(rooted) Toon thermostat combined Get and Set script
Created for one of the Dutch forum members who experienced a problem with the two Lua scripts controlling the communication between a rooted Toon and domoticz after updating to a recent domoticz version. This script uses the same uservariables as the original Lua script. many thanks to @johan1974 for testing, patience and constructive feedback.
When switching from the Lua version to this one. Make sure you deactivate both Lua scripts and remove the actions from the selector switches.
  • uservariables used in this script
  • UV_ToonIP ............................................. -- Toon IP address
  • UV_ToonThermostatSensorName ................... -- virtual thermostat setpoint showing current setpoint
  • UV_ToonTemperatureSensorName .................. -- virtual temperature sensor showing current room temperature
  • UV_ToonScenesSensorName ......................... -- virtual selector switch showing current program
  • UV_ToonAutoProgramSensorName .................. -- virtual selector switch showing current auto program status
  • UV_ToonProgramInformationSensorName ......... -- virtual text sensor showing displaying program information status
Main advantage of this script is the use of the async communication between domoticz and Toon. No more blocking the eventsystem if Toon is busy Domoticz event system will just work on other fun stuff and gets signaled whenever Toon decides to answer :)
    Sync Domoticz sensors / switches with rooted Toon in case the value is changed on the physical device.
    Updates
        Thermostat Sensor
        Temperature Sensor
        Scenes switch based on program set on Toon
        (Auto)program switch to value set on Toon
        Program information text to value set on Toon
local toonResponse  = "toonResponse"
local ResponseOK    = "OK_toon_Response"
local scriptVersion = "version 0.117"
                on  =   { timer         = { "every minute"      },
                          devices       = { "Toon Thermostaat","Toon Scenes"  },
                          httpResponses = { toonResponse , ResponseOK      }},
           logging  =   {
                            level       =       domoticz.LOG_DEBUG,
                            marker      =       scriptVersion .. " Toon"
               data =   {
                            lastActive    = { initial = 0     },
                            isActive      = { initial = false },
                            blockSetPoint = { initial = false },   -- Bug in TimedCommands (silent() does not work in updateSetPoint
    execute = function(dz, item)
        local now = os.time(os.date('*t'))                  -- seconds since 1/1/1970 00:00:01
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function sendURL(url,callback)
            local toonIP = dz.variables("UV_ToonIP").value
            local url    = "http://" .. toonIP .. url
            dz.openURL({
                            url = url,
                            method = "GET",
                            callback = callback
        local function setSetPoint(device,setPoint) -- update setPoint
            if device.setPoint ~= setPoint then
                logWrite("Updating thermostat sensor to new set point: " .. setPoint )
                device.updateSetPoint(setPoint)
                dz.data.blockSetPoint = false
        local function setSelector(device,state,str) -- update selector
            if device.level ~= state and device.lastUpdate.secondsAgo > 59 then
                logWrite("Updating the " .. device.name .. " level to " .. str .. " (" .. state ..  ")")
                device.switchSelector(state).silent()
        local function setTemperature(device,temperature) -- Update temperature sensor
            if device.temperature ~= temperature then
                logWrite("Updating the temperature sensor to: " .. temperature)
                device.updateTemperature(temperature).silent()
        local function setText(device,text)    -- Update text sensor
            if device.text ~= text then
                logWrite("Updating " .. device.name .. " to: " .. text)
                device.updateText(text)
        local function setSetPointInfo(device,nextTime,setPoint)
            if nextTime == 0 or setPoint == 0 then
                newText = "Op " .. setPoint .. "°"
                newText = "Om " ..os.date("%H:%M", nextTime).. " naar " .. setPoint .. "°"
            setText(device,newText)
        local function setSceneState(device,state)
            local states       = { 50,40,30,20,10}  -- Manual, Comfort, Home, Sleep , Away
            local stateStrings = { "Manual", "Comfort", "Home", "Sleep" , "Away"}
            local newState     = states[state + 2]
            local stateString  = stateStrings[state + 2]
            setSelector(device,newState,stateString)
        local function setProgramState(device,state)
            local states       = { 10,20,30 }  -- No, Yes, Temporary
            local stateStrings = { "No", "Yes", "Temporary" }
            local newState     = states[state + 1]
            local stateString  = stateStrings[state + 1]
        local function updateDevices(rt)
            local toonThermostat            = dz.devices(dz.variables("UV_ToonThermostatSensorName").value)           -- Sensor showing current setpoint
