Add new device Fibaro FGR-223 Roller Version 3
funmsa
Domoticz version: 2023.2
Post by funmsa »
Dear all,
I want to setup correctly my new Fibaro FGR-223 V3 on Domoticz but unfortunatly I can setup all parameters, look they aren't all recognize... why ? What I have to do to plainly setup my device ?
"FIBARO System Unknown: type=0303, id=1000" but not with all paramters only these (I try to re-add device and also reset it completly):
150. Parameter #150:
156. Parameter #156:
157. Parameter #157:
3001. Protection:
Is missing all paramters explain here in page 24 : https://manuals.fibaro.com/content/manu ... T-v1.0.pdf
In fact have the same problem with another Chinese device named "Wenzhou TKB Control System Unknown: type=0311, id=0303+", how to add paramters of new device not fully recognized by Domoticz ?
There is a full detailled list of supported and user whish list futur support ? How update the knowledge dictionnary of Domoticz easly to adding new device specifications ?
Best regards.
webrazor
Re: Add new device Fibaro FGR-223 Roller Version 3
Post by webrazor »
Is there any support yet for the new Roller Shutter 3 (FGR-223) from FIBARO?
Anybody using it yet, i want to buy a few?
yogui
Post by yogui »
Hello !
It seems that the device is now supported by OpenZwave : https://github.com/OpenZWave/open-zwave ... /ChangeLog
But nothing for the moment on Domoticz side.
yogui
Post by yogui »
After some search, and before than Domoticz to integrate module configuration, you could add it manually to your installation :
1°/ Download this file : https://github.com/OpenZWave/open-zwave ... fgr223.xml
And add it into the Config/fibaro directory
2°/ Add this line into the file Config/manufacturer_specific.xml on my side I've added it just below FGS223 configuration.
<Product type="0303" id="1000" name="FGR223 Roller Shutter Controller 3" config="fibaro/fgr223.xml"/>
Restart domoticz then remove and add your device. It will be recognized as a Fibaro FGR223 :)
Be careful on next update you will lose the line into Config/manufacturer_specific.xml file.
webrazor
Post by webrazor »
Ok so manual adding the device is possible.
Thank you
yogui
Post by yogui »
Yes and now this works fine even with Siri ;)
I will check to make a pull request on domoticz project to embeded these new devices for next beta
funmsa
Post by funmsa »
Dear Domoticz Support,
I finally instal Fibaro FGR-223 new Roller Shutter 3 on my Domoticz system. I had some painfull to add new xml OpenZWave but now is working well with all options. But I see a problem about percent opening status. Exemple :
Roller is close at 7% and I ask to go level 50% ...that work more or less fine because
1) Immediatly percent level gauge look 50% (instead 7%) on my Domoticz => Normal
2) Roller move from position 7% to 50% => Normal
3) But... percent level gauge on DOmoticz show again 7% (but roller is positionned on 50% like action was asked) => It's not normal !
My suspicion it's than Fibaro device fgr-223 send after the starting move the old position only (and never new percent position level) ... it's possible ? How to solve it ? Can Domoticz wait few milli seconds before to writeoff value ?
Best regards.
CYBEL
Post by CYBEL »
I installed the latest version of Domoticz on Debian.
I have the same problem when i try to include FGR-223 : "FIBARO System Unknown: type=0303, id=1000".
However, I had already the line "<Product type="0303" id="1000" name="FGR223 Roller Shutter Controller 3" config="fibaro/fgr223.xml"/>" in Config/manufacturer_specific.xml and the xml file in Config/fibaro.
I tried to install beta version of Domoticz but i have the same problem.
Have you got an idea ?
Thank'a a lot.
yan1950
Post by yan1950 »
Hello
Its the same for me.
I used the yogui's method but without any success...
Yannick
tiga
Post by tiga »
got the device working but same here with the slider.strange values.
josemi
Post by josemi »
Hello
Same behaviour here.
Slider does wierd things. :roll:
Did you manage to setup properly the FGR-223 in domoticz?
After including my fibaro FGR-223, many devices were shown up (see picture).
I added as switches with type Blinds Percentage the devices named as 'Level' of type Light/Switch in Devices tab. Is that right? Why are two Level devices? What is the purpose? :?:
This is my first Z-Wave device and I am lost.
josemi
Post by josemi »
I was fed up, and I gave up my Stick Gen5 and Fibaro to Amazon. I have wasted a lot of time. I am thinking about moving to Shelly.
Tmaster2018
Domoticz version: 4.10717
Post by Tmaster2018 »
I see that fibaro fgr 223 its part of domoticz/Config/manufacturer_specific.xml already. That means it's already compatible and full working? i just ordered from amazon some fibaro modules and now i'm seeing this terrifying reports from you :shock: :?
I hope that was solved , fibaro module now come with firmware 5.01 ... and i have latestest stable domoticz.
fransiefrans
Domoticz version: stable
Post by fransiefrans »
still the same issues with the newest firmware.
did the following:
In z-wave setup I only see 3001. Protection: as an option.. missing all the other options.
anyone any suggestions?
elmardam
Post by elmardam »
im using V4.11538 the device shows up correct.. but the roller shutter is still reporting wrong percentage values back to domoticz.. with a little pain.. it is working though..
alextime
Post by alextime »
elmardam wrote: Monday 23 December 2019 13:24 im using V4.11538 the device shows up correct.. but the roller shutter is still reporting wrong percentage values back to domoticz.. with a little pain.. it is working though..
Any news on this topic? Version 2 worked fine but I cannot find any FGR-222 anymore, I can only buy this new one model but it doesn’t work...
wahrens
Post by wahrens »
For myself i made a small workaround with an event to get the correct position:
I created a device event which resends the last position.
The counter is necessary because otherwise it would end in an endless loop.
devices = { 'Blind1' }
data = {
counter = { initial = 0 }
local level = device.level;
if (domoticz.data.counter == 0) then
domoticz.data.counter = 1
device.switchSelector(level).afterSec(20)
domoticz.data.counter = 0
Ronny
Post by Ronny »
Is this a dzvents script?
Ronny wrote:Is this a dzvents script?
Yes it is
Sjuul
Post by Sjuul »
Dear reader,
I had the Fibaro FGR-232 Roller version 3 (sw5.0 and 5.1) working on domoticz.
Last month the SDcard of my PI was corrupt. Backup doesn't work so the only way is to start install and configre. Now I use Domoticz 2020.2 on a PI4
Everything is gone well except include the Fibaro roller shutter 3.
I try a lot,
1. Fibaro module back to factory settings
2. Look if the XML file is in the config directory
3. Install a new Fibaro module including still not possible.
Has someone a working solution?
