RFXtrx433E Somfy support is gone on 4.9700 stable version
jmartinr64
Domoticz version: 4.10.419
Post by jmartinr64 »
Hi guys
Due to a SD crash issue on my previus installation ( I had running 3.8153 stable version)- I have done a new installation on last domoticz stable version, however when I tried to setup RFXtrx433E for my Somfy awning I seen Somfy support has gone
Do you know somebody how to support again Somfy devices ?
Thank you very much for your support
b_weijenberg
Re: RFXtrx433E Somfy support is gone on 4.9700 stable version
Post by b_weijenberg »
Somfy RTS is not received and no need to enable a protocol for this.
Manually create the Somfy RFY devices on the Switches tab.
Use RFXmngr to know the ID and unit numbers you have used. On the RFY tab transmit a "List Remotes" command.
RFX-433, RFX-433EMC, RFX-868
bjacobse
Post by bjacobse »