            local toonTemperature           = dz.devices(dz.variables("UV_ToonTemperatureSensorName").value)          -- Sensor showing current room temperature
            local toonScenes                = dz.devices(dz.variables("UV_ToonScenesSensorName").value)               -- Sensor showing current program
            local toonAutoProgram           = dz.devices(dz.variables("UV_ToonAutoProgramSensorName").value)          -- Sensor showing current auto program status
            local toonProgramInformation    = dz.devices(dz.variables("UV_ToonProgramInformationSensorName").value)   -- Sensor showing displaying program information status
            setSetPoint     (toonThermostat,          dz.utils.round(rt.currentSetpoint / 100,1          ))
            setTemperature  (toonTemperature,         dz.utils.round(rt.currentTemp / 100,1              ))
            setSceneState   (toonScenes,              rt.activeState                                      )  -- "activeState":"-1" ==> 50
            setProgramState (toonAutoProgram,         rt.programState                                     )  -- "programState":"0" ==> 10
            setText         (toonProgramInformation,  dz.utils.round(rt.nextTime,rt.nextSetpoint / 100,1 ))
        local function procesToonResponse()
            logWrite(tostring(item.data))
            return dz.utils.fromJSON(item.data)
        local function sendSetPoint(newSetPoint)
            logWrite("In function sendSetPoint; " .. item.name .. " wants to set setPoint to " .. newSetPoint)
            local calculatedSetPoint = newSetPoint * 100
            local urlString = "/happ_thermstat?action=setSetpoint&Setpoint=" .. calculatedSetPoint
            if not dz.data.blockSetPoint then
                sendURL(urlString, ResponseOK )
                logWrite("Toon setPoint send using " .. urlString)
                logWrite("Toon setPoint not send ; unblocking now ")
        local function sendScene()
            local newstate
            logWrite("In function sendScene; " .. item.name .. "; level " .. item.level .. " ==>> " .. item.levelName)
            if item.level ==  0 then  -- Off
                sendSetPoint(60)
                return
            if      item.level == 10 then newState = 3       -- Away
            elseif  item.level == 20 then newState = 2       -- Sleep
            elseif  item.level == 30 then newState = 1       -- Home
            elseif  item.level == 40 then newState = 0       -- Comfort
            else                          newState = -1      -- Invalid
            local urlString = "/happ_thermstat?action=changeSchemeState&state=2&temperatureState=" .. newState
            logWrite("Toon SchemeState send using " .. urlString)
        local function getInfo()
            sendURL("/happ_thermstat?action=getThermostatInfo",toonResponse)
        -- Check for conflicts between timer and set Toon
        local function setActive(state)
            if state then
                logWrite("Triggered by device. Setting active")
                dz.data.isActive    = true
                dz.data.lastActive  = now
                dz.data.isActive    = false
                logWrite("Answer from Toon. Unset active")
        local function isFree()
            return (( dz.data.lastActive + 90 ) < now ) or ( not dz.data.isActive )
        local function writeStatus(origin)
            logWrite(origin .. "isFree:               " .. tostring(isFree()))
            logWrite(origin .. "lastActive:           " .. os.date("%X",dz.data.lastActive))
            logWrite(origin .. "blockSetPoint:        " .. tostring(dz.data.blockSetPoint))
        -- main program
        writeStatus("-- start -- ")
        if item.isDevice then                               -- triggered by selector or setPoint
            if item.name == "Toon Scenes" then
                sendScene()
                setActive(true)
                sendSetPoint(item.setPoint)
                setActive(true)
        elseif item.isTimer and isFree() then                    -- triggered by timer
                dz.data.blockSetPoint = true
                getInfo()
        elseif item.isHTTPResponse then                              -- Triggered by Toon response
            if item.trigger == toonResponse then                 -- return from getInfo()
                if item.ok and isFree() then                     -- statusCode == 2xx
                    updateDevices(procesToonResponse())
                elseif isFree() then
                    logWrite("Toon did not return valid data. Please check what went wrong. Error code: " .. item.statusCode or 999  ,dz.LOG_ERROR)
                    logWrite("Invalid data: " .. tostring(item.data))
                    logWrite("Toon is busy dealing with sendScene or sendSetPoint")
                logWrite("returned from sendScene or sendSetPoint: " .. tostring(item.data))
                setActive(false)
            logWrite("This should never happen")
        writeStatus("-- end -- ")
EdwinK
Re: Toon thermostat combined Get and Set script
Post by EdwinK »
Thanks for this. I used to use another version for hacked Toon's, but somehow that doesn't want to work for me. Going to give this a change.
EdwinK
Post by EdwinK »
Getting the below message.
