Compatibility Zigate and Synology nas Topic is solved
keros
Re: Compatibility Zigate and Synology nas
Post by keros »
Here are some new log :
27 13:40:22.225 Status: (Zigate) Installer Version Number: 030f
2019-07-27 13:40:22.327 Status: (Zigate) Accepting new Hardware: On
2019-07-27 13:40:22.581 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 13:40:22.581 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 13:40:31.851 Status: (Zigate) Zigate set to Certification : CE
2019-07-27 13:40:31.852 Status: (Zigate) Start Web Server connection
2019-07-27 13:40:31.903 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-07-27 13:40:31.903 Status: (Zigate) Web backend for Web User Interface Name: 'Zigate Server Connection', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '', Port: '9440', Baud: -1, Connected: False, Parent: 'None'
2019-07-27 13:40:31.903 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 13:40:32.659 (Zigate) checkPluginVersion - Available Plugin Versions are, stable: 4.3.5 , beta: 4.4.14
2019-07-27 13:40:32.659 (Zigate) checkPluginVersion - Available Firmware Version is, Major: 0003 , Minor: 031a
2019-07-27 13:40:32.659 (Zigate) checkPluginUpdate - 4.6.001 4.4.14
2019-07-27 13:40:32.659 (Zigate) checkFirmwareUpdate - Firmware update available
2019-07-27 13:40:32.659 Status: (Zigate) There is a newer Zigate Firmware version available
2019-07-27 13:45:22.284 Error: (Zigate) Transport is not connected, write directive to 'Zigate' ignored.
2019-07-27 13:45:24.889 Status: (Zigate) Reconnected after failure
2019-07-27 13:45:24.889 Status: (Zigate) Configure Permit To Join
2019-07-27 13:45:24.890 Status: (Zigate) Request Accepting new Hardware for 180 seconds
2019-07-27 13:45:24.890 Status: (Zigate) Trigger a Topology Scan
2019-07-27 13:45:24.891 Status: (Zigate) Trigger a Energy Level Scan
2019-07-27 13:45:24.891 Status: (Zigate) Network Energy Level Report: 0000
2019-07-27 13:45:24.891 Status: (Zigate) -----------------------------------------------
2019-07-27 13:45:24.891 Status: (Zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
2019-07-27 13:45:27.299 (Zigate) No Firmware Version received from Zigate
I stil cannot acces to the zigate web admin page and I don't understand why ?
When I unplug/replug the Wifi Zigate, I see the Wifi from the zigate (with the first letters of the mac adress) for one minute before it desepears . I think it change to my box network. But after that I stil canot access to it.
My zigate wifi firmware is ZiGate-WiFi v2.00 with esp-link v3.2.50-gfe4f565-dirty
Which thing do I have to update ?
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
pipiche
Post by pipiche »
What is domoticz version you are using ?
keros
Post by keros »
I'm on the lastest beta updated yesterday : 4.11031
pipiche
Post by pipiche »
keros wrote: Saturday 27 July 2019 14:15 I'm on the lastest beta updated yesterday : 4.11031
That explains your issue to get access to the Web Admin page of the plugin
That one is bugy the HTTP protocol doesn't work with plugin framework :-(
I had the issue yesterday and it is now fixed. ( 4.11033 is ok )
As the Zigate firmware is concerned, you are running firmware 3.0f and 3.1a is available. That is the Zigate firmware ( not the Wifi module).
To update the Zigate module, you need to remove the Wifi module and put the USB-TTL and then do the upgrade of the Module
keros
Post by keros »
Ok thanks Pipiche for the explanations. I'll update the zigbee module then.
For the moment Domoticz doesn't propose the 4.11033 update.
pipiche
Post by pipiche »
The firmware update to 3.1a is not a must. So no urgency
keros
Post by keros »
Too late, i allready moved the zibee module to the usb stick :D
keros
Post by keros »
Update done !!
2019-07-27 14:54:54.584 Status: (Zigate) Started.
2019-07-27 14:54:54.924 Status: (Zigate) Entering work loop.
