(rooted) Toon thermostat combined Get and Set script
- Domoticz version: V2022.1
Re: Toon thermostat combined Get and Set script
i am using a toon, but without a registration from enexis. therefor i can't add it to domoticz. but can this script work without having the toon connect to domoticz? by written the asked toon info to dummy devices?
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
- Domoticz version: 4.10659
Thanks for the reply, but the <IP> is just for posting purposes. I already went ahead and changed the code so that my IP is in there instead of putting into a domoticz var.waaren wrote: ↑Monday 18 February 2019 20:13The IP number of your Toon need to be entered in the uservariable UV_ToonIP. Look at the first post of this topic.jbr79 wrote: ↑Monday 18 February 2019 19:46 irrespective of setting local LAN access to true or not, the error message is:Code: Select all
Error opening url: http://<IP>/happ_thermstat?action=getThermostatInfo
It would help if you show the loglines produced by this script.
Rather than changing the script though, I guess the issue is that I need a hacked Toon for it to work...
- Domoticz version: 2023.2
Hi everybody,
I liked the script and made an addition to be aware when my Toon is heating. I want to smart control my thermostat when I'm working from home. Since sharing is caring; hereby the updated script.
P.S. I couldn't properly diff it but only approximately 10 lines have changed.
P.S.2 One should add the required uservariable and selector switch as mentioned here in the manual with "ToonBranderInfo"
P.S.3 Toon only ever shows if it is heating or not and doesn't mention the usage of WW (in Dutch: warmwater) since it's not controlled through OTGW mode but pure simple on/off mode I geuss.
Sync Domoticz sensors / switches with Toon in case the value is changed on the physical device.
Updates
Thermostat Sensor
Temperature Sensor
Scenes switch based on program set on Toon
(Auto)program switch to value set on Toon
Program information text to value set on Toon
Van: https://www.domoticz.com/forum/viewtopic.php?f=59&t=26662
local toonResponse = "toonResponse"
local ResponseOK = "OK_toon_Response"
local scriptVersion = "version 0.2"
on = { timer = { "every minute" },
devices = { "Toon Thermostaat","Toon Scenes" },
httpResponses = { toonResponse , ResponseOK }},
logging = {
level = domoticz.LOG_INFO,
-- level = domoticz.LOG_DEBUG,
marker = scriptVersion .. " Toon"
data = {
lastActive = { initial = 0 },
isActive = { initial = false },
blockSetPoint = { initial = false }, -- Bug in TimedCommands (silent() does not work in updateSetPoint
execute = function(dz, item)
local now = os.time(os.date('*t')) -- seconds since 1/1/1970 00:00:01
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local function sendURL(url,callback)
local toonIP = dz.variables("UV_ToonIP").value
local url = "http://" .. toonIP .. url
dz.openURL({
url = url,
method = "GET",
callback = callback
local function setSetPoint(device,setPoint) -- update setPoint
if device.setPoint ~= setPoint then
logWrite("Updating thermostat sensor to new set point: " .. setPoint )
device.updateSetPoint(setPoint)
dz.data.blockSetPoint = false
local function setSelector(device,state,str) -- update selector
if device.level ~= state and device.lastUpdate.secondsAgo > 59 then
logWrite("Updating the " .. device.name .. " level to " .. str .. " (" .. state .. ")")
device.switchSelector(state).silent()
local function setTemperature(device,temperature) -- Update temperature sensor
if device.temperature ~= temperature then
logWrite("Updating the temperature sensor to: " .. temperature)
device.updateTemperature(temperature).silent()
local function setText(device,text) -- Update text sensor
if device.text ~= text then
logWrite("Updating " .. device.name .. " to: " .. text)
device.updateText(text)
local function setSetPointInfo(device,nextTime,setPoint)
if nextTime == 0 or setPoint == 0 then
newText = "Op " .. setPoint .. "▒"
newText = "Om " ..os.date("%H:%M", nextTime).. " naar " .. setPoint .. "▒"
setText(device,newText)
local function setSceneState(device,state)
local states = { 50,40,30,20,10} -- Manual, Comfort, Home, Sleep , Away
local stateStrings = { "Manual", "Comfort", "Home", "Sleep" , "Away"}
local newState = states[state + 2]
local stateString = stateStrings[state + 2]
setSelector(device,newState,stateString)
local function setProgramState(device,state)
