Hi guys
Due to a SD crash issue on my previus installation ( I had running 3.8153 stable version)- I have done a new installation on last domoticz stable version, however when I tried to setup RFXtrx433E for my Somfy awning I seen Somfy support has gone
Do you know somebody how to support again Somfy devices ?
Thank you very much for your support
RFXtrx433E Somfy support is gone on 4.9700 stable version
- jmartinr64
- Domoticz version: 4.10.419
- Capture.JPG (58.13 KiB) Viewed 1654 times
- Capture_0.JPG (42.96 KiB) Viewed 1654 times
b_weijenberg
- Target OS: -
Re: RFXtrx433E Somfy support is gone on 4.9700 stable version
Somfy RTS is not received and no need to enable a protocol for this.
Manually create the Somfy RFY devices on the Switches tab.
Use RFXmngr to know the ID and unit numbers you have used. On the RFY tab transmit a "List Remotes" command.
RFX-433, RFX-433EMC, RFX-868
