Dashticz - Module - Calendar
pvklink
Domoticz version: latest b
Re: Dashticz - Module - Calendar
Post by pvklink »
@lokonli: problem solved. there werer no meetings for the selected agenda! Everythings works fine...
Jablotron connection, Ikea
Lokonli
Post by Lokonli »
pvklink wrote: Wednesday 20 February 2019 13:46 @lokonli: problem solved. there werer no meetings for the selected agenda! Everythings works fine...
ok, thanks for the update!
Dave47
Domoticz version: 2023.1
Post by Dave47 »
I have a file f1kalender.ics from my phone.
I put it in Dashticz folder.
Is it possible with module Calandar to make this vissible in Dashticz.
Which code do i need?
I have tried but it is not working
mvdheide01
Post by mvdheide01 »
Lokonli wrote: Monday 18 February 2019 19:46
mvdheide01 wrote: Sunday 17 February 2019 16:54 Hi,
I am trying just to display the google calendar as it shows in the "integrate calendar". So no tricks or formatting, just as it comes because i like that. Also my garbage calendar is included, the holidays etc.
I was able to show it in Dashticz, but after 1 minute or so, it is replace by the month view of a google calendar.
I have seen some posts on it and tried to put it together, but I am stuck.
How can i do that?
I tried to add a screenshot as attachement to this post but it keeps complaining that it is too large
Marcel
How did you add your calendar to Dashticz? Via a frame, or via a calendar block?
Can you post your calendar definition from your CONFIG.js here?
Thanks for replying,
Actually at this moment i don't know what my configuration was exactly and I ca't find that post anymore.
I had found a post that put it in a frame and remove the "<iframe src=" before the link and "></iframe>" from the end of the Google calendar link.
But at this moment every try does not display the page anymore. I should be displayed like for example the train info or news from nu.nl.
It would help to have a simple example that always would work to display.
Raspberry Pi, RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, OpenZWave USB
Lokonli
Post by Lokonli »
mvdheide01 wrote: Wednesday 20 February 2019 18:27
How can i do that?
Marcel
First, you have to find the correct link to your calendar. You can find them as follows:
open https://calendar.google.com/calendar
Under 'My calendars' click on the three dots behind your calendar -> settings and sharing
In the page that opens look for the following links:
Public URL to this calendar. It's something like: https://calendar.google.com/calendar/em ... FAmsterdam
I call this PublicURL
Secret address in ICAL format. It's something like: https://calendar.google.com/calendar/ic ... /basic.ics
I call this SecretICAL
There are several ways to display your google calendar:
1) Use a calendar block.
See https://www.domoticz.com/wiki/Dashticz_ ... -_Calendar
Set the icalurl parameter to SecretICAL
Set the url parameter to PublicURL
Precondition: You must use a recent beta, and have PHP enabled.
2) Use a frame:
In CONFIG.js:
var frames = {}
frames.calendar = { frameurl: 'PublicURL'}
columns[1] = {}
columns[1]['blocks'] = [
frames.calendar
3) Via a button
In CONFIG.js:
var buttons= {}
buttons.calendar = { url: 'PublicURL'}
columns[1] = {}
buttons.calendar
If you click the button your calendar will be shown in a popup window.
You can configure the frame and button via the usual parameters (title, width, height, icon, etc)
One of the advantages for method 1 is that you don't have to login into your Google account, so I would recommend that one.
Lokonli
Post by Lokonli »
Dave47 wrote: Wednesday 20 February 2019 15:24 I have a file f1kalender.ics from my phone.
yes, that is possible.
Define your calendar as follows in CONFIG.js:
calendars.example = {maxitems:4, icalurl:'/home/pi/dashticz_v2/f1kalender.ics'}
and then add calendars.example to a column.
You have to change the icalurl to the correct path for your ics file.
The ics file must have read permission set for the webserver-user (normally that's root)
mvdheide01
Lokonli wrote: Wednesday 20 February 2019 20:46
2) Use a frame:
In CONFIG.js:
var frames = {}
columns[1] = {}
frames.calendar
3) Via a button
In CONFIG.js:
var buttons= {}
columns[1] = {}
buttons.calendar
Great!
With this info, I at least have my previous results back.
I have used both options
1, with the calendar block using SecretICAL. That works ok but does not show my recurring appointments and the format is not like i want it (that i might be able to change in a css)
2, with iframe, this shows my combined calendar perfect, but only for one minute or so, then it is empty. You wrote something like I need to login to Google? Or do I need to set up an api key or something like that?
I would like option 2 to function :-)
Let me try if i can show my code
In CONFIG.js:
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/.......mic.be_.........group.calendar.google.com/private-....../basic.ics' }
var frames = {}
frames.calendar = { frameurl: 'https://calendar.google.com/calendar/embed?showTitle=0&amp;showNav=0&amp;showDate=0&amp;showPrint=0&amp;showTabs=0&amp;showCalendars=0&amp;showTz=0&amp;mode=AGENDA&amp;height=400&amp;wkst=2&amp;bgcolor=%23FFFFFF&amp;src=..........c.be_.........4%40group.calendar.google.com&amp;color=%2344a703&amp;src=en.be%23holiday%40group.v.calendar.google.com&amp;color=%23125A12&amp;src=.....%40import.calendar.google.com&amp;color=%23691426&amp;ctz=Europe%2FBrussels" style="border-width:0" width="400" height="400" frameborder="0" scrolling="no">'}
var columns = {}
columns[1]  = {}
columns[1]['blocks'] = [calendars.private]
columns[2] = {}
columns[2]['blocks'] = [frames.calendar]
Dave47
Post by Dave47 »
How can i change that, i dont understand?
Dashticz can not read my file!
