domoticz in synology as package! Available now.
michaelb
Post by michaelb »
Hi Jumbotroll,
I recently updated the package to version V4.11213 (cedarview) and it seems it deletes the custom pages in the www/templates directory. Can you fix somthing so that in future builds this dir is retained?
Michael
jumbotroll
Post by jumbotroll »
michaelb wrote: Saturday 31 August 2019 7:57 Hi Jumbotroll,
Michael
Modified install script, please test latest build..
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
Hi Jumbotroll, can you create a new appollolake without python build tonight (no hurry since i still see a couple of fixes coming in, gizmocuz is on a roll :D )
There are a couple of new bugfixes and functionality regarding the buienradar implementation.(build 248 or newer)
jumbotroll
Gravityz wrote: Sunday 01 September 2019 14:54 Hi Jumbotroll, can you create a new appollolake without python build tonight (no hurry since i still see a couple of fixes coming in, gizmocuz is on a roll :D )
Apollolake is updated..
Jumbotroll
Gravityz
Post by Gravityz »
thanks
Gravityz
Post by Gravityz »
Hi Jumbotroll, can you create build 290 or higher
they fixed some buienradar stuff ik like to test out
thanks
for other people reading this. i recently made another donation(yes the last one was 2 years ago :roll: ) to Jumbotroll because he is doing excellent work
If you value these synology builds please think about donating because this saves us a lot of time
jumbotroll
Gravityz wrote: Friday 06 September 2019 15:11 Hi Jumbotroll, can you create build 290 or higher
thanks
Updated :)
Jumbotroll
Jumper3126
Post by Jumper3126 »
Just updated from 4.9700 to 4.10717 on my synology 218 play by deleting the old version and then installing the new one. I'm not able to load the Device nor the Hardware tabs. All other tabs and settings are loaded directly. I've tried to reinstall both the python and non-python version but the same result. When I reinstall the 4.9700 version, the hardware and device functions work like normal again.
Any advice/idea how to solve this??
Solved it ;)
Needed to empty cache
Gravityz
Post by Gravityz »
Hi Jumbotroll.
can you create a new build(11324 or later)
want to check if the negative rain value is fixed
Gravityz
Post by Gravityz »
hi Jumbotroll, is it possible to create build 352 or later.
the buienradar problem seems hard to fix.(rain counter does not get reset correctly)
jumbotroll
Gravityz wrote: Sunday 06 October 2019 11:38 hi Jumbotroll, is it possible to create build 352 or later.
V4.11354 is uploaded :)
Jumbotroll
arkoko
Post by arkoko »
Hi!
I have installed Jadahl package (Beta for DSM 6.2) on my two Synology devices (DS214 Play and DS218+) and downloading configuration file from Z-Wave Node Managemenrt does not working on both of them.
URL opened (e.g. https://mysyno.address.me/zwavegetconfig.php?idx=2), but nothing happened, only empty page.
I just wonder is it global or related to Synology or to my environment? I can't check anymore, but before one instance ran on Raspberry Pi and if I remember correctly, downloading then worked.
"AEON Labs ZW090 Z-Stick Gen5 EU" and "AEON Labs DSA02203 Z-Stick S2" USB sticks are in use.
I like this package - donated!
Gravityz
Post by Gravityz »
not working on my synology as well but i do not use this functionality
mine is giving the same response page but with idx=3
what configuration file should get downloaded?
@Jumbotroll, build 367 or later should have some buienrader fixes and new functionality(could this really be the last fix :-))
arkoko
Post by arkoko »
For instance, I just installed for testing fresh last stable Domoticz on raspberry, then connected Z-Wave USB stick and downloading works. It gave me xml file (it's quite empty, because no added nodes to the controller).
zwcfg_0xcd99e118.xml:
<?xml version="1.0" encoding="utf-8" ?>
<Driver xmlns="http://code.google.com/p/open-zwave/" version="3" home_id="0xcd99e118" node_id="1" api_capabilities="0" controller_capabilities="40" poll_interval="60000" poll_interval_between="false">
    <Node id="1" name="Controller" location="" basic="2" generic="2" specific="1" type="Static PC Controller" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
        <Manufacturer id="115" name="Z-Wave.Me">
            <Product type="400" id="1" name="ZME_UZB1 USB Stick" />
        </Manufacturer>
        <CommandClasses>
            <CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" after_mark="true">
                <Instance index="1" />
                <Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
            </CommandClass>
        </CommandClasses>
    </Node>
</Driver>
Aad3229
Post by Aad3229 »
I am running the latest stable on my Synology DS218+ and I don't have problems with Zwave.
Domoticz V4.10717 on Synology, RFXtrx433E USB 433.92MHz Transceiver, 9 x KAKU Switch (APA3-1500R), 1 x ABST-604 KAKU Dusk sensor, MiLight iBox V6, OpenZwave USB-stick Aeon LabS, Zwave PIR, Zwave door sensors, Zwave powerplugs
arkoko
Post by arkoko »
Configuration download work? Which type of Z-Wave stick you are using?
matsumoto
Domoticz version: V3.9483
Post by matsumoto »
No longer support for MARVELL Kirkwood 88F6282 (ds413j) ?
I've got a problem with Chrome displaying an empty screen with only a "replace" field.
If no more support, any detailed tutorial how to compile domoticz for my NAS ?
Thanks !
Aad3229
Post by Aad3229 »
I use the AON Aeotec ZW090 Z-Stick Gen5 EU. And, sorry, the configuration download page is empty by me as well.
bertbigb
Post by bertbigb »
I encounter a very new problem for me.
I just downloaded http://www.jadahl.com/domoticz_stable_6 ... rch=avoton for my Synology 1517+
It is installing but I can't get it to run from the package centre.
Someone else recognizing this problem? Who can help me or guide me a bit to get it to work?
Best regards Bert
Synology DS1517+ - DSM 6.2
jumbotroll
bertbigb wrote: Sunday 17 November 2019 16:13 Hi all,
You have installed the Python version and you have to install Python3 package for domoticz to run.
Download and install this: https://global.download.synology.com/do ... mber=24922
Jumbotroll
Users browsing this forum: suhanidash557 and 1 guest