local states = { 10,20,30 } -- No, Yes, Temporary
local stateStrings = { "No", "Yes", "Temporary" }
local newState = states[state + 1]
local stateString = stateStrings[state + 1]
local function setBurnerState(device,state)
local states = { 0,10,20 } -- Off, CV, WW
local stateStrings = { "Off", "CV", "WW" }
local function updateDevices(rt)
local toonThermostat = dz.devices(dz.variables("UV_ToonThermostatSensorName").value) -- Sensor showing current setpoint
local toonTemperature = dz.devices(dz.variables("UV_ToonTemperatureSensorName").value) -- Sensor showing current room temperature
local toonScenes = dz.devices(dz.variables("UV_ToonScenesSensorName").value) -- Sensor showing current program
local toonAutoProgram = dz.devices(dz.variables("UV_ToonAutoProgramSensorName").value) -- Sensor showing current auto program status
local toonProgramInformation = dz.devices(dz.variables("UV_ToonProgramInformationSensorName").value) -- Sensor showing displaying program information status
local toonBurner = dz.devices(dz.variables("UV_ToonBurnerInfo").value) -- Sensor showing current CV information status
-- local toonModulation
setSetPoint (toonThermostat, dz.utils.round(rt.currentSetpoint / 100,1 ))
setTemperature (toonTemperature, dz.utils.round(rt.currentTemp / 100,1 ))
setSceneState (toonScenes, rt.activeState ) -- "activeState":"-1" ==> 50
setProgramState (toonAutoProgram, rt.programState ) -- "programState":"0" ==> 10
setBurnerState (toonBurner, rt.burnerInfo ) -- "burnerInfo":"0" ==> 0
setText (toonProgramInformation, dz.utils.round(rt.nextTime,rt.nextSetpoint / 100,1 ))
local function procesToonResponse()
logWrite(tostring(item.data))
return dz.utils.fromJSON(item.data)
local function sendSetPoint(newSetPoint)
logWrite("In function sendSetPoint; " .. item.name .. " wants to set setPoint to " .. newSetPoint)
local calculatedSetPoint = newSetPoint * 100
local urlString = "/happ_thermstat?action=setSetpoint&Setpoint=" .. calculatedSetPoint
if not dz.data.blockSetPoint then
sendURL(urlString, ResponseOK )
logWrite("Toon setPoint send using " .. urlString)
logWrite("Toon setPoint not send ; unblocking now ")
local function sendScene()
local newstate
logWrite("In function sendScene; " .. item.name .. "; level " .. item.level .. " ==>> " .. item.levelName)
if item.level == 0 then -- Off
sendSetPoint(60)
return
if item.level == 10 then newState = 3 -- Away
elseif item.level == 20 then newState = 2 -- Sleep
elseif item.level == 30 then newState = 1 -- Home
elseif item.level == 40 then newState = 0 -- Comfort
else newState = -1 -- Invalid
local urlString = "/happ_thermstat?action=changeSchemeState&state=2&temperatureState=" .. newState
logWrite("Toon SchemeState send using " .. urlString)
local function getInfo()
sendURL("/happ_thermstat?action=getThermostatInfo",toonResponse)
-- Check for conflicts between timer and set Toon
local function setActive(state)
if state then
logWrite("Triggered by device. Setting active")
dz.data.isActive = true
dz.data.lastActive = now
dz.data.isActive = false
logWrite("Answer from Toon. Unset active")
local function isFree()
return (( dz.data.lastActive + 90 ) < now ) or ( not dz.data.isActive )
local function writeStatus(origin)
logWrite(origin .. "isFree: " .. tostring(isFree()))
logWrite(origin .. "lastActive: " .. os.date("%X",dz.data.lastActive))
logWrite(origin .. "blockSetPoint: " .. tostring(dz.data.blockSetPoint))
-- main program
writeStatus("-- start -- ")
if item.isDevice then -- triggered by selector or setPoint
if item.name == "Toon Scenes" then
sendScene()
setActive(true)
sendSetPoint(item.setPoint)
setActive(true)
elseif item.isTimer and isFree() then -- triggered by timer
dz.data.blockSetPoint = true
getInfo()
elseif item.isHTTPResponse then -- Triggered by Toon response
if item.trigger == toonResponse then -- return from getInfo()
if item.ok and isFree() then -- statusCode == 2xx
updateDevices(procesToonResponse())
elseif isFree() then
logWrite("Toon did not return valid data. Please check what went wrong. Error code: " .. item.statusCode or 999 ,dz.LOG_ERROR)
logWrite("Invalid data: " .. tostring(item.data))
logWrite("Toon is busy dealing with sendScene or sendSetPoint")
logWrite("returned from sendScene or sendSetPoint: " .. tostring(item.data))
setActive(false)
logWrite("This should never happen")
writeStatus("-- end -- ")
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
Does this work with the rooted Toon?
