Esp8266 + WS2812 Strip Led + Domoticz
i've read on forum about some projects to integrate the WS2812 RGB led strip with Domoticz but i've not found a WiKi or tutorial on how to integrate it with Domoticz.
Can someone reassume the steps to make it work?
- gizmocuz
Re: Esp8266 + WS2812 Strip Led + Domoticz
Should be working fine using MySensors
How to integrate it with domoticz? What's the hardware to use to make it work?
Do i need the gateway? is there a way to use only esp8266 (with espeasy inside)?
I have build this system, working quite nice:
https://www.twoenter.nl/blog/arduino-es ... -domoticz/
- ledfreak3d
- Domoticz version: 3.8025
yep but those are not neopixelsB7en9 wrote: ↑Thursday 10 January 2019 19:05 I have build this system, working quite nice:
Unleashe the magic smoke ;)
- MaffeMuis
- Domoticz version: 3.9483
Your still searching? I got a working version. True mqtt, domoticz and nice scenes. That you can build yourself and run with 6 zones.ledfreak3d wrote: ↑Friday 02 August 2019 18:48yep but those are not neopixelsB7en9 wrote: ↑Thursday 10 January 2019 19:05 I have build this system, working quite nice:
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
- Domoticz version: Beta 4.1
Hey Guys, did you use esp easy version to control the 12v rgb strip? I want to use it combined with tasmota. Does anyone have experience with this setup and tasmota?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
- Domoticz version: 2020.2
use wled with the plugin. easy and works flawlessly for me
Will try when Ali delivers. Do you know if you can have two white LEDs as well instead of rgbw?snellejellep wrote:use wled with the plugin. easy and works flawlessly for me
I dont know, you should check the wled github for that
Verstuurd vanaf mijn SM-G975F met Tapatalk
- Domoticz version: 4.10
Guys I've translated my dutch article about RGB ledstrips and domoticz to English for you.B7en9 wrote: ↑Thursday 10 January 2019 19:05 I have build this system, working quite nice:
See
https://www.twoenter.nl/blog/en/domotic ... -domoticz/
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
