I changed one file so how do I force this update (and forgot to make a backupclinkadink wrote: Sunday 16 February 2020 14:05 There was an update to the latest beta this morning. It included tooltip styling.
*snip*
It is obviously still a beta, so any feedback is appreciated![]()
Multiple sources in one graph
- Sjonnie2017
- Domoticz version: Latest ß
Re: Multiple sources in one graph
YouLess Energy meter
- clinkadink
- Domoticz version: 2020.2
How are you normally updating?
Lokonli
git reset --hard HEAD
git pull
- clinkadink
The latest update contains the changes that you tested (plus the new toolTipStyle).
In other words, you shouldn't lose anything by updating.
- Sjonnie2017
I normally use "git pull" in the dashticz folder.
That seemed to do the trickLokonli wrote: Sunday 16 February 2020 14:33This will overwrite the changes you've made, but it will not remove new files you've created.Code: Select all
git reset --hard HEAD git pull
Haven't lost anything indeed. Tried the toolTipStyle parameter and got this in the graph on the dashboard (über coolclinkadink wrote: Sunday 16 February 2020 14:37 The latest update contains the changes that you tested (plus the new toolTipStyle).
The tooltips do not work in the popup graphs though but I think you didn't expect it to
Greetz,
Sjonnie
EDIT: The tooltips work on the multigraphs as well. Forgot to mention that
Last edited by Sjonnie2017 on Sunday 16 February 2020 15:07, edited 1 time in total.
- clinkadink
Great news, thanks!
No, they won't work in popups ... at the moment.
- Sjonnie2017
Looking at what you have achieved up til now I am sure you are going to fix that as well.clinkadink wrote: Sunday 16 February 2020 15:03 Great news, thanks!
Greetz,
Sjonnie
- Sjonnie2017
While I was using Dashticz and checked some graphs I noticed a little odd behavior. It seems that the tooltips parameter shows a large amount of digits behind the decimal separator for last month. It works well for all other measurements like Today and Last Hours but the last day of this month however...
Last month - today:
Last month - *not* today:
Refreshing/re-selecting makes no difference.
Greetz,
Sjonnie
Last month - today:
Greetz,
Sjonnie
- clinkadink
That's is the standard tooltips, not the new tooltips. Can you check your block config?
- Sjonnie2017
Sorry! You're right of course.
Added the new tooltip parameter to the blocks and all is working as expected now.
Greetz,
Sjonnie
Greetz,
Sjonnie
- clinkadink
Finally found the issue. Am fixing it now.Sjonnie2017 wrote: Sunday 16 February 2020 13:44 if I click on Last month twice it shows me kWh (eg. 15kWh). If I then select last hours, on first click it shows me kWh (eg. 2000 kWh) and after the second click I get W (eg. 2000 W). Same applies for Today. If I select Last Hours it shows me W as unit of measurement. If I then select Last Month the first time it shows me W (eg. 20 W) and after the second click it shows me kWh (20 kWh). It looks like the unit of measurement is not immediately updated if I switch between different time measurements.
P.S. toolTipStyle now working on Popups (on mine)
- clinkadink
There have been quite a few graph updates to the latest beta over the weekend.
Fixes:
https://github.com/Dashticz/dashticz/tree/beta
Tip 1: defined graph blocks do not require be named as "graph_idx" or "multigraph_idx" anymore. You can name them whatever you like.
Tip 2: all defined graph blocks must contain the devices parameter, e.g. devices: [123]
Tip 3: all undefined graphs (those without any block) should still be named as "graph_idx" (where idx is the idx of the device).
Fixes:
- Height can once again be set in the graph block, e.g. height: '300px'
- drawOrderLast, drawOrderDay, drawOrderMonth now correctly allows sorting the order of datasets per button (last, today, month)
- Users would often have to press the range button twice to show the correct ylabel - now fixed.
- The Legend order can now be changed by changing the order of the keys in the graph block config
- User can now display HTML graph tooltips instead of the standard ones, e.g. toolTipStyle: true
- The graph beta documentation has been updated to reflect the recent changes
- Users can now debug their graph by setting their graph's block config, e.g. debugButton: true
- HTML tooltips are now shown on Popups by default
- clinkadink
The latest update (this morning), includes the ability to add a debug button to your graph. To do this, add the following line to your graph's block config:
The update adds a button to the top right of the graph. When pressed, a dialog box is displayed with key information about each device and the data that has been generated to show the graph. Each device has a link, this takes you to page showing all data about each device within the graph, using Domoticz api. Across the top shows the original keys and the new keys (appended with the device idx). I am hoping that this will help us resolve any issues we may experience with any troublesome graphs
There are 3 buttons at the top of the debug window:
debugButton: trueThere are 3 buttons at the top of the debug window:
- DevTools button - press F12 on the keyboard and then click this to show the graph properties in Dev Tools
- Save button - click this to download your graph properties in JSON format. This will be helpful if you need support.
- Close button - to exit the debug window. Although clicking outside of the window does the same thing.
- Sjonnie2017
After all your hard work I just had to update and start testing. I added the debugButton = true parameter to the blocks. Everything else has been left 'as is'.