Verstuurd vanaf mijn LM-V405 met Tapatalk
Yes; @jjnj, only with a rooted Toon.
Nice script. After the latest domoticz update the original script did crash domoticz, so I had to disable it.
Now I will use your script. But when i use it I got this error:
Error: EventSystem: in Toon Thermostaat: [string "--[[
..."]:22: attempt to index global 'domoticz' (a nil value)
What does it mean?
What does it mean?
- waaren
@jonathan12
The script is to be set as a dzVents script. From what I see it looks like you tried to save it as a Lua script.
When not yet familiar with dzVents please start with reading Get started Before implementing. Special attention please for
"In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
Hi Waaren,
Thanks for your answer! Now it is working.
Thanks a lot!
Thanks a lot!
- Domoticz version: 4.9700
Hi, I'm new here, and for a while playing around with the above script. (versie imdos)
almost everything works but I get one error in my log namely:Error: EventSystem: in toon script: [string "commandArray = {}..."]:58: attempt to perform arithmetic on field '?' (a nil value)
i where to look for the error? the only thing my stand in that line is that there is a difference in Setpoint and SetPoint hear that so or is there a mistake somewhere?
thanks in advance
thanks in advance
* raspberry pi3b+
* rooted toon 2
* rooted toon 2
- waaren
Do you mean changing something in the script with "playing around" ?annesdomotic wrote: ↑Tuesday 20 August 2019 12:28 Hi, I'm new here, and for a while playing around with the above script. (versie imdos)
There is no such line in the original script or in the version of @imdos. Because the script is in dzVents lua no commandarray manipulation is needed on the script-level.almost everything works but I get one error in my log namely:Error: EventSystem: in toon script: [string "commandArray = {}..."]:58: attempt to perform arithmetic on field '?' (a nil value)
So if you changed anything in the script please post it and also the complete loglines for this script.
good morning,
by playing I mean trying. Add xiaomi sensors via zigbee etc. and that went well. I only found 1 error in the log and that was in line 58:
what struck me in this line is that it says Setpoint and later SetPoint. I've changed both to Setpoint and now my domoticz has crashed. domoticz offline, I can approach m via putty but after restart the domoticz stays offline. new problem
if currentBoilerSetPoint ~= nil then
-- Update the temperature of boiler
if otherdevices_svalues[ToonBoilerTempSetpoint]*100 ~= currentBoilerSetPoint*100 then
print('Updating the boiler temperature to new value: ' ..currentBoilerSetPoint)
commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonBoilerTempSetpoint], currentBoilerSetPoint)}
* raspberry pi3b+
* rooted toon 2
* rooted toon 2
sudo /etc/init.d/domoticz.sh restart
my domoticz is online
* raspberry pi3b+
* rooted toon 2
* rooted toon 2
- waaren
I cannot be sure because you only post part of your script but from what I see here it looks like you are playing with another script. This topic is about the dzVents version of the [hacked] Toon control combined in one script.annesdomotic wrote: ↑Wednesday 21 August 2019 8:59 by playing I mean trying. Add xiaomi sensors via zigbee etc. and that went well. I only found 1 error in the log and that was in line 58:
It is not a good idea to combine classic domoticz Lua with dzVents as the both change the commandArray object (used for communicating back to domoticz main program) different.
okay thanks for the tip not to combine script. it's idd another script i found out. sorry for the confusion. now i first have to find a solution for my domoticz, he is offline again. seems to be a problem with the new version: 4.10717
* raspberry pi3b+
* rooted toon 2
* rooted toon 2
- HansieNL
A few questions... if you allow me:
1. Should the Toon Auto Program switch set the status on the Toon Thermostat itself or does it only read from the Toon Thermostat?
