Pushover
tre4bax
Pushover
Post by tre4bax »
Hi There,
Has anyone used Pushover? I set this all up but it asks for a username and the only one I have is an email address. When you try and put that in using Domoticz it changes the @ to %40 and thus it does not seem to function.
What username do I need and how do I get it entered?
Trevor
bizziebis
Domoticz version: 3.8805
Re: Pushover
Post by bizziebis »
You have to login at the website pushover.com.
There you'll find your User Key ( User ID field in Domoticz).
You have to Register an Application on the pushover website. That will give you an API Token/Key (API Key field in Domoticz)
When you fill in both fields with the values you now have, you can start receiving notifications.
tre4bax
Re: Pushover
Post by tre4bax »
Ah, Many thanks. I get it now. Seems to be working okay. If I can just fix it up so that the new version Domoticz boots on start again all will be well :-)
NLRad
Problem with Pushover configuration
Post by NLRad »
I'm having trouble with configuring Pushover with Domoticz on my Raspberry Pi2B. I registered Domoticz as an app, then I filled in my user key en API token on the settings page. But if I push the Test button, in a red box the following message is displayed: Problem sending notification, please check the api key!
Anyone any suggestion?
Pushing notification from my desktop to my Pushover android client works just fine.
jannl
Domoticz version: 2026.1.x
Re: Pushover
Post by jannl »
May be you have a white space before or after the api key?
NLRad
Re: Pushover
Post by NLRad »
@jannl: thanks for your suggestion, but no, no leading or trailing spaces (I doublechecked).
See attached screenshot of the Domoticz Pushover configuration errormessage.
20151221 domoticz pushover error.png (47.89 KiB) Viewed 10579 times
jannl
Re: Pushover
Post by jannl »
Not sure if for testing 'actief' must be checked.
hjvingen
Re: Pushover
Post by hjvingen »
I got this message also at first setup.
After saving settings and go back to testing, it worked for me.
NLRad
Re: Pushover
Post by NLRad »
@hjvingen: yep, that did it. Thnx!
antares
Re: Pushover
Post by antares »
Hello!
I got this working now as well, and wonder how I can now send a push notification from LUA. Is there a 'SEND PUSHOVER' command?
G3rard
Domoticz version: No
Re: Pushover
Post by G3rard »
Check this post http://www.domoticz.com/forum/viewtopic ... 31&t=14884.
It's going to be implemented by ultratoto14.
Not using Domoticz anymore