The code for electricity and gas:
You'll get used to my definition style (in time
The pictures:
No tool tips on popup gas:
Dashboard graphs on first load:
Popup electricity on first load:
Popup electricity Last Month after first load:
Popup electricity Today after selecting Last Month:
Popup electricity Last Hours after selecting Today
I am almost certain it won't help a bit but I have added the debug code for the electricity graph just to be sure:
HTH
Greetz,
Sjonnie
blocks[grafiek_elektra] = {}
blocks[grafiek_elektra]['title'] = 'Elektriciteit';
blocks[grafiek_elektra]['devices'] = [199];
blocks[grafiek_elektra]['width'] = 12;
blocks[grafiek_elektra]['height'] = '400px';
blocks[grafiek_elektra]['interval'] = 2;
blocks[grafiek_elektra]['graphTypes'] = ['v', 'v2'];
blocks[grafiek_elektra]['graph'] = 'line';
blocks[grafiek_elektra]['sortDevices'] = true;
blocks[grafiek_elektra]['toolTipStyle'] = true;
blocks[grafiek_elektra]['debugButton'] = true;
blocks[grafiek_elektra]['legend'] = {'v2_199': 'Dag', 'v_199': 'Nacht'}
blocks[grafiek_gas] = {}
blocks[grafiek_gas]['title'] = 'Gas';
blocks[grafiek_gas]['devices'] = [200];
blocks[grafiek_gas]['width'] = 12;
blocks[grafiek_gas]['height'] = '400px';
blocks[grafiek_gas]['interval'] = 2;
blocks[grafiek_gas]['toolTipStyle'] = true;
blocks[grafiek_gas]['debugButton'] = true;
blocks[grafiek_gas]['legend'] = {'v_200': 'Per Uur', 'c_200': 'Totaal'}The pictures:
"blockId": "block_33",
"block": {
"devices": [
199
"datasetColors": [
"red",
"yellow",
"blue",
"orange",
"green",
"purple"
"barWidth": 0.9,
"borderColors": [
"red",
"yellow",
"blue",
"orange",
"green",
"purple"
"borderDash": [],
"borderWidth": 2,
"buttonsBorder": "white",
"buttonsColor": "black",
"buttonsFill": "white",
"buttonsIcon": "#686868",
"buttonsMarginX": 2,
"buttonsMarginY": 0,
"buttonsPadX": 6,
"buttonsPadY": 2,
"buttonsRadius": 4,
"buttonsShadow": false,
"buttonsSize": 14,
"buttonsText": false,
"cartesian": "linear",
"custom": false,
"debugButton": true,
"displayFormats": false,
"drawOrderDay": false,
"drawOrderLast": false,
"drawOrderMonth": false,
"gradients": false,
"graph": "line",
"graphTypes": [
"v",
"v2"
"height": "400px",
"iconColour": "grey",
"interval": 2,
"legend": {
"v2_199": "Dag",
"v_199": "Nacht"
"lineFill": false,
"lineTension": 0.1,
"maxTicksLimit": null,
"method": 1,
"pointBorderColor": [
"grey"
"pointBorderWidth": 0,
"pointFillColor": [
"red",
"yellow",
"blue",
"orange",
"green",
"purple"
"pointRadius": 0,
"pointStyle": false,
"reverseTime": false,
"sortDevices": true,
"spanGaps": false,
"title": "Elektriciteit",
"toolTipStyle": true,
"width": 12
"currentValue": "7.50 kWh",
"currentValues": [
"7.50 kWh"
"customRange": false,
"data": {
"result": [
"d": "2020-02-16 18:30",
"v_199": "0",
"v2_199": "0"
"d": "2020-02-16 18:35",
"v_199": "2552",
"v2_199": "0"
"d": "2020-02-16 18:40",
"v_199": "2316",
"v2_199": "0"
"d": "2020-02-16 18:45",
"v_199": "3264",
"v2_199": "0"
"d": "2020-02-16 18:50",
"v_199": "2940",
"v2_199": "0"
"d": "2020-02-16 18:55",
"v_199": "3025",
"v2_199": "0"
"d": "2020-02-16 19:00",
"v_199": "2992",
"v2_199": "0"
"d": "2020-02-16 19:05",
"v_199": "2808",
"v2_199": "0"
"d": "2020-02-16 19:10",
"v_199": "1596",
"v2_199": "0"
"d": "2020-02-16 19:15",
"v_199": "792",
"v2_199": "0"
"d": "2020-02-16 19:20",
"v_199": "649",
"v2_199": "0"
"d": "2020-02-16 19:25",
"v_199": "684",
"v2_199": "0"
"d": "2020-02-16 19:30",
"v_199": "672",
"v2_199": "0"
"d": "2020-02-16 19:35",
"v_199": "627",
"v2_199": "0"
"d": "2020-02-16 19:40",
"v_199": "672",
"v2_199": "0"
"d": "2020-02-16 19:45",
"v_199": "684",
"v2_199": "0"
"d": "2020-02-16 19:50",
"v_199": "638",
"v2_199": "0"
"d": "2020-02-16 19:55",
"v_199": "744",
"v2_199": "0"
"d": "2020-02-16 20:00",
"v_199": "660",
"v2_199": "0"
"d": "2020-02-16 20:05",
"v_199": "732",
"v2_199": "0"
"d": "2020-02-16 20:10",
"v_199": "594",
"v2_199": "0"
"d": "2020-02-16 20:15",
"v_199": "756",
"v2_199": "0"
"d": "2020-02-16 20:20",
"v_199": "636",
"v2_199": "0"
"d": "2020-02-16 20:25",
"v_199": "660",
"v2_199": "0"
"d": "2020-02-16 20:30",
"v_199": "627",
"v2_199": "0"
"d": "2020-02-16 20:35",
"v_199": "696",
"v2_199": "0"
"d": "2020-02-16 20:40",
"v_199": "720",
"v2_199": "0"
"d": "2020-02-16 20:45",
"v_199": "708",
"v2_199": "0"
"d": "2020-02-16 20:50",
"v_199": "648",
"v2_199": "0"
"d": "2020-02-16 20:55",
"v_199": "594",
"v2_199": "0"
"d": "2020-02-16 21:00",