I use
 var calendars = {}
Must i also use this or other other calendar config?
  config['calendarurl']
mvdheide01
mvdheide01 wrote: Thursday 21 February 2019 10:37
2) Use a frame:
In CONFIG.js:
var frames = {}
columns[1] = {}
frames.calendar
3) Via a button
In CONFIG.js:
var buttons= {}
columns[1] = {}
buttons.calendar
Great!
In CONFIG.js:
var calendars = {}
var frames = {}
var columns = {}
columns[1]  = {}
columns[2] = {}
I have switched to the calendar in block, which workes good, also the recurring events are there.
The only enhancement I would like to see is the order of the records.
Now when there there is a recurring appointment at 11:00 and a normal at 14:00, the 14:00 appointment is shown first.
Can this be included?
naitsirhc
Post by naitsirhc »
Is it possible to give items which will return in the calendar some colors, For example:
Birthday wil be written in blue
Dentist in yellow
etc.
Und Tschjuß
Lokonli
Post by Lokonli »
naitsirhc wrote: Tuesday 12 March 2019 17:29 Is it possible to give items which will return in the calendar some colors, For example:
Dentist in yellow
etc.
Do you mean coloring of recurring events, or give an event a color if it contains specific text?
naitsirhc
Post by naitsirhc »
Lokonli wrote: Tuesday 12 March 2019 18:36
Dentist in yellow
etc.
I would like to give the event a color if it contains a specific text, or even better...showing a icon and colored text
Und Tschjuß
TankySpanky
Post by TankySpanky »
Im starting to getting a headache of the Calendar thing......... Grrrr
I got the garbage working but the normal one seems to get blocked ( probally my mistake ) but i cant find it.
When i press F12 i get the following error
Refused to display 'https://accounts.google.com/ServiceLogin?service=cl&passive=*******&osid=1&continue=https://calendar.google.com/calendar/render&followup=https://calendar.google.com/calendar/render&scc=1' in a frame because it set 'X-Frame-Options' to 'deny'.
changed one number to ***
I placed in the .htaccess
"Header always unset X-Frame-Options"
But no fireworks with that...
"Pretty please" Help :)
Raspberry Pi 3 B+ & Domoticz Beta & Dashticz Beta = Headache :)
But it keeps you van the straat
Lokonli
Post by Lokonli »
TankySpanky wrote: Tuesday 26 March 2019 22:18 Im starting to getting a headache of the Calendar thing......... Grrrr
Which exact Dashticz version are you using?
(you find your Dashticz version if you click on the settings icon in the Dashticz topbar, and then on the info tab)
Do you use a server with PHP installed? Which PHP version is reported by Dashticz?
(you find your PHP version if you click on the settings icon in the Dashticz topbar, and then on the info tab)
You must have an (unmodified) recent beta version of Dashticz, with a PHP enabled webserver for the calendar to work.
How did you define your calendar in CONFIG.js?
TankySpanky
Hello ,
I have installed...
Dashticz Beta
Php 7.0.33-0+deb9u3
Apache2 webserver
I have copied the "private" link from google calendar in the place for the kalender URL ical
https://calendar.google.com/calendar/ical/***********%40gmail.com/private-************************/basic.ics
further i have some CSS changes for nothing strange
Edited the traffic.js info to show belgium traffic info
ty in advance
Lokonli
Post by Lokonli »
TankySpanky wrote: Wednesday 27 March 2019 16:55 Hello ,
I have installed...
Dashticz Beta
Php 7.0.33-0+deb9u3
Apache2 webserver
ty in advance
Just to be sure: Which Dashticz version are you using?
I'm not sure how you defined your calendar block in CONFIG.js, but my advice is to do it as follows:
var calendars = {}
calendars.me = { maxitems: 10,
  icon:'far fa-lightbulb',
  icalurl: 'https://calendar.google.com/calendar/ical/me%40gmail.com/private-12ab12ab12ab12ab12ab12ab/basic.ics'
and then add it to a column:
columns[1] = {}
  calendars.me
This should work ...
TankySpanky
Sorry i forgot Dashticz version
"version": "2.5.10",
"branch": "beta",
I have placed copied it as stated, but i do get the bar with the lightbulb :) but nothing below or next to it,
even make a app. for next saturday ( for private ) and it does nog show
All other things are not visable too
UPDATE:
Typo found
Its working now ...
crap i think i spend all together about 11 hours of copie paste type and redo / reinstall restart apache2 Name it...
/BOW /HUG
Lokonli
Post by Lokonli »
TankySpanky wrote: Wednesday 27 March 2019 20:43 Sorry i forgot Dashticz version
"branch": "beta",
UPDATE:
Typo found
Its working now ...
/BOW /HUG
Excellent!
For my curiosity: what was the typo?
Maybe I can improve the error handling in Dashticz ...
TankySpanky
Hello :)
Because i copy pasted the info u posted i pasted it and then copied my own ics url at the end which resulted in a double path to the google calendar
 icon:'far fa-calendar',  icalurl: 'https://calendar.google.com/calendar/ical/https://calendar.google.com/calendar/ical/aad.*****%40gmail.com/private-d***********/basic.ics
So it was totally my fault.
now i started to think if i can host my own calendar for the family :) so all access and one calendar to display :)
I can do the combined one for my wife's and mine i guess to start with :)
Now its working i can move on with it
ty again
TankySpanky
Works like a charm :)
calendars.combined = {}
calendars.combined.maxitems = 14;
calendars.combined.width = 6;
calendars.combined.icon = 'far fa-calendar';
calendars.combined.calendars = [
	{ color:'White',calendar:calendars.simone },
	{ color:'Yellow',calendar:calendars.aad }
calendars.combined.url = 'https://calendar.google.com/calendar';
