripts or
b. /home/pi/domoticz/scripts/dzVents/generated_scripts
and what is the extension?
a. lua
b. dzvents
Thanks for your time/help
ak97
Post by ak97 »
eleutscher wrote: Sunday 05 April 2020 14:51
}[/code]
1. Yes
2. Yes
a. lua
b. dzvents
1. Open Domoticz web-interface
2. Setup -> More Options -> Events
3. Create dzVents envent
4. Copy&Paste content of script :)
eleutscher
ak97 wrote: Sunday 05 April 2020 15:04
[/quote]
That is what I did. But still no luck. Could it be because ! am still on dzVents version: 2.4.24?
ak97
Post by ak97 »
eleutscher wrote: Sunday 05 April 2020 18:50 That is what I did. But still no luck. Could it be because ! am still on dzVents version: 2.4.24?
Here is what I found:
https://www.domoticz.com/wiki/Domoticz_ ... ents_3.0.0
Yes, dzVents must be a 3.0 and above
Maybe there is another way to call the script to create a network map, but I did not think about it. generating an event when opening a page is the easiest solution for me ...
EddyG
Post by EddyG »
ak97 wrote: Sunday 05 April 2020 13:10
I am on version 4.10717 and in that version CustomEvents where not implemented yet.