"v_199": "594",
"v2_199": "0"
"d": "2020-02-16 21:05",
"v_199": "624",
"v2_199": "0"
"d": "2020-02-16 21:10",
"v_199": "576",
"v2_199": "0"
"d": "2020-02-16 21:15",
"v_199": "756",
"v2_199": "0"
"d": "2020-02-16 21:20",
"v_199": "624",
"v2_199": "0"
"d": "2020-02-16 21:25",
"v_199": "561",
"v2_199": "0"
"d": "2020-02-16 21:30",
"v_199": "612",
"v2_199": "0"
"d": "2020-02-16 21:35",
"v_199": "660",
"v2_199": "0"
"d": "2020-02-16 21:40",
"v_199": "648",
"v2_199": "0"
"d": "2020-02-16 21:45",
"v_199": "516",
"v2_199": "0"
"d": "2020-02-16 21:50",
"v_199": "492",
"v2_199": "0"
"d": "2020-02-16 21:55",
"v_199": "480",
"v2_199": "0"
"d": "2020-02-16 22:00",
"v_199": "612",
"v2_199": "0"
"d": "2020-02-16 22:05",
"v_199": "492",
"v2_199": "0"
"d": "2020-02-16 22:10",
"v_199": "408",
"v2_199": "0"
"d": "2020-02-16 22:15",
"v_199": "420",
"v2_199": "0"
"d": "2020-02-16 22:20",
"v_199": "384",
"v2_199": "0"
"d": "2020-02-16 22:25",
"v_199": "297",
"v2_199": "0"
"d": "2020-02-16 22:30",
"v_199": "312",
"v2_199": "0"
"d": "2020-02-16 22:35",
"v_199": "408",
"v2_199": "0"
"d": "2020-02-16 22:40",
"v_199": "504",
"v2_199": "0"
"d": "2020-02-16 22:45",
"v_199": "468",
"v2_199": "0"
"d": "2020-02-16 22:50",
"v_199": "432",
"v2_199": "0"
"d": "2020-02-16 22:55",
"v_199": "374",
"v2_199": "0"
"d": "2020-02-16 23:00",
"v_199": "408",
"v2_199": "0"
"d": "2020-02-16 23:05",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-16 23:10",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-16 23:15",
"v_199": "576",
"v2_199": "0"
"d": "2020-02-16 23:20",
"v_199": "468",
"v2_199": "0"
"d": "2020-02-16 23:25",
"v_199": "420",
"v2_199": "0"
"d": "2020-02-16 23:30",
"v_199": "330",
"v2_199": "0"
"d": "2020-02-16 23:35",
"v_199": "300",
"v2_199": "0"
"d": "2020-02-16 23:40",
"v_199": "312",
"v2_199": "0"
"d": "2020-02-16 23:45",
"v_199": "312",
"v2_199": "0"
"d": "2020-02-16 23:50",
"v_199": "540",
"v2_199": "0"
"d": "2020-02-16 23:55",
"v_199": "363",
"v2_199": "0"
"d": "2020-02-17 00:00",
"v_199": "480",
"v2_199": "0"
"d": "2020-02-17 00:05",
"v_199": "468",
"v2_199": "0"
"d": "2020-02-17 00:10",
"v_199": "480",
"v2_199": "0"
"d": "2020-02-17 00:15",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-17 00:20",
"v_199": "552",
"v2_199": "0"
"d": "2020-02-17 00:25",
"v_199": "408",
"v2_199": "0"
"d": "2020-02-17 00:30",
"v_199": "319",
"v2_199": "0"
"d": "2020-02-17 00:35",
"v_199": "336",
"v2_199": "0"
"d": "2020-02-17 00:40",
"v_199": "360",
"v2_199": "0"
"d": "2020-02-17 00:45",
"v_199": "528",
"v2_199": "0"
"d": "2020-02-17 00:50",
"v_199": "420",
"v2_199": "0"
"d": "2020-02-17 00:55",
"v_199": "429",
"v2_199": "0"
"d": "2020-02-17 01:00",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-17 01:05",
"v_199": "420",
"v2_199": "0"
"d": "2020-02-17 01:10",
"v_199": "552",
"v2_199": "0"
"d": "2020-02-17 01:15",
"v_199": "408",
"v2_199": "0"
"d": "2020-02-17 01:20",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-17 01:25",
"v_199": "418",
"v2_199": "0"
"d": "2020-02-17 01:30",
"v_199": "480",
"v2_199": "0"
"d": "2020-02-17 01:35",
"v_199": "540",
"v2_199": "0"
"d": "2020-02-17 01:40",
"v_199": "360",
"v2_199": "0"
"d": "2020-02-17 01:45",
"v_199": "324",
"v2_199": "0"
"d": "2020-02-17 01:50",
"v_199": "312",
"v2_199": "0"
"d": "2020-02-17 01:55",
"v_199": "492",
"v2_199": "0"
"d": "2020-02-17 02:00",
"v_199": "432",
"v2_199": "0"
"d": "2020-02-17 02:05",
"v_199": "385",
"v2_199": "0"
"d": "2020-02-17 02:10",
"v_199": "492",
"v2_199": "0"
"d": "2020-02-17 02:15",
"v_199": "456",
"v2_199": "0"
"d": "2020-02-17 02:20",
"v_199": "420",
"v2_199": "0"
"d": "2020-02-17 02:25",
"v_199": "480",
"v2_199": "0"
"d": "2020-02-17 02:30",
"v_199": "561",
"v2_199": "0"
"d": "2020-02-17 02:35",
"v_199": "480",
"v2_199": "0"
"d": "2020-02-17 02:40",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-17 02:45",
"v_199": "418",
"v2_199": "0"
"d": "2020-02-17 02:50",
"v_199": "312",
"v2_199": "0"
"d": "2020-02-17 02:55",
"v_199": "324",
"v2_199": "0"
"d": "2020-02-17 03:00",
"v_199": "444",
"v2_199": "0"
"d": "2020-02-17 03:05",
"v_199": "451",
"v2_199": "0"
"d": "2020-02-17 03:10",
"v_199": "456",
"v2_199": "0"
"d": "2020-02-17 03:15",
"v_199": "516",
"v2_199": "0"
"d": "2020-02-17 03:20",
"v_199": "612",
"v2_199": "0"
"d": "2020-02-17 03:25",
"v_199": "429",
"v2_199": "0"
"d": "2020-02-17 03:30",
"v_199": "456",
"v2_199": "0"
"d": "2020-02-17 03:35",