019-01-23 11:35:01.139 Status: dzVents: Info: version 0.117 Toon: ------ Finished TOON
2019-01-23 11:36:00.539 Status: dzVents: Info: version 0.117 Toon: ------ Start internal script: TOON:, trigger: every minute
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: -- start -- isFree: true
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: -- start -- lastActive: 01:00:00
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: -- start -- blockSetPoint: true
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: OpenURL: url = http://192.168.0.4/happ_thermstat?action=getThermostatInfo
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: OpenURL: method = GET
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: OpenURL: post data = nil
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: OpenURL: headers = nil
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: OpenURL: callback = toonResponse
2019-01-23 11:36:00.540 Status: dzVents: Debug: version 0.117 Toon: -- end -- isFree: true
2019-01-23 11:36:00.541 Status: dzVents: Debug: version 0.117 Toon: -- end -- lastActive: 01:00:00
2019-01-23 11:36:00.541 Status: dzVents: Debug: version 0.117 Toon: -- end -- blockSetPoint: true
2019-01-23 11:36:00.541 Status: dzVents: Info: version 0.117 Toon: ------ Finished TOON
2019-01-23 11:36:00.920 Status: dzVents: Info: Handling httpResponse-events for: "toonResponse
2019-01-23 11:36:00.920 Status: dzVents: Info: version 0.117 Toon: ------ Start internal script: TOON: HTTPResponse: "toonResponse"
2019-01-23 11:36:00.920 Status: dzVents: Debug: version 0.117 Toon: -- start -- isFree: true
2019-01-23 11:36:00.921 Status: dzVents: Debug: version 0.117 Toon: -- start -- lastActive: 01:00:00
2019-01-23 11:36:00.921 Status: dzVents: Debug: version 0.117 Toon: -- start -- blockSetPoint: true
2019-01-23 11:36:00.921 Status: dzVents: Debug: version 0.117 Toon: {"result":"ok", "currentTemp":"2043", "currentSetpoint":"2000", "currentInternalBoilerSetpoint":"6", "programState":"1", "activeState":"1", "nextProgram":"1", "nextState":"0", "nextTime":"1548262800","nextSetpoint":"2000","randomConfigId":"1714636915","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
2019-01-23 11:36:00.927 Status: dzVents: Error (2.4.11): version 0.117 Toon: There is no device with that name or id:
2019-01-23 11:36:00.928 Status: dzVents: Error (2.4.11): version 0.117 Toon: There is no device with that name or id:
2019-01-23 11:36:00.929 Status: dzVents: Error (2.4.11): version 0.117 Toon: There is no device with that name or id:
2019-01-23 11:36:00.929 Status: dzVents: Error (2.4.11): version 0.117 Toon: An error occured when calling event handler TOON
2019-01-23 11:36:00.929 Status: dzVents: Error (2.4.11): version 0.117 Toon: ...e/pi/domoticz/scripts/dzVents/generated_scripts/TOON.lua:50: attempt to index local 'device' (a nil value)
2019-01-23 11:36:00.929 Status: dzVents: Info: version 0.117 Toon: ------ Finished TOON
EdwinK wrote: Wednesday 23 January 2019 11:35 Getting the below message.
Seems that the device names or numbers from the uservariables are not properly converted so that they can be used in the script.
Can you show the content of the uservariables ?
EdwinK
Post by EdwinK »
I now see I didn't enter any information in the 'Variable value:' part. 🤦
I see the following in the script
but a bit further:
 toonThermostat
 toonScenes
So, what do I need to have? Lost.
EdwinK
Post by EdwinK »
Error found, but can't seem to find it.
