Add new device Fibaro FGR-223 Roller Version 3
funmsa
- Domoticz version: 2023.2
Dear all,
I want to setup correctly my new Fibaro FGR-223 V3 on Domoticz but unfortunatly I can setup all parameters, look they aren't all recognize... why ? What I have to do to plainly setup my device ?
"FIBARO System Unknown: type=0303, id=1000" but not with all paramters only these (I try to re-add device and also reset it completly):
150. Parameter #150:
156. Parameter #156:
157. Parameter #157:
3001. Protection:
Is missing all paramters explain here in page 24 : https://manuals.fibaro.com/content/manu ... T-v1.0.pdf
In fact have the same problem with another Chinese device named "Wenzhou TKB Control System Unknown: type=0311, id=0303+", how to add paramters of new device not fully recognized by Domoticz ?
There is a full detailled list of supported and user whish list futur support ? How update the knowledge dictionnary of Domoticz easly to adding new device specifications ?
Best regards.
3001. Protection:
Best regards.
webrazor
Re: Add new device Fibaro FGR-223 Roller Version 3
Is there any support yet for the new Roller Shutter 3 (FGR-223) from FIBARO?
Anybody using it yet, i want to buy a few?
Hello !
It seems that the device is now supported by OpenZwave : https://github.com/OpenZWave/open-zwave ... /ChangeLog
But nothing for the moment on Domoticz side.
After some search, and before than Domoticz to integrate module configuration, you could add it manually to your installation :
1°/ Download this file : https://github.com/OpenZWave/open-zwave ... fgr223.xml
And add it into the Config/fibaro directory
2°/ Add this line into the file Config/manufacturer_specific.xml on my side I've added it just below FGS223 configuration.
<Product type="0303" id="1000" name="FGR223 Roller Shutter Controller 3" config="fibaro/fgr223.xml"/>
Restart domoticz then remove and add your device. It will be recognized as a Fibaro FGR223
Be careful on next update you will lose the line into Config/manufacturer_specific.xml file.
webrazor
Ok so manual adding the device is possible.
Thank you
Thank you
Yes and now this works fine even with Siri
I will check to make a pull request on domoticz project to embeded these new devices for next beta
funmsa
Dear Domoticz Support,
I finally instal Fibaro FGR-223 new Roller Shutter 3 on my Domoticz system. I had some painfull to add new xml OpenZWave but now is working well with all options. But I see a problem about percent opening status. Exemple :
Roller is close at 7% and I ask to go level 50% ...that work more or less fine because
1) Immediatly percent level gauge look 50% (instead 7%) on my Domoticz => Normal
2) Roller move from position 7% to 50% => Normal
3) But... percent level gauge on DOmoticz show again 7% (but roller is positionned on 50% like action was asked) => It's not normal !
My suspicion it's than Fibaro device fgr-223 send after the starting move the old position only (and never new percent position level) ... it's possible ? How to solve it ? Can Domoticz wait few milli seconds before to writeoff value ?
Best regards.
Best regards.
I installed the latest version of Domoticz on Debian.
I have the same problem when i try to include FGR-223 : "FIBARO System Unknown: type=0303, id=1000".
However, I had already the line "<Product type="0303" id="1000" name="FGR223 Roller Shutter Controller 3" config="fibaro/fgr223.xml"/>" in Config/manufacturer_specific.xml and the xml file in Config/fibaro.
I tried to install beta version of Domoticz but i have the same problem.
Have you got an idea ?
Thank'a a lot.
Thank'a a lot.
Hello
Its the same for me.
I used the yogui's method but without any success...
Yannick
Yannick
tiga
got the device working but same here with the slider.strange values.
josemi
Hello
Same behaviour here.
Slider does wierd things.
Did you manage to setup properly the FGR-223 in domoticz?
After including my fibaro FGR-223, many devices were shown up (see picture).
I added as switches with type Blinds Percentage the devices named as 'Level' of type Light/Switch in Devices tab. Is that right? Why are two Level devices? What is the purpose?
This is my first Z-Wave device and I am lost.
josemi
I was fed up, and I gave up my Stick Gen5 and Fibaro to Amazon. I have wasted a lot of time. I am thinking about moving to Shelly.
Tmaster2018
- Domoticz version: 4.10717
I see that fibaro fgr 223 its part of domoticz/Config/manufacturer_specific.xml already. That means it's already compatible and full working? i just ordered from amazon some fibaro modules and now i'm seeing this terrifying reports from you
I hope that was solved , fibaro module now come with firmware 5.01 ... and i have latestest stable domoticz.
fransiefrans
- Domoticz version: stable
still the same issues with the newest firmware.
did the following:
anyone any suggestions?
did the following:
In z-wave setup I only see 3001. Protection: as an option.. missing all the other options.1°/ Download this file : https://github.com/OpenZWave/open-zwave ... fgr223.xml
im using V4.11538 the device shows up correct.. but the roller shutter is still reporting wrong percentage values back to domoticz.. with a little pain.. it is working though..
alextime
Any news on this topic? Version 2 worked fine but I cannot find any FGR-222 anymore, I can only buy this new one model but it doesn’t work...elmardam wrote: Monday 23 December 2019 13:24 im using V4.11538 the device shows up correct.. but the roller shutter is still reporting wrong percentage values back to domoticz.. with a little pain.. it is working though..
wahrens
For myself i made a small workaround with an event to get the correct position:
I created a device event which resends the last position.
The counter is necessary because otherwise it would end in an endless loop.
devices = { 'Blind1' }
data = {
counter = { initial = 0 }
local level = device.level;
if (domoticz.data.counter == 0) then
domoticz.data.counter = 1
device.switchSelector(level).afterSec(20)
domoticz.data.counter = 0
data = {
Ronny
Is this a dzvents script?
- waaren
Yes it isRonny wrote:Is this a dzvents script?
Sjuul
Dear reader,
I had the Fibaro FGR-232 Roller version 3 (sw5.0 and 5.1) working on domoticz.
Last month the SDcard of my PI was corrupt. Backup doesn't work so the only way is to start install and configre. Now I use Domoticz 2020.2 on a PI4
Everything is gone well except include the Fibaro roller shutter 3.
I try a lot,
1. Fibaro module back to factory settings
2. Look if the XML file is in the config directory
3. Install a new Fibaro module including still not possible.
Has someone a working solution?
I try a lot,