"v_199": "492",
"v2_199": "0"
"d": "2020-02-17 03:40",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-17 03:45",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-17 03:50",
"v_199": "312",
"v2_199": "0"
"d": "2020-02-17 03:55",
"v_199": "363",
"v2_199": "0"
"d": "2020-02-17 04:00",
"v_199": "504",
"v2_199": "0"
"d": "2020-02-17 04:05",
"v_199": "336",
"v2_199": "0"
"d": "2020-02-17 04:10",
"v_199": "372",
"v2_199": "0"
"d": "2020-02-17 04:15",
"v_199": "480",
"v2_199": "0"
"d": "2020-02-17 04:20",
"v_199": "348",
"v2_199": "0"
"d": "2020-02-17 04:25",
"v_199": "385",
"v2_199": "0"
"d": "2020-02-17 04:30",
"v_199": "396",
"v2_199": "0"
"d": "2020-02-17 04:35",
"v_199": "360",
"v2_199": "0"
"d": "2020-02-17 04:40",
"v_199": "552",
"v2_199": "0"
"d": "2020-02-17 04:45",
"v_199": "374",
"v2_199": "0"
"d": "2020-02-17 04:50",
"v_199": "360",
"v2_199": "0"
"d": "2020-02-17 04:55",
"v_199": "384",
"v2_199": "0"
"d": "2020-02-17 05:00",
"v_199": "231",
"v2_199": "0"
"d": "2020-02-17 05:05",
"v_199": "444",
"v2_199": "0"
"d": "2020-02-17 05:10",
"v_199": "360",
"v2_199": "0"
"d": "2020-02-17 05:15",
"v_199": "516",
"v2_199": "0"
"d": "2020-02-17 05:20",
"v_199": "684",
"v2_199": "0"
"d": "2020-02-17 05:25",
"v_199": "588",
"v2_199": "0"
"d": "2020-02-17 05:30",
"v_199": "660",
"v2_199": "0"
"d": "2020-02-17 05:35",
"v_199": "732",
"v2_199": "0"
"d": "2020-02-17 05:40",
"v_199": "696",
"v2_199": "0"
"d": "2020-02-17 05:45",
"v_199": "576",
"v2_199": "0"
"d": "2020-02-17 05:50",
"v_199": "352",
"v2_199": "0"
"d": "2020-02-17 05:55",
"v_199": "744",
"v2_199": "0"
"d": "2020-02-17 06:00",
"v_199": "352",
"v2_199": "0"
"d": "2020-02-17 06:05",
"v_199": "456",
"v2_199": "0"
"d": "2020-02-17 06:10",
"v_199": "420",
"v2_199": "0"
"d": "2020-02-17 06:15",
"v_199": "864",
"v2_199": "0"
"d": "2020-02-17 06:20",
"v_199": "636",
"v2_199": "0"
"d": "2020-02-17 06:25",
"v_199": "418",
"v2_199": "0"
"d": "2020-02-17 06:30",
"v_199": "636",
"v2_199": "0"
"d": "2020-02-17 06:35",
"v_199": "372",
"v2_199": "0"
"d": "2020-02-17 06:40",
"v_199": "583",
"v2_199": "0"
"d": "2020-02-17 06:45",
"v_199": "341",
"v2_199": "0"
"d": "2020-02-17 06:50",
"v_199": "504",
"v2_199": "0"
"d": "2020-02-17 06:55",
"v_199": "468",
"v2_199": "0"
"d": "2020-02-17 07:00",
"v_199": "372",
"v2_199": "0"
"d": "2020-02-17 07:05",
"v_199": "0",
"v2_199": "516"
"d": "2020-02-17 07:10",
"v_199": "0",
"v2_199": "275"
"d": "2020-02-17 07:15",
"v_199": "0",
"v2_199": "360"
"d": "2020-02-17 07:20",
"v_199": "0",
"v2_199": "216"
"d": "2020-02-17 07:25",
"v_199": "0",
"v2_199": "360"
"d": "2020-02-17 07:30",
"v_199": "0",
"v2_199": "198"
"d": "2020-02-17 07:35",
"v_199": "0",
"v2_199": "360"
"d": "2020-02-17 07:40",
"v_199": "0",
"v2_199": "372"
"d": "2020-02-17 07:45",
"v_199": "0",
"v2_199": "407"
"d": "2020-02-17 07:50",
"v_199": "0",
"v2_199": "444"
"d": "2020-02-17 07:55",
"v_199": "0",
"v2_199": "324"
"d": "2020-02-17 08:00",
"v_199": "0",
"v2_199": "408"
"d": "2020-02-17 08:05",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 08:10",
"v_199": "0",
"v2_199": "396"
"d": "2020-02-17 08:15",
"v_199": "0",
"v2_199": "324"
"d": "2020-02-17 08:20",
"v_199": "0",
"v2_199": "480"
"d": "2020-02-17 08:25",
"v_199": "0",
"v2_199": "308"
"d": "2020-02-17 08:30",
"v_199": "0",
"v2_199": "408"
"d": "2020-02-17 08:35",
"v_199": "0",
"v2_199": "240"
"d": "2020-02-17 08:40",
"v_199": "0",
"v2_199": "308"
"d": "2020-02-17 08:45",
"v_199": "0",
"v2_199": "192"
"d": "2020-02-17 08:50",
"v_199": "0",
"v2_199": "336"
"d": "2020-02-17 08:55",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 09:00",
"v_199": "0",
"v2_199": "396"
"d": "2020-02-17 09:05",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 09:10",
"v_199": "0",
"v2_199": "384"
"d": "2020-02-17 09:15",
"v_199": "0",
"v2_199": "286"
"d": "2020-02-17 09:20",
"v_199": "0",
"v2_199": "312"
"d": "2020-02-17 09:25",
"v_199": "0",
"v2_199": "418"
"d": "2020-02-17 09:30",
"v_199": "0",
"v2_199": "336"
"d": "2020-02-17 09:35",
"v_199": "0",
"v2_199": "492"
"d": "2020-02-17 09:40",
"v_199": "0",
"v2_199": "308"
"d": "2020-02-17 09:45",
"v_199": "0",
"v2_199": "336"
"d": "2020-02-17 09:50",
"v_199": "0",
"v2_199": "180"
"d": "2020-02-17 09:55",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 10:00",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 10:05",
"v_199": "0",
"v2_199": "204"
"d": "2020-02-17 10:10",
