domoticz in synology as package! Available now.
Hi Jumbotroll,
I recently updated the package to version V4.11213 (cedarview) and it seems it deletes the custom pages in the www/templates directory. Can you fix somthing so that in future builds this dir is retained?
Michael
Michael
- jumbotroll
Modified install script, please test latest build..
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Domoticz version: 2022.2
Hi Jumbotroll, can you create a new appollolake without python build tonight (no hurry since i still see a couple of fixes coming in, gizmocuz is on a roll
There are a couple of new bugfixes and functionality regarding the buienradar implementation.(build 248 or newer)
- jumbotroll
Apollolake is updated..Gravityz wrote: ↑Sunday 01 September 2019 14:54 Hi Jumbotroll, can you create a new appollolake without python build tonight (no hurry since i still see a couple of fixes coming in, gizmocuz is on a roll)
Jumbotroll
Jumbotroll
Hi Jumbotroll, can you create build 290 or higher
they fixed some buienradar stuff ik like to test out
thanks
for other people reading this. i recently made another donation(yes the last one was 2 years ago
) to Jumbotroll because he is doing excellent work
If you value these synology builds please think about donating because this saves us a lot of time
thanks
- jumbotroll
UpdatedGravityz wrote: ↑Friday 06 September 2019 15:11 Hi Jumbotroll, can you create build 290 or higher
thanks
for other people reading this. i recently made another donation(yes the last one was 2 years ago) to Jumbotroll because he is doing excellent work
Jumbotroll
Jumbotroll
Just updated from 4.9700 to 4.10717 on my synology 218 play by deleting the old version and then installing the new one. I'm not able to load the Device nor the Hardware tabs. All other tabs and settings are loaded directly. I've tried to reinstall both the python and non-python version but the same result. When I reinstall the 4.9700 version, the hardware and device functions work like normal again.
Any advice/idea how to solve this??
Solved it
Needed to empty cache
Solved it
Hi Jumbotroll.
can you create a new build(11324 or later)
want to check if the negative rain value is fixed
hi Jumbotroll, is it possible to create build 352 or later.
the buienradar problem seems hard to fix.(rain counter does not get reset correctly)
- jumbotroll
V4.11354 is uploaded
Jumbotroll
Jumbotroll
Hi!
I have installed Jadahl package (Beta for DSM 6.2) on my two Synology devices (DS214 Play and DS218+) and downloading configuration file from Z-Wave Node Managemenrt does not working on both of them.
URL opened (e.g. https://mysyno.address.me/zwavegetconfig.php?idx=2), but nothing happened, only empty page.
I just wonder is it global or related to Synology or to my environment? I can't check anymore, but before one instance ran on Raspberry Pi and if I remember correctly, downloading then worked.
"AEON Labs ZW090 Z-Stick Gen5 EU" and "AEON Labs DSA02203 Z-Stick S2" USB sticks are in use.
I like this package - donated!
not working on my synology as well but i do not use this functionality
mine is giving the same response page but with idx=3
what configuration file should get downloaded?
@Jumbotroll, build 367 or later should have some buienrader fixes and new functionality(could this really be the last fix
For instance, I just installed for testing fresh last stable Domoticz on raspberry, then connected Z-Wave USB stick and downloading works. It gave me xml file (it's quite empty, because no added nodes to the controller).
zwcfg_0xcd99e118.xml:
- Spoiler: show
I am running the latest stable on my Synology DS218+ and I don't have problems with Zwave.
Domoticz V4.10717 on Synology, RFXtrx433E USB 433.92MHz Transceiver, 9 x KAKU Switch (APA3-1500R), 1 x ABST-604 KAKU Dusk sensor, MiLight iBox V6, OpenZwave USB-stick Aeon LabS, Zwave PIR, Zwave door sensors, Zwave powerplugs
Configuration download work? Which type of Z-Wave stick you are using?
- Domoticz version: V3.9483
No longer support for MARVELL Kirkwood 88F6282 (ds413j) ?
I've got a problem with Chrome displaying an empty screen with only a "replace" field.
If no more support, any detailed tutorial how to compile domoticz for my NAS ?
Thanks !
Thanks !
I use the AON Aeotec ZW090 Z-Stick Gen5 EU. And, sorry, the configuration download page is empty by me as well.Configuration download work? Which type of Z-Wave stick you are using?
I encounter a very new problem for me.
I just downloaded http://www.jadahl.com/domoticz_stable_6 ... rch=avoton for my Synology 1517+
It is installing but I can't get it to run from the package centre.
Someone else recognizing this problem? Who can help me or guide me a bit to get it to work?
Best regards Bert
Synology DS1517+ - DSM 6.2
- jumbotroll
You have installed the Python version and you have to install Python3 package for domoticz to run.bertbigb wrote: ↑Sunday 17 November 2019 16:13 Hi all,
Download and install this: https://global.download.synology.com/do ... mber=24922
Jumbotroll
Jumbotroll
