Dashticz - Module - Calendar
- Domoticz version: latest b
Re: Dashticz - Module - Calendar
@lokonli: problem solved. there werer no meetings for the selected agenda! Everythings works fine...
Jablotron connection, Ikea
- Target OS: -
- Domoticz version: 2023.1
I have a file f1kalender.ics from my phone.
I put it in Dashticz folder.
Is it possible with module Calandar to make this vissible in Dashticz.
Which code do i need?
I have tried but it is not working
Thanks for replying,Lokonli wrote: ↑Monday 18 February 2019 19:46How did you add your calendar to Dashticz? Via a frame, or via a calendar block?mvdheide01 wrote: ↑Sunday 17 February 2019 16:54 Hi,
I am trying just to display the google calendar as it shows in the "integrate calendar". So no tricks or formatting, just as it comes because i like that. Also my garbage calendar is included, the holidays etc.
I was able to show it in Dashticz, but after 1 minute or so, it is replace by the month view of a google calendar.
I have seen some posts on it and tried to put it together, but I am stuck.
How can i do that?
I tried to add a screenshot as attachement to this post but it keeps complaining that it is too large
Marcel
Can you post your calendar definition from your CONFIG.js here?
Actually at this moment i don't know what my configuration was exactly and I ca't find that post anymore.
I had found a post that put it in a frame and remove the "<iframe src=" before the link and "></iframe>" from the end of the Google calendar link.
But at this moment every try does not display the page anymore. I should be displayed like for example the train info or news from nu.nl.
It would help to have a simple example that always would work to display.
Raspberry Pi, RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, OpenZWave USB
First, you have to find the correct link to your calendar. You can find them as follows:mvdheide01 wrote: ↑Wednesday 20 February 2019 18:27Thanks for replying,Lokonli wrote: ↑Monday 18 February 2019 19:46How did you add your calendar to Dashticz? Via a frame, or via a calendar block?mvdheide01 wrote: ↑Sunday 17 February 2019 16:54 Hi,
How can i do that?
Marcel
open https://calendar.google.com/calendar
Under 'My calendars' click on the three dots behind your calendar -> settings and sharing
In the page that opens look for the following links:
Public URL to this calendar. It's something like: https://calendar.google.com/calendar/em ... FAmsterdam
I call this PublicURL
Secret address in ICAL format. It's something like: https://calendar.google.com/calendar/ic ... /basic.ics
I call this SecretICAL
There are several ways to display your google calendar:
1) Use a calendar block.
See https://www.domoticz.com/wiki/Dashticz_ ... -_Calendar
Set the icalurl parameter to SecretICAL
Set the url parameter to PublicURL
Precondition: You must use a recent beta, and have PHP enabled.
2) Use a frame:
In CONFIG.js:
var frames = {}
frames.calendar = { frameurl: 'PublicURL'}
columns[1] = {}
columns[1]['blocks'] = [
frames.calendar
In CONFIG.js:
var buttons= {}
buttons.calendar = { url: 'PublicURL'}
columns[1] = {}
buttons.calendar
You can configure the frame and button via the usual parameters (title, width, height, icon, etc)
One of the advantages for method 1 is that you don't have to login into your Google account, so I would recommend that one.
yes, that is possible.
Define your calendar as follows in CONFIG.js:
calendars.example = {maxitems:4, icalurl:'/home/pi/dashticz_v2/f1kalender.ics'}
You have to change the icalurl to the correct path for your ics file.
The ics file must have read permission set for the webserver-user (normally that's root)
Great!Lokonli wrote: ↑Wednesday 20 February 2019 20:46First, you have to find the correct link to your calendar. You can find them as follows:mvdheide01 wrote: ↑Wednesday 20 February 2019 18:27Thanks for replying,
2) Use a frame:
In CONFIG.js:3) Via a buttonCode: Select all
var frames = {} frames.calendar = { frameurl: 'PublicURL'} columns[1] = {} columns[1]['blocks'] = [ frames.calendar ]
In CONFIG.js:If you click the button your calendar will be shown in a popup window.Code: Select all
var buttons= {} buttons.calendar = { url: 'PublicURL'} columns[1] = {} columns[1]['blocks'] = [ buttons.calendar ]
With this info, I at least have my previous results back.