"v_199": "0",
"v2_199": "456"
"d": "2020-02-17 10:15",
"v_199": "0",
"v2_199": "341"
"d": "2020-02-17 10:20",
"v_199": "0",
"v2_199": "456"
"d": "2020-02-17 10:25",
"v_199": "0",
"v2_199": "384"
"d": "2020-02-17 10:30",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 10:35",
"v_199": "0",
"v2_199": "396"
"d": "2020-02-17 10:40",
"v_199": "0",
"v2_199": "288"
"d": "2020-02-17 10:45",
"v_199": "0",
"v2_199": "324"
"d": "2020-02-17 10:50",
"v_199": "0",
"v2_199": "363"
"d": "2020-02-17 10:55",
"v_199": "0",
"v2_199": "348"
"d": "2020-02-17 11:00",
"v_199": "0",
"v2_199": "396"
"d": "2020-02-17 11:05",
"v_199": "0",
"v2_199": "330"
"d": "2020-02-17 11:10",
"v_199": "0",
"v2_199": "228"
"d": "2020-02-17 11:15",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 11:20",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 11:25",
"v_199": "0",
"v2_199": "204"
"d": "2020-02-17 11:30",
"v_199": "0",
"v2_199": "253"
"d": "2020-02-17 11:35",
"v_199": "0",
"v2_199": "420"
"d": "2020-02-17 11:40",
"v_199": "0",
"v2_199": "348"
"d": "2020-02-17 11:45",
"v_199": "0",
"v2_199": "348"
"d": "2020-02-17 11:50",
"v_199": "0",
"v2_199": "440"
"d": "2020-02-17 11:55",
"v_199": "0",
"v2_199": "312"
"d": "2020-02-17 12:00",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 12:05",
"v_199": "0",
"v2_199": "374"
"d": "2020-02-17 12:10",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 12:15",
"v_199": "0",
"v2_199": "253"
"d": "2020-02-17 12:20",
"v_199": "0",
"v2_199": "300"
"d": "2020-02-17 12:25",
"v_199": "0",
"v2_199": "360"
"d": "2020-02-17 12:30",
"v_199": "0",
"v2_199": "242"
"d": "2020-02-17 12:35",
"v_199": "0",
"v2_199": "240"
"d": "2020-02-17 12:40",
"v_199": "0",
"v2_199": "324"
"d": "2020-02-17 12:45",
"v_199": "0",
"v2_199": "192"
"d": "2020-02-17 12:50",
"v_199": "0",
"v2_199": "228"
"d": "2020-02-17 12:55",
"v_199": "0",
"v2_199": "420"
"d": "2020-02-17 13:00",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 13:05",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 13:10",
"v_199": "0",
"v2_199": "492"
"d": "2020-02-17 13:15",
"v_199": "0",
"v2_199": "348"
"d": "2020-02-17 13:20",
"v_199": "0",
"v2_199": "308"
"d": "2020-02-17 13:25",
"v_199": "0",
"v2_199": "408"
"d": "2020-02-17 13:30",
"v_199": "0",
"v2_199": "288"
"d": "2020-02-17 13:35",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 13:40",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 13:45",
"v_199": "0",
"v2_199": "396"
"d": "2020-02-17 13:50",
"v_199": "0",
"v2_199": "192"
"d": "2020-02-17 13:55",
"v_199": "0",
"v2_199": "242"
"d": "2020-02-17 14:00",
"v_199": "0",
"v2_199": "396"
"d": "2020-02-17 14:05",
"v_199": "0",
"v2_199": "252"
"d": "2020-02-17 14:10",
"v_199": "0",
"v2_199": "204"
"d": "2020-02-17 14:15",
"v_199": "0",
"v2_199": "240"
"d": "2020-02-17 14:20",
"v_199": "0",
"v2_199": "420"
"d": "2020-02-17 14:25",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 14:30",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 14:35",
"v_199": "0",
"v2_199": "300"
"d": "2020-02-17 14:40",
"v_199": "0",
"v2_199": "456"
"d": "2020-02-17 14:45",
"v_199": "0",
"v2_199": "348"
"d": "2020-02-17 14:50",
"v_199": "0",
"v2_199": "319"
"d": "2020-02-17 14:55",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 15:00",
"v_199": "0",
"v2_199": "396"
"d": "2020-02-17 15:05",
"v_199": "0",
"v2_199": "253"
"d": "2020-02-17 15:10",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 15:15",
"v_199": "0",
"v2_199": "192"
"d": "2020-02-17 15:20",
"v_199": "0",
"v2_199": "297"
"d": "2020-02-17 15:25",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 15:30",
"v_199": "0",
"v2_199": "252"
"d": "2020-02-17 15:35",
"v_199": "0",
"v2_199": "264"
"d": "2020-02-17 15:40",
"v_199": "0",
"v2_199": "360"
"d": "2020-02-17 15:45",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 15:50",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 15:55",
"v_199": "0",
"v2_199": "253"
"d": "2020-02-17 16:00",
"v_199": "0",
"v2_199": "396"
"d": "2020-02-17 16:05",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 16:10",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 16:15",
"v_199": "0",
"v2_199": "341"
"d": "2020-02-17 16:20",
"v_199": "0",
"v2_199": "300"
"d": "2020-02-17 16:25",
"v_199": "0",
"v2_199": "276"
"d": "2020-02-17 16:30",
"v_199": "0",
"v2_199": "348"
"d": "2020-02-17 16:35",
"v_199": "0",
"v2_199": "600"
