Moisture % XT300 keeps rising
Venzent
Domoticz version: 3.8153
Post by Venzent »
Just bought 2 XT300 soil moisture sensors for my plants.
The % humidity keeps rising instead of becoming less during the time. When I add water, I see a peak, some time later a drop and then again it starts rising.
Both the sensors acts the same.....
Any thoughts on this??
Schermafbeelding 2019-04-06 om 22.48.25.png (208.86 KiB) Viewed 1977 times
Nettime
Re: Moisture % XT300 keeps rising
Post by Nettime »
I think I read somewhere that they are autoadjusting, have patience :)
Nettime
Post by Nettime »
This is what one of my sensors show, guess my wife was away the 24'th.
"seems i snipped it a bit short, green is moisture."
Venzent
Post by Venzent »
Hi Nettime,
Thanks for the response. Lately the line seems to make more sense, the range is between 95% full wet, and 70% for dry.
I dont onderstand your trend. Slowely raising grom 24th april, and then a steady line. Do you water your plants daily?
giocaf
Post by giocaf »
also for my project I have some trouble with the opus/xt300 data sensor,
sometime data seems to be correct but in the next time the data goes wrong (temperature: -40, and channel 0). This because the rtl_433 receiver can analyze the wave but it can't decode the signal and catch 0 values for moisture, temperature and channel...(into the script the temp was tem= 0 - 40--> then -40)
in your opinion what are the causes of these wrong data?
thank you!
ccaru
Post by ccaru »
Hi All,
curious issue with the XT300 : I purchased one unit over a year ago which i found to be really good. Placed it outside and it worked consistently well throughout the year, through the hot months and cold months, so i just purchased an additional 3 units (with one to spare in case one gets broken).
All three units I received are showing a value of 99% for humidity, almost constantly. It sometimes goes down to perhaps 94 but it doesn't seem to be in relation with the wetness of the soil. I actually put my old one together with my new one and my old one is reading 32% while the new one, 99% as always. I would have put it down to a faulty unit but all three units are showing the same thing? Is it possible i've purchased all three from a faulty batch?
RFXCom, Somfy RTS, 433Mhz Lighting, Evohome, Smart watering via Netatmo, solenoid valves, soil humidity sensors, Airthings Radon via bluetooth, Marley heat recovery fresh air units, Blue Iris, Alexa via DA Bridge.
Tarzan737
Post by Tarzan737 »
how can you see 2 graphs in the same? im interested to do that as well!
Domoticz version: 2025.1
Tarzan737 wrote: Saturday 18 September 2021 19:14 how can you see 2 graphs in the same? im interested to do that as well!
You mean Temperature and moisture together? That will be shown if you open the log of the combined Temp+Hum device.