2. If I set temperature by Toon Scene the setpoint changes correcly. After another minute the scene jumps to manual state. Is this the way it should work?
3. Toon program Information shows only a number. Is this correct?
Blah blah blah
- waaren
1. It only readsHansieNL wrote: ↑Wednesday 28 August 2019 13:47 A few questions... if you allow me:
2. Don't remember the details of this but do think Toon comes back with this state and the script follows.
3. Don't know this; As i do not own a Toon myself I developed this script together with @johan1974 who did all the testing and provided the required feedback. Best if he (or any other user of the script) could step in and answer this question and confirm or correct my answer on 2. and 3.
If you encounter an error that prevents the proper working of this script, I could off course try to work with you to get the script working error free again.
- HansieNL
I had a non rooted Toon and when I selected a scene the scene stayed selected till setpoint or scene was manually changed. How it’s working now is not logical to me. Don’t now why scene changes to manual after 1 minute. Would be great if you could help to solve this.waaren wrote: ↑Wednesday 28 August 2019 18:281. It only reads
- Spoiler: show
Blah blah blah
- waaren
Assuming you use this script on a rooted Toon (it will only work on a rooted one)HansieNL wrote: ↑Thursday 29 August 2019 2:27 I had a non rooted Toon and when I selected a scene the scene stayed selected till setpoint or scene was manually changed. How it’s working now is not logical to me. Don’t now why scene changes to manual after 1 minute. Would be great if you could help to solve this.
Can you switch on debug in your script and the dzVents loglevel to "Errors + minimal execution info + generic info" in [settings] [other]
and send the loglines from the beginning to the end of where the script is triggered (multiple times) and the rooted Toon reacts with the steps you don't understand and send the loglines to me as PM ?
Also mark the lines where you see the script behaving different then expected.
Thx
- madpatrick
- Domoticz version: 2024.7
1. Not using Auto Program. Setting the scene by Domoticz on certain times or actionsHansieNL wrote: ↑Wednesday 28 August 2019 13:47 A few questions... if you allow me:
2. This is correct. There is link between a temperature setpoint and Scene. Other way around of course is working
3. The number should be the temperature. You can add text your self
For example:
-- Updates the toon program information text box
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
-= HP server GEN8 Xeon(R) E3-1220L_V2 -=- OZW -=- Toon2 (rooted) -=- Domoticz v2024.7 -=- Dashticz v3.12b on Tab8" =-
- HansieNL
Thanks @madpatrick and @waaren for your help.
I use 2 scripts. Don't know how to make it using just one script. But it works for me ok. I'm using only 3 devices: Thermostat, Scenes and Temperature. I don't use scene states, so decided to use setpoint temperature to let switch the scenes.
toon_setpoint .lua
toon_script.lua
toon_setpoint .lua
devices = {
'Thermostaat'
domoticz.openURL(string.format('http://192.168.2.17/happ_thermstat?action=setSetpoint&Setpoint=%s', device.setPoint*100))
domoticz.log('Setting Toon setpoint to '.. device.setPoint)
logging = {
level = domoticz.LOG_FORCE, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
marker = "(Toon) "
timer = {
'every minute'
execute = function(domoticz)
local ToonThermostat = 'Thermostaat' -- Sensor showing current setpoint
local ToonScenes = 'Toons' -- Sensor showing current program
local ToonTemperature = 'Binnen' -- Sensor showing current room temperature
local ToonIP = '192.168.2.17'
-- Handle json
local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
-- Update the current temperature setpoint
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
currentTemperature = tonumber(string.format("%.1f", currentTemperature)) -- 1 decimaal is voldoende [PdB]
-- Update the current scene
local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100
if currentActiveTemp == 21 then currentActiveState = 40 -- Comfort
elseif currentActiveTemp == 19 then currentActiveState = 30 -- Home
elseif currentActiveTemp == 15 then currentActiveState = 20 -- Sleep
elseif currentActiveTemp == 12 then currentActiveState = 10 -- Away
else currentActiveState = 50 -- Manual
-- Update the thermostat sensor to current setpoint
if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
-- Update the temperature sensor to current room temperature
if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
-- Update the toon scene selector sensor to current program state
if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed
domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
Blah blah blah
