Python Plugin : EZJarviz Voice command plugin
zak45
Domoticz version: V2024.4
Post by zak45 »
Maybe time to share this one.
This is a Domoticz plugin for Jarvis@Home android application.
Features provided by the plugin are:
Voice command : activate your devices by your voice.
TTS : Text To Speech, let Domoticz speak to you.
Notification system : TTS and/or android notification.
Geofence : activate your devices when enter/leave Home.
Geolocalisation : send to Domoticz your localisation.
still some works to finalize it, but already usable.
Wiki : https://www.domoticz.com/wiki/Plugins/EZJarviz.html
enjoy.
Martial
Re: Python Plugin : EZJarviz Voice command plugin
Post by Martial »
Hello zak45,
I have to try this quickly!
Thank
zak45
Post by zak45 »
Hi Martial,
feel free to provide feedback.
rgds
kniazio
Domoticz version: 3.7243
Post by kniazio »
 2019-03-09 19:38:48.870 Error: (DomoVoice) 'onStart' failed 'KeyError'.
2019-03-09 19:38:48.870 Error: (DomoVoice) ----> Line 194 in '/home/pi/domoticz/plugins/EZJarviz/plugin.py', function onStart
2019-03-09 19:38:48.870 Error: (DomoVoice) ----> Line 1395 in '/home/pi/domoticz/plugins/EZJarviz/plugin.py', function grpDomoticz
the plugin creates a configuration on your phone
at the end of the configuration, reports an error
You can hear a message on the phone about a configuration error
I do not have any DomoVoice switches in Switches
zak45
Post by zak45 »
@kniazio
can you put debug mode on, reload the plugin and post the log ?
thanks
edit:
have been able to reproduce the case:
2019-03-09 22:11:39.345 Status: (DomoticZVoiceZ) Initialized version 1.0.0, author 'zak45'
2019-03-09 22:11:39.347 Status: (DomoticZVoiceZ) Entering work loop.
2019-03-09 22:11:39.391 Error: (DomoticZVoiceZ) 'onStart' failed 'KeyError'.
2019-03-09 22:11:39.391 Error: (DomoticZVoiceZ) ----> Line 194 in '/home/usr/domoticz/plugins/EZJarviz/plugin.py', function onStart
2019-03-09 22:11:39.391 Error: (DomoticZVoiceZ) ----> Line 1395 in '/home/usr/domoticz/plugins/EZJarviz/plugin.py', function grpDomoticz
2019-03-09 22:11:49.386 (DomoticZVoiceZ - 192.168.1.21:8181-M) Updating device from 1:'On' to have values 0:'Off'.
2019-03-09 22:11:49.397 (DomoticZVoiceZ) __we update 0:'Off' (DomoticZVoiceZ - 192.168.1.21:8181-M)__
this happen when yo do not have any scene/group device...
let's try to manually create these two scenes :
InHome & OutHome
re-edit :)
new version uploaded to manage the case & additional feature included
just download and replace plugin.py & Jarviz.py
zak45
Post by zak45 »
new Web admin page in progress...
can be found here :
..\Domoticz\www\templates\EZJarviz.html
you need to enable custom page in Domoticz settings
zak45
Post by zak45 »
and some additional API command.. see wiki !
kniazio
Post by kniazio »
Thanks a lot
All devices in switches appeared
What this Custom page is for
Now you only have to learn how to handle it :)
kniazio
Post by kniazio »
It would be nice to have step by step instructions on how to add Switch to Jarvis
kniazio
Post by kniazio »
How to load Polish into Jarvis?
I uploaded the en_pl.lng file and changed its name to en_en.lng. Jarvis still speaks to me in English. Only when uploading the configuration to the phone he speaks Polish
zak45
Post by zak45 »
kniazio wrote: Sunday 10 March 2019 6:50 Thanks a lot
yep, will use it for different admin task e.g. jarvis password change --> need to be put in right format into uservariables etc...
but you can also see the outputs (txt & err) of the second running process, no need to browse plugin folder with scp or other sftp.
if you click on one *.txt file, this should open another tab with the content ;-)
zak45
Post by zak45 »
kniazio wrote: Sunday 10 March 2019 7:33 It would be nice to have step by step instructions on how to add Switch to Jarvis
all should be on the wiki.
zak45
Post by zak45 »
kniazio wrote: Sunday 10 March 2019 8:27 How to load Polish into Jarvis?
what I see on your screenshot : Domoticz = english --> EZJarviz = english
so ...
and let me know if the wiki looks not clear, you really need to read it.
kniazio
Post by kniazio »
I can not add my own switch to Jarvis.
I want to issue commands in Polish.
I'm Polish
https://www.domoticz.com/forum/download ... p?id=19368
zak45
Post by zak45 »
kniazio wrote: Sunday 10 March 2019 15:59 I can not add my own switch to Jarvis.
I'm Polish
Hummm .. maybe some misunderstanding:
"I can not add my own switch to Jarvis." : not enough information provided to be able to help you but.. if you speak about this device specifically
, this one is a push On button no ?? this type is not yet managed....workaround should be easy to implement.
"I want to issue commands in Polish.I'm Polish"
--> this should work for Polish language, so what's your problem here ???
kniazio
Post by kniazio »
I have a switch called "Kuchnia"
I turn it on in my kitchen.
What do you need to do to be able to control this switch with Jarvis?
zak45
Post by zak45 »
kniazio wrote: Sunday 10 March 2019 20:15 I have a switch called "Kuchnia"
you can try by changing its type : put it as on/off and set a off after 2 sec. should do the trick.
let's try.
zak45
Post by zak45 »
Now with a Web Admin Page for plugin management:
https://www.domoticz.com/forum/viewtopi ... 65&t=27513
zak45
Post by zak45 »
Now with On-Line Editor for language file :
