27 13:40:22.225 Status: (Zigate) Installer Version Number: 030f
2019-07-27 13:40:22.327 Status: (Zigate) Accepting new Hardware: On
2019-07-27 13:40:22.581 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 13:40:22.581 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 13:40:31.851 Status: (Zigate) Zigate set to Certification : CE
2019-07-27 13:40:31.852 Status: (Zigate) Start Web Server connection
2019-07-27 13:40:31.903 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-07-27 13:40:31.903 Status: (Zigate) Web backend for Web User Interface Name: 'Zigate Server Connection', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '', Port: '9440', Baud: -1, Connected: False, Parent: 'None'
2019-07-27 13:40:31.903 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 13:40:32.659 (Zigate) checkPluginVersion - Available Plugin Versions are, stable: 4.3.5 , beta: 4.4.14
2019-07-27 13:40:32.659 (Zigate) checkPluginVersion - Available Firmware Version is, Major: 0003 , Minor: 031a
2019-07-27 13:40:32.659 (Zigate) checkPluginUpdate - 4.6.001 4.4.14
2019-07-27 13:40:32.659 (Zigate) checkFirmwareUpdate - Firmware update available
2019-07-27 13:40:32.659 Status: (Zigate) There is a newer Zigate Firmware version available
2019-07-27 13:45:22.284 Error: (Zigate) Transport is not connected, write directive to 'Zigate' ignored.
2019-07-27 13:45:24.889 Status: (Zigate) Reconnected after failure
2019-07-27 13:45:24.889 Status: (Zigate) Configure Permit To Join
2019-07-27 13:45:24.890 Status: (Zigate) Request Accepting new Hardware for 180 seconds
2019-07-27 13:45:24.890 Status: (Zigate) Trigger a Topology Scan
2019-07-27 13:45:24.891 Status: (Zigate) Trigger a Energy Level Scan
2019-07-27 13:45:24.891 Status: (Zigate) Network Energy Level Report: 0000
2019-07-27 13:45:24.891 Status: (Zigate) -----------------------------------------------
2019-07-27 13:45:24.891 Status: (Zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
2019-07-27 13:45:27.299 (Zigate) No Firmware Version received from Zigate
When I unplug/replug the Wifi Zigate, I see the Wifi from the zigate (with the first letters of the mac adress) for one minute before it desepears . I think it change to my box network. But after that I stil canot access to it.
My zigate wifi firmware is ZiGate-WiFi v2.00 with esp-link v3.2.50-gfe4f565-dirty