I have used both options
1, with the calendar block using SecretICAL. That works ok but does not show my recurring appointments and the format is not like i want it (that i might be able to change in a css)
2, with iframe, this shows my combined calendar perfect, but only for one minute or so, then it is empty. You wrote something like I need to login to Google? Or do I need to set up an api key or something like that?
I would like option 2 to function
Let me try if i can show my code
In CONFIG.js:
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/.......mic.be_.........group.calendar.google.com/private-....../basic.ics' }
var frames = {}
frames.calendar = { frameurl: 'https://calendar.google.com/calendar/embed?showTitle=0&showNav=0&showDate=0&showPrint=0&showTabs=0&showCalendars=0&showTz=0&mode=AGENDA&height=400&wkst=2&bgcolor=%23FFFFFF&src=..........c.be_.........4%40group.calendar.google.com&color=%2344a703&src=en.be%23holiday%40group.v.calendar.google.com&color=%23125A12&src=.....%40import.calendar.google.com&color=%23691426&ctz=Europe%2FBrussels" style="border-width:0" width="400" height="400" frameborder="0" scrolling="no">'}
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [calendars.private]
columns[2] = {}
columns[2]['blocks'] = [frames.calendar]
- Target OS: -
How can i change that, i dont understand?
Dashticz can not read my file!
I use
var calendars = {}
config['calendarurl']
I have switched to the calendar in block, which workes good, also the recurring events are there.mvdheide01 wrote: ↑Thursday 21 February 2019 10:37Great!Lokonli wrote: ↑Wednesday 20 February 2019 20:46First, you have to find the correct link to your calendar. You can find them as follows:mvdheide01 wrote: ↑Wednesday 20 February 2019 18:27
2) Use a frame:
In CONFIG.js:Code: Select all
var calendars = {} calendars.private = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/.......mic.be_.........group.calendar.google.com/private-....../basic.ics' } var frames = {} frames.calendar = { frameurl: 'https://calendar.google.com/calendar/embed?showTitle=0&showNav=0&showDate=0&showPrint=0&showTabs=0&showCalendars=0&showTz=0&mode=AGENDA&height=400&wkst=2&bgcolor=%23FFFFFF&src=..........c.be_.........4%40group.calendar.google.com&color=%2344a703&src=en.be%23holiday%40group.v.calendar.google.com&color=%23125A12&src=.....%40import.calendar.google.com&color=%23691426&ctz=Europe%2FBrussels" style="border-width:0" width="400" height="400" frameborder="0" scrolling="no">'} var columns = {} columns[1] = {} columns[1]['blocks'] = [calendars.private] columns[2] = {} columns[2]['blocks'] = [frames.calendar]
The only enhancement I would like to see is the order of the records.
Now when there there is a recurring appointment at 11:00 and a normal at 14:00, the 14:00 appointment is shown first.
Can this be included?
Is it possible to give items which will return in the calendar some colors, For example:
Birthday wil be written in blue
Dentist in yellow
etc.
Dentist in yellow
etc.
Und Tschjuß
I would like to give the event a color if it contains a specific text, or even better...showing a icon and colored text
Und Tschjuß
Im starting to getting a headache of the Calendar thing......... Grrrr
I got the garbage working but the normal one seems to get blocked ( probally my mistake ) but i cant find it.
When i press F12 i get the following error
changed one number to ***
I placed in the .htaccess
"Header always unset X-Frame-Options"
But no fireworks with that...
"Pretty please" Help
Refused to display 'https://accounts.google.com/ServiceLogin?service=cl&passive=*******&osid=1&continue=https://calendar.google.com/calendar/render&followup=https://calendar.google.com/calendar/render&scc=1' in a frame because it set 'X-Frame-Options' to 'deny'.