2019-07-27 14:54:54.925 Status: (Zigate) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-07-27 14:54:54.936 Status: (Zigate) Zigate plugin beta-4.6.001 started
2019-07-27 14:54:54.949 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 14:54:54.949 [GCC 6.3.0 20170516]
2019-07-27 14:54:54.949 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 14:54:54.949 Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 14:54:54.949 Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 14:54:54.949 Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 14:54:54.949 Status: (Zigate) load PluginConf
2019-07-27 14:54:54.950 Status: (Zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-07-27 14:54:54.950 Status: (Zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-07-27 14:54:54.951 Status: (Zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-07-27 14:54:54.951 Status: (Zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-07-27 14:54:54.951 Status: (Zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-07-27 14:54:54.951 Status: (Zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-07-27 14:54:54.951 Status: (Zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-05.json
2019-07-27 14:54:54.951 Status: (Zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-07-27 14:54:54.951 Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 14:54:54.952 Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 14:54:54.971 Status: (Zigate) DeviceConf loaded
2019-07-27 14:54:54.971 Status: (Zigate) load ListOfDevice
2019-07-27 14:54:55.226 (Zigate) Permit Join status: 01
2019-07-27 14:54:55.226 (Zigate) ---> self.permitTojoin['Starttime']: 1564232095
2019-07-27 14:54:55.226 (Zigate) ---> Current time : 1564232095
2019-07-27 14:54:55.226 (Zigate) ---> self.Ping['Permit'] (prev) : None
2019-07-27 14:54:55.226 (Zigate) ---> self.Ping['Permit'] (new ) : On
2019-07-27 14:54:55.014 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 14:54:55.019 Status: (Zigate) Transport mode: Wifi
2019-07-27 14:54:55.019 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 14:54:55.070 Status: (Zigate) Configure Permit To Join
2019-07-27 14:54:55.070 Status: (Zigate) Request Accepting new Hardware for 180 seconds
2019-07-27 14:54:55.071 Status: (Zigate) Trigger a Topology Scan
2019-07-27 14:54:55.071 Status: (Zigate) Trigger a Energy Level Scan
2019-07-27 14:54:55.071 Status: (Zigate) Network Energy Level Report: 0000
2019-07-27 14:54:55.071 Status: (Zigate) -----------------------------------------------
2019-07-27 14:54:55.071 Status: (Zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
2019-07-27 14:54:55.124 Status: (Zigate) Major Version Num: 0003
2019-07-27 14:54:55.124 Status: (Zigate) Installer Version Number: 031a
2019-07-27 14:54:55.226 Status: (Zigate) Accepting new Hardware: On
2019-07-27 14:54:55.279 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 14:54:55.279 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 14:54:55.334 Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 14:55:04.954 Status: (Zigate) Zigate set to Certification : CE
2019-07-27 14:55:04.955 Status: (Zigate) Start Web Server connection
2019-07-27 14:55:05.204 (Zigate) checkPluginVersion - Available Plugin Versions are, stable: 4.3.5 , beta: 4.4.14
2019-07-27 14:55:05.205 (Zigate) checkPluginVersion - Available Firmware Version is, Major: 0003 , Minor: 031a
2019-07-27 14:55:05.205 (Zigate) checkPluginUpdate - 4.6.001 4.4.14
2019-07-27 14:55:05.006 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-07-27 14:55:05.006 Status: (Zigate) Web backend for Web User Interface Name: 'Zigate Server Connection', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '', Port: '9440', Baud: -1, Connected: False, Parent: 'None'
2019-07-27 14:55:05.006 Status: (Zigate) Plugin with Zigate firmware 031a correctly initialized
Wait and see ... 8-)
keros
Post by keros »
Domoticz updated to 3.11034
No errors for the moment.
Thank you Pipiche
keros
Post by keros »
I come back with some news : I have a few erros with connection failed but it comes back rapidly.
I think I can say that the problem is solved. Many thanks once again.
pipiche
Post by pipiche »
Great !
keros
Post by keros »
I still have some issues.
I oppend a new topic on https://easydomoticz.com/forum/viewtopi ... a6a#p71949 (in french)
frankwijers
Post by frankwijers »
twoenter wrote: Monday 24 June 2019 13:06 I have finished the dutch tutorial to install and configure the Zigate on a Synology NAS at my own blog.
https://www.twoenter.nl/blog/domotica/z ... cz-zigate/
Hi Twoenter,
I tried following your post to install Zigate, but I run into some trouble. Could you assist me?
I got to the part to git clone the plugin, but after a reset, I do not have the Zigate plugin available in Domoticz. Since this is my firts time trying this, I'm kinda lost.
pipiche
Post by pipiche »
frankwijers wrote: Wednesday 11 March 2020 22:45
Hi Twoenter,
Are you sure that you have uploaded a Domoticz version with Python ?
twoenter
Domoticz version: 4.10
Post by twoenter »
Hi Twoenter,
Have you installed the domoticz with python version like pipiche said? Because the plugin is written in python language you need to install the domoticz with python package for synology from jahdal.
If you have installed domoticz with python please tell us what's in your log when you start domoticz. Maybe there's a clue.
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
frankwijers
This weekend, I made a backup of Domoticz, uninstalled it and reinstalled the package with Python. Seems I installed the wrong one last time. It's working now.
