Esp8266 + WS2812 Strip Led + Domoticz
Everything about esp8266 and more.
vrega
Post by vrega »
i've read on forum about some projects to integrate the WS2812 RGB led strip with Domoticz but i've not found a WiKi or tutorial on how to integrate it with Domoticz.
Can someone reassume the steps to make it work?
gizmocuz
Re: Esp8266 + WS2812 Strip Led + Domoticz
Post by gizmocuz »
Should be working fine using MySensors
vrega
Post by vrega »
How to integrate it with domoticz? What's the hardware to use to make it work?
Do i need the gateway? is there a way to use only esp8266 (with espeasy inside)?
B7en9
Post by B7en9 »
I have build this system, working quite nice:
https://www.twoenter.nl/blog/arduino-es ... -domoticz/
ledfreak3d
Domoticz version: 3.8025
Post by ledfreak3d »
B7en9 wrote: Thursday 10 January 2019 19:05 I have build this system, working quite nice:
yep but those are not neopixels
Unleashe the magic smoke ;)
MaffeMuis
Domoticz version: 3.9483
Post by MaffeMuis »
ledfreak3d wrote: Friday 02 August 2019 18:48
Your still searching? I got a working version. True mqtt, domoticz and nice scenes. That you can build yourself and run with 6 zones.
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
gerbenvanasselt
Domoticz version: Beta 4.1
Post by gerbenvanasselt »
Hey Guys, did you use esp easy version to control the 12v rgb strip? I want to use it combined with tasmota. Does anyone have experience with this setup and tasmota?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
snellejellep
Post by snellejellep »
use wled with the plugin. easy and works flawlessly for me
gerbenvanasselt
snellejellep wrote:use wled with the plugin. easy and works flawlessly for me
Will try when Ali delivers. Do you know if you can have two white LEDs as well instead of rgbw?
snellejellep
I dont know, you should check the wled github for that
Verstuurd vanaf mijn SM-G975F met Tapatalk
twoenter
Domoticz version: 4.10
Post by twoenter »
Guys I've translated my dutch article about RGB ledstrips and domoticz to English for you.
See
https://www.twoenter.nl/blog/en/domotic ... -domoticz/
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