Raspberry Pi 3 B+ & Domoticz Beta & Dashticz Beta = Headache :)
But it keeps you van the straat
Which exact Dashticz version are you using?TankySpanky wrote: ↑Tuesday 26 March 2019 22:18 Im starting to getting a headache of the Calendar thing......... Grrrr
changed one number to ***Code: Select all
"Pretty please" Help![]()
(you find your Dashticz version if you click on the settings icon in the Dashticz topbar, and then on the info tab)
Do you use a server with PHP installed? Which PHP version is reported by Dashticz?
(you find your PHP version if you click on the settings icon in the Dashticz topbar, and then on the info tab)
You must have an (unmodified) recent beta version of Dashticz, with a PHP enabled webserver for the calendar to work.
How did you define your calendar in CONFIG.js?
Hello ,
I have installed...
Dashticz Beta
Php 7.0.33-0+deb9u3
Apache2 webserver
I have copied the "private" link from google calendar in the place for the kalender URL ical
further i have some CSS changes for nothing strange
Edited the traffic.js info to show belgium traffic info
ty in advance
I have installed...
Dashticz Beta
Php 7.0.33-0+deb9u3
Apache2 webserver
https://calendar.google.com/calendar/ical/***********%40gmail.com/private-************************/basic.ics
ty in advance
Just to be sure: Which Dashticz version are you using?TankySpanky wrote: ↑Wednesday 27 March 2019 16:55 Hello ,
I have installed...
Dashticz Beta
Php 7.0.33-0+deb9u3
Apache2 webserver
I have copied the "private" link from google calendar in the place for the kalender URL icalfurther i have some CSS changes for nothing strangeCode: Select all
ty in advance
I'm not sure how you defined your calendar block in CONFIG.js, but my advice is to do it as follows:
var calendars = {}
calendars.me = { maxitems: 10,
icon:'far fa-lightbulb',
icalurl: 'https://calendar.google.com/calendar/ical/me%40gmail.com/private-12ab12ab12ab12ab12ab12ab/basic.ics'
columns[1] = {}
calendars.me
Sorry i forgot Dashticz version
"version": "2.5.10",
"branch": "beta",
I have placed copied it as stated, but i do get the bar with the lightbulb
but nothing below or next to it,
even make a app. for next saturday ( for private ) and it does nog show
All other things are not visable too
UPDATE:
Typo found
Its working now ...
THANKS
crap i think i spend all together about 11 hours of copie paste type and redo / reinstall restart apache2 Name it...
/BOW /HUG
"branch": "beta",
UPDATE:
Typo found
Its working now ...
THANKS
/BOW /HUG
Excellent!TankySpanky wrote: ↑Wednesday 27 March 2019 20:43 Sorry i forgot Dashticz version
"branch": "beta",
I have placed copied it as stated, but i do get the bar with the lightbulbbut nothing below or next to it,
UPDATE:
Typo found
Its working now ...
THANKS![]()
/BOW /HUG
For my curiosity: what was the typo?
Maybe I can improve the error handling in Dashticz ...
Hello
Because i copy pasted the info u posted i pasted it and then copied my own ics url at the end which resulted in a double path to the google calendar
So it was totally my fault.
now i started to think if i can host my own calendar for the family
so all access and one calendar to display
I can do the combined one for my wife's and mine i guess to start with
Now its working i can move on with it
ty again
icon:'far fa-calendar', icalurl: 'https://calendar.google.com/calendar/ical/https://calendar.google.com/calendar/ical/aad.*****%40gmail.com/private-d***********/basic.ics
ty again
Works like a charm
calendars.combined = {}
calendars.combined.maxitems = 14;
calendars.combined.width = 6;
calendars.combined.icon = 'far fa-calendar';
calendars.combined.calendars = [
{ color:'White',calendar:calendars.simone },
{ color:'Yellow',calendar:calendars.aad }
calendars.combined.url = 'https://calendar.google.com/calendar';