2019-01-24 11:06:00.587 Status: dzVents: Debug: version 0.117 Toon: {"result":"ok", "currentTemp":"2088", "currentSetpoint":"2000", "currentInternalBoilerSetpoint":"6", "programState":"1", "activeState":"1", "nextProgram":"1", "nextState":"0", "nextTime":"1548349200","nextSetpoint":"2000","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
Complete error-log (I hope):
2019-01-24 11:09:00.611 Status: dzVents: Info: Handling httpResponse-events for: "toonResponse
2019-01-24 11:09:00.611 Status: dzVents: Info: version 0.117 Toon: ------ Start internal script: TOON: HTTPResponse: "toonResponse"
2019-01-24 11:09:00.612 Status: dzVents: Debug: version 0.117 Toon: -- start -- isFree: true
2019-01-24 11:09:00.612 Status: dzVents: Debug: version 0.117 Toon: -- start -- lastActive: 01:00:00
2019-01-24 11:09:00.612 Status: dzVents: Debug: version 0.117 Toon: -- start -- blockSetPoint: true
2019-01-24 11:09:00.612 Status: dzVents: Debug: version 0.117 Toon: {"result":"ok", "currentTemp":"2091", "currentSetpoint":"2000", "currentInternalBoilerSetpoint":"6", "programState":"1", "activeState":"1", "nextProgram":"1", "nextState":"0", "nextTime":"1548349200","nextSetpoint":"2000","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
2019-01-24 11:09:00.636 Status: dzVents: Debug: version 0.117 Toon: Processing device-adapter for toonThermostat: Thermostat setpoint device adapter
2019-01-24 11:09:00.638 Status: dzVents: Debug: version 0.117 Toon: Processing device-adapter for toonTemperature: Temperature device adapter
2019-01-24 11:09:00.639 Status: dzVents: Debug: version 0.117 Toon: Processing device-adapter for toonScenes: Switch device adapter
2019-01-24 11:09:00.640 Status: dzVents: Debug: version 0.117 Toon: Processing device-adapter for toonAutoProgram: Switch device adapter
2019-01-24 11:09:00.641 Status: dzVents: Debug: version 0.117 Toon: Processing device-adapter for toonProgramInformation: Text device
2019-01-24 11:09:00.641 Status: dzVents: Debug: version 0.117 Toon: Updating the temperature sensor to: 20.9
2019-01-24 11:09:00.641 Status: dzVents: Debug: version 0.117 Toon: Updating the toonAutoProgram level to Yes (20)
2019-01-24 11:09:00.641 Status: dzVents: Debug: version 0.117 Toon: Constructed timed-command: Set Level 20
2019-01-24 11:09:00.641 Status: dzVents: Debug: version 0.117 Toon: Constructed timed-command: Set Level 20 NOTRIGGER
2019-01-24 11:09:00.642 Status: dzVents: Debug: version 0.117 Toon: Updating toonProgramInformation to: 1548349200
2019-01-24 11:09:00.642 Status: dzVents: Debug: version 0.117 Toon: -- end -- isFree: true
2019-01-24 11:09:00.642 Status: dzVents: Debug: version 0.117 Toon: -- end -- lastActive: 01:00:00
2019-01-24 11:09:00.642 Status: dzVents: Debug: version 0.117 Toon: -- end -- blockSetPoint: false
2019-01-24 11:09:00.642 Status: dzVents: Info: version 0.117 Toon: ------ Finished TOON
EdwinK
Post by EdwinK »
Devices:
Schermafbeelding 2019-01-24 om 11.13.27.png (116.9 KiB) Viewed 5123 times
UV:
Schermafbeelding 2019-01-24 om 11.14.44.png (59.22 KiB) Viewed 5123 times
EdwinK wrote: Thursday 24 January 2019 11:15 Devices:
UV:
Please double check names / variables. Special attention for spaces and use of UPPERCASE lowercase
EdwinK
Post by EdwinK »
I don't see it.
EdwinK wrote: Thursday 24 January 2019 20:41 I don't see it.
My bad. Did not notice you had two devices for some of the Toon stuff. What is the error you found ?
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
Line 184 and 185 are not correct. There is a space between by devics and not in UV
georon
Domoticz version: Bèta
Post by georon »
Waaren,
My complements on the way you have designed this LUA script.
Very nicely written and I really like that fact that you have created everything using functions.
This keeps your main program nice and small.
I really like it very much!
Currently not using it though, I had created my own version based on the original separated scripts.
EdwinK
Post by EdwinK »
madpatrick wrote: Friday 25 January 2019 9:51 Line 184 and 185 are not correct. There is a space between by devics and not in UV
This are my lines 184 and 185
       -- main program
madpatrick
EdwinK wrote: Tuesday 12 February 2019 21:01
       -- main program
In Devices
EdwinK
Post by EdwinK »
Ah... Didn't notice..
jbr79
Domoticz version: 4.10659
Post by jbr79 »
What are the prerequisites for using this script? This script is returning an error just connecting to the thermostat when I am trying to apply it...
jbr79 wrote: Monday 18 February 2019 7:53 What are the prerequisites for using this script? This script is returning an error just connecting to the thermostat when I am trying to apply it...
Probably @johan1974 is in the best position to answer this. Script was tested on his setup and I don't own a Toon myself.
What is the error you get ?
jbr79
Post by jbr79 »
irrespective of setting local LAN access to true or not, the error message is:
Error opening url: http://<IP>/happ_thermstat?action=getThermostatInfo
madpatrick
jbr79 wrote: Monday 18 February 2019 19:46 irrespective of setting local LAN access to true or not, the error message is:
Put your ip address at <IP>
The IP number of your Toon need to be entered in the uservariable UV_ToonIP. Look at the first post of this topic.
It would help if you show the loglines produced by this script.
