Python Plugin : EZJarviz Voice command plugin
zak45
- Domoticz version: V2024.4
Maybe time to share this one.
This is a Domoticz plugin for Jarvis@Home android application.
Features provided by the plugin are:
Voice command : activate your devices by your voice.
TTS : Text To Speech, let Domoticz speak to you.
Notification system : TTS and/or android notification.
Geofence : activate your devices when enter/leave Home.
Geolocalisation : send to Domoticz your localisation.
still some works to finalize it, but already usable.
Wiki : https://www.domoticz.com/wiki/Plugins/EZJarviz.html
enjoy.
enjoy.
Martial
Re: Python Plugin : EZJarviz Voice command plugin
Hello zak45,
I have to try this quickly!
Thank
Thank
zak45
Hi Martial,
feel free to provide feedback.
rgds
rgds
kniazio
- Domoticz version: 3.7243
2019-03-09 19:38:48.870 Error: (DomoVoice) 'onStart' failed 'KeyError'.
2019-03-09 19:38:48.870 Error: (DomoVoice) ----> Line 194 in '/home/pi/domoticz/plugins/EZJarviz/plugin.py', function onStart
2019-03-09 19:38:48.870 Error: (DomoVoice) ----> Line 1395 in '/home/pi/domoticz/plugins/EZJarviz/plugin.py', function grpDomoticz at the end of the configuration, reports an error
You can hear a message on the phone about a configuration error
I do not have any DomoVoice switches in Switches
- switches.jpg (153.6 KiB) Viewed 2018 times
- log.jpg (232.98 KiB) Viewed 2018 times
- jarvis.jpg (129.21 KiB) Viewed 2018 times
zak45
@kniazio
can you put debug mode on, reload the plugin and post the log ?
thanks
edit:
have been able to reproduce the case:
2019-03-09 22:11:39.345 Status: (DomoticZVoiceZ) Initialized version 1.0.0, author 'zak45'
2019-03-09 22:11:39.347 Status: (DomoticZVoiceZ) Entering work loop.
2019-03-09 22:11:39.391 Error: (DomoticZVoiceZ) 'onStart' failed 'KeyError'.
2019-03-09 22:11:39.391 Error: (DomoticZVoiceZ) ----> Line 194 in '/home/usr/domoticz/plugins/EZJarviz/plugin.py', function onStart
2019-03-09 22:11:39.391 Error: (DomoticZVoiceZ) ----> Line 1395 in '/home/usr/domoticz/plugins/EZJarviz/plugin.py', function grpDomoticz
2019-03-09 22:11:49.386 (DomoticZVoiceZ - 192.168.1.21:8181-M) Updating device from 1:'On' to have values 0:'Off'.
2019-03-09 22:11:49.397 (DomoticZVoiceZ) __we update 0:'Off' (DomoticZVoiceZ - 192.168.1.21:8181-M)__
this happen when yo do not have any scene/group device...
let's try to manually create these two scenes :
InHome & OutHome
re-edit
new version uploaded to manage the case & additional feature included
just download and replace plugin.py & Jarviz.py
thanks
edit:
InHome & OutHome
re-edit
zak45
new Web admin page in progress...
can be found here :
..\Domoticz\www\templates\EZJarviz.html
you need to enable custom page in Domoticz settings
can be found here :
zak45
and some additional API command.. see wiki !
kniazio
Thanks a lot
All devices in switches appeared
What this Custom page is for
Now you only have to learn how to handle it
- web.jpg (99.98 KiB) Viewed 1990 times
- dev.jpg (210.86 KiB) Viewed 1990 times
kniazio
It would be nice to have step by step instructions on how to add Switch to Jarvis
- addswitch.jpg (206.94 KiB) Viewed 1987 times
kniazio
How to load Polish into Jarvis?
I uploaded the en_pl.lng file and changed its name to en_en.lng. Jarvis still speaks to me in English. Only when uploading the configuration to the phone he speaks Polish
zak45
yep, will use it for different admin task e.g. jarvis password change --> need to be put in right format into uservariables etc...kniazio wrote: Sunday 10 March 2019 6:50 Thanks a lot
Now you only have to learn how to handle it![]()
but you can also see the outputs (txt & err) of the second running process, no need to browse plugin folder with scp or other sftp.
if you click on one *.txt file, this should open another tab with the content
zak45
all should be on the wiki.kniazio wrote: Sunday 10 March 2019 7:33 It would be nice to have step by step instructions on how to add Switch to Jarvis
zak45
what I see on your screenshot : Domoticz = english --> EZJarviz = englishkniazio wrote: Sunday 10 March 2019 8:27 How to load Polish into Jarvis?
so ...
and let me know if the wiki looks not clear, you really need to read it.
kniazio
I can not add my own switch to Jarvis.
I want to issue commands in Polish.
I'm Polish
https://www.domoticz.com/forum/download ... p?id=19368
I'm Polish
zak45
Hummm .. maybe some misunderstanding:kniazio wrote: Sunday 10 March 2019 15:59 I can not add my own switch to Jarvis.
I'm Polish
"I can not add my own switch to Jarvis." : not enough information provided to be able to help you but.. if you speak about this device specifically
, this one is a push On button no ?? this type is not yet managed....workaround should be easy to implement.
"I want to issue commands in Polish.I'm Polish"
--> this should work for Polish language, so what's your problem here ???
kniazio
I have a switch called "Kuchnia"
I turn it on in my kitchen.
What do you need to do to be able to control this switch with Jarvis?
zak45
you can try by changing its type : put it as on/off and set a off after 2 sec. should do the trick.kniazio wrote: Sunday 10 March 2019 20:15 I have a switch called "Kuchnia"
let's try.
zak45
Now with a Web Admin Page for plugin management:
https://www.domoticz.com/forum/viewtopi ... 65&t=27513
zak45
Now with On-Line Editor for language file :