"d": "2020-02-17 16:40",
"v_199": "0",
"v2_199": "480"
"d": "2020-02-17 16:45",
"v_199": "0",
"v2_199": "432"
"d": "2020-02-17 16:50",
"v_199": "0",
"v2_199": "363"
"d": "2020-02-17 16:55",
"v_199": "0",
"v2_199": "492"
"d": "2020-02-17 17:00",
"v_199": "0",
"v2_199": "336"
"d": "2020-02-17 17:05",
"v_199": "0",
"v2_199": "240"
"d": "2020-02-17 17:10",
"v_199": "0",
"v2_199": "420"
"d": "2020-02-17 17:15",
"v_199": "0",
"v2_199": "336"
"d": "2020-02-17 17:20",
"v_199": "0",
"v2_199": "319"
"d": "2020-02-17 17:25",
"v_199": "0",
"v2_199": "444"
"d": "2020-02-17 17:30",
"v_199": "0",
"v2_199": "492"
"d": "2020-02-17 17:35",
"v_199": "0",
"v2_199": "1392"
"d": "2020-02-17 17:40",
"v_199": "0",
"v2_199": "876"
"d": "2020-02-17 17:45",
"v_199": "0",
"v2_199": "1342"
"d": "2020-02-17 17:50",
"v_199": "0",
"v2_199": "576"
"d": "2020-02-17 17:55",
"v_199": "0",
"v2_199": "1128"
"d": "2020-02-17 18:00",
"v_199": "0",
"v2_199": "605"
"d": "2020-02-17 18:05",
"v_199": "0",
"v2_199": "1176"
"d": "2020-02-17 18:10",
"v_199": "0",
"v2_199": "572"
"d": "2020-02-17 18:15",
"v_199": "0",
"v2_199": "1080"
"d": "2020-02-17 18:20",
"v_199": "0",
"v2_199": "816"
"d": "2020-02-17 18:25",
"v_199": "0",
"v2_199": "828"
"status": "OK",
"title": "Graph day"
"dataFilterCount": 0,
"dataFilterUnit": "",
"decimals": 2,
"forced": false,
"graphConfig": null,
"graphIdx": "block_33199",
"hasBlock": true,
"idx": 199,
"lastRefreshTime": 1581960343,
"mountPoint": "#block_33",
"multigraph": false,
"name": "Elektriciteit",
"popup": false,
"primary": true,
"primaryIdx": "block_33199",
"range": "month",
"realrange": "month",
"sensor": "counter",
"subtype": "Energy",
"txtUnit": "kWh",
"type": "P1 Smart Meter",
"keys": [
"v",
"v2"
"ykeys": [
"v_199",
"v2_199"
"ylabels": [
"kWh",
"kWh"
}Greetz,
Sjonnie
- clinkadink
Thanks for the feedback!
Can you try with interval commented out?
Edit: did you copy the debug log after pressing the 'month' button? As the range shows "month" but the data is for "days". Scroll to the bottom of the debug log.
"range": "month","UI is the saddle, the stirrups, & the reins. UX is the feeling you get being able to ride the horse."
- Sjonnie2017
But of course
No change in the graphs unfortunately
EDIT: Debug log after first load (not selecting a time range):
‘Eliminate all other factors, and the one which remains must be the truth.’
"block": {
"devices": [
199
"datasetColors": [
"red",
"yellow",
"blue",
"orange",
"green",
"purple"
"barWidth": 0.9,
"borderColors": [
"red",
"yellow",
"blue",
"orange",
"green",
"purple"
"borderDash": [],
"borderWidth": 2,
"buttonsPadX": 6,
"buttonsPadY": 2,
"buttonsRadius": 4,
"buttonsSize": 14,
"custom": false,
"gradients": false,
"graph": "line",
"graphTypes": [
"v",
"v2"
"height": "400px",
"interval": 1,
"legend": {
"v2_199": "Dag",
"v_199": "Nacht"
"lineFill": false,
"lineTension": 0.1,
"method": 1,
"grey"
"pointFillColor": [
"red",
"yellow",
"blue",
"orange",
"green",
"purple"
"pointRadius": 0,
"spanGaps": false,
"width": 12
"currentValue": "7.93 kWh",
"currentValues": [
"7.93 kWh"
"data": {
"result": [
"v_199": "0",
"v2_199": "0"
"v_199": "2992",
"v2_199": "0"
"v_199": "2808",
"v2_199": "0"
"v_199": "1596",
"v2_199": "0"
"v_199": "792",
"v2_199": "0"
"v_199": "649",
"v2_199": "0"
"v_199": "684",
"v2_199": "0"
"v_199": "672",
"v2_199": "0"
"v_199": "627",
"v2_199": "0"
"v_199": "672",
"v2_199": "0"
"v_199": "684",
"v2_199": "0"
"v_199": "638",
"v2_199": "0"
"v_199": "744",
"v2_199": "0"
"v_199": "660",
"v2_199": "0"
"v_199": "732",
"v2_199": "0"
"v_199": "594",
"v2_199": "0"
"v_199": "756",
"v2_199": "0"
"v_199": "636",
"v2_199": "0"
"v_199": "660",
"v2_199": "0"
"v_199": "627",
"v2_199": "0"
"v_199": "696",
"v2_199": "0"
"v_199": "720",
"v2_199": "0"
"v_199": "708",
"v2_199": "0"
"v_199": "648",
"v2_199": "0"
"v_199": "594",
"v2_199": "0"
"v_199": "594",
"v2_199": "0"
"v_199": "624",
"v2_199": "0"
"v_199": "576",
"v2_199": "0"
"v_199": "756",
"v2_199": "0"
"v_199": "624",
"v2_199": "0"
"v_199": "561",
"v2_199": "0"
"v_199": "612",
"v2_199": "0"
"v_199": "660",
"v2_199": "0"
"v_199": "648",
"v2_199": "0"
"v_199": "516",
"v2_199": "0"
"v_199": "492",
"v2_199": "0"
"v_199": "480",
"v2_199": "0"
"v_199": "612",
"v2_199": "0"
"v_199": "492",
"v2_199": "0"
"v_199": "408",
"v2_199": "0"
"v_199": "420",
"v2_199": "0"
"v_199": "384",
"v2_199": "0"
"v_199": "297",
"v2_199": "0"
"v_199": "312",
"v2_199": "0"
