Esp8266 + WS2812 Strip Led + Domoticz
vrega
i've read on forum about some projects to integrate the WS2812 RGB led strip with Domoticz but i've not found a WiKi or tutorial on how to integrate it with Domoticz.
Can someone reassume the steps to make it work?
- gizmocuz
Re: Esp8266 + WS2812 Strip Led + Domoticz
Should be working fine using MySensors
vrega
How to integrate it with domoticz? What's the hardware to use to make it work?
Do i need the gateway? is there a way to use only esp8266 (with espeasy inside)?
I have build this system, working quite nice:
https://www.twoenter.nl/blog/arduino-es ... -domoticz/
- ledfreak3d
- Domoticz version: 3.8025
yep but those are not neopixelsB7en9 wrote: Thursday 10 January 2019 19:05 I have build this system, working quite nice:
Unleashe the magic smoke ;)
- MaffeMuis
- Domoticz version: 3.9483
Your still searching? I got a working version. True mqtt, domoticz and nice scenes. That you can build yourself and run with 6 zones.ledfreak3d wrote: Friday 02 August 2019 18:48yep but those are not neopixelsB7en9 wrote: Thursday 10 January 2019 19:05 I have build this system, working quite nice:
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
gerbenvanasselt
- Domoticz version: Beta 4.1
Hey Guys, did you use esp easy version to control the 12v rgb strip? I want to use it combined with tasmota. Does anyone have experience with this setup and tasmota?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
snellejellep
- Domoticz version: 2020.2
use wled with the plugin. easy and works flawlessly for me
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
gerbenvanasselt
Will try when Ali delivers. Do you know if you can have two white LEDs as well instead of rgbw?snellejellep wrote:use wled with the plugin. easy and works flawlessly for me
snellejellep
I dont know, you should check the wled github for that
Verstuurd vanaf mijn SM-G975F met Tapatalk
twoenter
- Domoticz version: 4.10
Guys I've translated my dutch article about RGB ledstrips and domoticz to English for you.B7en9 wrote: Thursday 10 January 2019 19:05 I have build this system, working quite nice:
See
https://www.twoenter.nl/blog/en/domotic ... -domoticz/
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
Users browsing this forum: Ahrefs [Bot] and 1 guest