"v_199": "408",
"v2_199": "0"
"v_199": "504",
"v2_199": "0"
"v_199": "468",
"v2_199": "0"
"v_199": "432",
"v2_199": "0"
"v_199": "374",
"v2_199": "0"
"v_199": "408",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "576",
"v2_199": "0"
"v_199": "468",
"v2_199": "0"
"v_199": "420",
"v2_199": "0"
"v_199": "330",
"v2_199": "0"
"v_199": "300",
"v2_199": "0"
"v_199": "312",
"v2_199": "0"
"v_199": "312",
"v2_199": "0"
"v_199": "540",
"v2_199": "0"
"v_199": "363",
"v2_199": "0"
"v_199": "480",
"v2_199": "0"
"v_199": "468",
"v2_199": "0"
"v_199": "480",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "552",
"v2_199": "0"
"v_199": "408",
"v2_199": "0"
"v_199": "319",
"v2_199": "0"
"v_199": "336",
"v2_199": "0"
"v_199": "360",
"v2_199": "0"
"v_199": "528",
"v2_199": "0"
"v_199": "420",
"v2_199": "0"
"v_199": "429",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "420",
"v2_199": "0"
"v_199": "552",
"v2_199": "0"
"v_199": "408",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "418",
"v2_199": "0"
"v_199": "480",
"v2_199": "0"
"v_199": "540",
"v2_199": "0"
"v_199": "360",
"v2_199": "0"
"v_199": "324",
"v2_199": "0"
"v_199": "312",
"v2_199": "0"
"v_199": "492",
"v2_199": "0"
"v_199": "432",
"v2_199": "0"
"v_199": "385",
"v2_199": "0"
"v_199": "492",
"v2_199": "0"
"v_199": "456",
"v2_199": "0"
"v_199": "420",
"v2_199": "0"
"v_199": "480",
"v2_199": "0"
"v_199": "561",
"v2_199": "0"
"v_199": "480",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "418",
"v2_199": "0"
"v_199": "312",
"v2_199": "0"
"v_199": "324",
"v2_199": "0"
"v_199": "444",
"v2_199": "0"
"v_199": "451",
"v2_199": "0"
"v_199": "456",
"v2_199": "0"
"v_199": "516",
"v2_199": "0"
"v_199": "612",
"v2_199": "0"
"v_199": "429",
"v2_199": "0"
"v_199": "456",
"v2_199": "0"
"v_199": "492",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "312",
"v2_199": "0"
"v_199": "363",
"v2_199": "0"
"v_199": "504",
"v2_199": "0"
"v_199": "336",
"v2_199": "0"
"v_199": "372",
"v2_199": "0"
"v_199": "480",
"v2_199": "0"
"v_199": "348",
"v2_199": "0"
"v_199": "385",
"v2_199": "0"
"v_199": "396",
"v2_199": "0"
"v_199": "360",
"v2_199": "0"
"v_199": "552",
"v2_199": "0"
"v_199": "374",
"v2_199": "0"
"v_199": "360",
"v2_199": "0"
"v_199": "384",
"v2_199": "0"
"v_199": "231",
"v2_199": "0"
"v_199": "444",
"v2_199": "0"
"v_199": "360",
"v2_199": "0"
"v_199": "516",
"v2_199": "0"
"v_199": "684",
"v2_199": "0"
"v_199": "588",
"v2_199": "0"
"v_199": "660",
"v2_199": "0"
"v_199": "732",
"v2_199": "0"
"v_199": "696",
"v2_199": "0"
"v_199": "576",
"v2_199": "0"
"v_199": "352",
"v2_199": "0"
"v_199": "744",
"v2_199": "0"
"v_199": "352",
"v2_199": "0"
"v_199": "456",
"v2_199": "0"
"v_199": "420",
"v2_199": "0"
"v_199": "864",
"v2_199": "0"
"v_199": "636",
"v2_199": "0"
"v_199": "418",
"v2_199": "0"
"v_199": "636",
"v2_199": "0"
"v_199": "372",
"v2_199": "0"
"v_199": "583",
"v2_199": "0"
"v_199": "341",
"v2_199": "0"
"v_199": "504",
"v2_199": "0"
"v_199": "468",
"v2_199": "0"
"v_199": "372",
"v2_199": "0"
"v_199": "0",
"v2_199": "516"
"v_199": "0",
"v2_199": "275"
"v_199": "0",
"v2_199": "360"
"v_199": "0",
"v2_199": "216"
"v_199": "0",
"v2_199": "360"
"v_199": "0",
"v2_199": "198"
"v_199": "0",
"v2_199": "360"
"v_199": "0",
"v2_199": "372"
"v_199": "0",
"v2_199": "407"
"v_199": "0",
"v2_199": "444"
"v_199": "0",
"v2_199": "324"
"v_199": "0",
"v2_199": "408"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "396"
"v_199": "0",
"v2_199": "324"
"v_199": "0",
"v2_199": "480"
"v_199": "0",
"v2_199": "308"
"v_199": "0",
"v2_199": "408"
"v_199": "0",
"v2_199": "240"
"v_199": "0",
"v2_199": "308"
"v_199": "0",
"v2_199": "192"
"v_199": "0",
"v2_199": "336"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "396"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "384"
"v_199": "0",
"v2_199": "286"
"v_199": "0",
"v2_199": "312"
"v_199": "0",
"v2_199": "418"
"v_199": "0",
"v2_199": "336"
"v_199": "0",
"v2_199": "492"
"v_199": "0",
"v2_199": "308"
"v_199": "0",
"v2_199": "336"
"v_199": "0",
"v2_199": "180"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "204"
"v_199": "0",
"v2_199": "456"
"v_199": "0",
"v2_199": "341"
"v_199": "0",
"v2_199": "456"
"v_199": "0",
"v2_199": "384"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "396"
"v_199": "0",
"v2_199": "288"
"v_199": "0",
"v2_199": "324"
"v_199": "0",
"v2_199": "363"
"v_199": "0",
"v2_199": "348"
"v_199": "0",
"v2_199": "396"
"v_199": "0",
"v2_199": "330"
"v_199": "0",
"v2_199": "228"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "204"
"v_199": "0",
"v2_199": "253"
"v_199": "0",
"v2_199": "420"
"v_199": "0",
"v2_199": "348"
"v_199": "0",
"v2_199": "348"
"v_199": "0",
"v2_199": "440"
"v_199": "0",
"v2_199": "312"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "374"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "253"
"v_199": "0",
"v2_199": "300"
"v_199": "0",
"v2_199": "360"
"v_199": "0",
"v2_199": "242"
"v_199": "0",
"v2_199": "240"
"v_199": "0",
"v2_199": "324"
"v_199": "0",
"v2_199": "192"
"v_199": "0",
"v2_199": "228"
"v_199": "0",
"v2_199": "420"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "492"
"v_199": "0",
"v2_199": "348"
"v_199": "0",
"v2_199": "308"
"v_199": "0",
"v2_199": "408"
"v_199": "0",
"v2_199": "288"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "396"
"v_199": "0",
"v2_199": "192"
"v_199": "0",
"v2_199": "242"
"v_199": "0",
"v2_199": "396"
"v_199": "0",
"v2_199": "252"
"v_199": "0",
"v2_199": "204"
"v_199": "0",
"v2_199": "240"
"v_199": "0",
"v2_199": "420"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "300"
"v_199": "0",
"v2_199": "456"
"v_199": "0",
"v2_199": "348"
"v_199": "0",
"v2_199": "319"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "396"
"v_199": "0",
"v2_199": "253"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "192"
"v_199": "0",
"v2_199": "297"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "252"
"v_199": "0",
"v2_199": "264"
"v_199": "0",
"v2_199": "360"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "253"
"v_199": "0",
"v2_199": "396"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "341"
"v_199": "0",
"v2_199": "300"
"v_199": "0",
"v2_199": "276"
"v_199": "0",
"v2_199": "348"
"v_199": "0",
"v2_199": "600"
"v_199": "0",
"v2_199": "480"
"v_199": "0",
"v2_199": "432"
"v_199": "0",
"v2_199": "363"
"v_199": "0",
"v2_199": "492"
"v_199": "0",
"v2_199": "336"
"v_199": "0",
"v2_199": "240"
"v_199": "0",
"v2_199": "420"
"v_199": "0",
"v2_199": "336"
"v_199": "0",
"v2_199": "319"
"v_199": "0",
"v2_199": "444"
"v_199": "0",
"v2_199": "492"
"v_199": "0",
"v2_199": "1392"
"v_199": "0",
"v2_199": "876"
"v_199": "0",
"v2_199": "1342"
"v_199": "0",
"v2_199": "576"
"v_199": "0",
"v2_199": "1128"
"v_199": "0",
"v2_199": "605"
"v_199": "0",
"v2_199": "1176"
"v_199": "0",
"v2_199": "572"
"v_199": "0",
"v2_199": "1080"
"v_199": "0",
"v2_199": "816"
"v_199": "0",
"v2_199": "828"
"d": "2020-02-17 18:30",
"v_199": "0",
"v2_199": "756"
"d": "2020-02-17 18:35",
"v_199": "0",
"v2_199": "825"
"d": "2020-02-17 18:40",
"v_199": "0",
"v2_199": "588"
"d": "2020-02-17 18:45",
"v_199": "0",
"v2_199": "1144"
"status": "OK",
"decimals": 2,
"forced": false,
"hasBlock": true,
"idx": 199,
"lastRefreshTime": 1581961504,
"popup": false,
"primary": true,
"range": "month",
"txtUnit": "kWh",
"keys": [
"v",
"v2"
"ykeys": [
"v_199",
"v2_199"
"ylabels": [
"kWh",
"kWh"
}ConBee II - TRÅDFRI lights + switches, loads of ChingLing dimmers and switches, Heiman and Xiaomi sensors
- clinkadink
That ^^^ is the reason. As suspected, your graph is initiating with range set to month. The default for month is kWh. Now to work out why.Sjonnie2017 wrote: Monday 17 February 2020 18:44 Debug log after first load (not selecting a time range):Code: Select all
{ // truncated // "range": "month", <---- should be "day" "realrange": "month", <---- should be "day" "sensor": "counter", "subtype": "Energy", "title": "Elektriciteit", "txtUnit": "kWh", "type": "P1 Smart Meter", "keys": [ "v", "v2" ], "ykeys": [ "v_199", "v2_199" ], "ylabels": [ "kWh", "kWh" ] }
It looks like the debug button is paying off already
- Sjonnie2017
I think we found the "why"
This is in my custom.js:
Will rem it out and see what happens...
EDIT: Bingo!
However I would like to have last month as the standard time period for these graphs
EDIT2: On the other hand: if it is a lot of work I will settle for 'day'
config['standard_graph'] = 'month';EDIT: Bingo!
- clinkadink
I should be able to fix it, now I know what the reason is. Thanks for the info. Leave it with me, I will get back to youSjonnie2017 wrote: Monday 17 February 2020 18:55 However I would like to have last month as the standard time period for these graphs![]()
- Sjonnie2017
I am certain you will! Somehow I expect to have to update to the latest beta somewhere in the near future
