Connect KaKu modules without a remote
rvmourik
Hi There,
I use to have a Kaku remote, and connected all my devices with the learning mode from Domoticz after pairing the remote with a kaku module.
Quick question:
Remote died, and i don''t want to by a new one. I believe it's possible to pair rfxcom/domoticz with kaku modules without the remote. Anyone can give me a quick hint on how to do this?
Thanks in advance.
Robbert
Quick question:
Thanks in advance.
Robbert
- gizmocuz
Re: Connect KaKu modules without a remote
Sure thats possible...
From the switches page, click on 'Manual Light/Switch',
and specify:
- the correct hardware (rfxcom),
- name
- switch type: On/Off
- protocol: AC
- Enter a unique ID, like 1 23 45 67
- unit code (1)
Now set your kaku in learn mode (for instance plug it into the power)
now press the TEST button in domoticz, and it should be paired
Next save your switch by clicking 'Add Device'
and specify:
- name
- protocol: AC
- unit code (1)
rvmourik
Couldn't be anymore clearer, thanksgizmocuz wrote:Sure thats possible...
and specify:
- name
- protocol: AC
- unit code (1)
Quick follow-up question:
I have a KaKu wall-switch (double) http://www.klikaanklikuit.nl/shop/nl/du ... awst-8802/
Is it possible to let Domoticz do an action once, one of the buttons is pressed? So instead of pairing the switch directly to a KaKu module, let Domoticz do something once on of the buttons is pressed?
Thanks in advance.
Robbert
- coolwine1962
- Domoticz version: 2020.1
Yes, make a group, learn (pair) the switch in the group, and define an action via domoticz for the group switch.
I use this method to switch on zwave via kaku switch.
Beste regards
Jan Arie Koelewijn
Beste regards
Jan Arie Koelewijn
1 x Raspberry Pi4 Raspbian
1 x ANT GP433Mhz
1 x Rfxcom
1 x RainSensor
1 x Kaku Doorbel
1 X Aeon Z-Wave USB Stick
25 x Fibaro WallPlug
2 x ZRC90
2 x Aeotec MultiSensor
6 x zWave Greenwave 6
4 x zWave Greenwave 1
1 x Pi slave for Electra and Gas
1 x ANT GP433Mhz
1 x Rfxcom
1 x RainSensor
1 x Kaku Doorbel
2 x ZRC90
rvmourik
Will try that thanks!coolwine1962 wrote:Yes, make a group, learn (pair) the switch in the group, and define an action via domoticz for the group switch.
Beste regards
Jan Arie Koelewijn
vodor
Thanks for this post. Got my kaku switches today. Was wondering how I was going to get them paired. After about 3 minutes of scratching head I googled and found this post. Very helpful and my switch worked first time.
- mvveelen
This is the easies way of adding the switches, but.....I can't anymore. I thought I had a broken switch, but a second and a third can't be added as well. I allowed new devices for 5 minutes, set the AC protocol and chose a random code to add them. When I hit the TEST button, it should 'click', but nothing happens. Weird.
b_weijenberg
- Target OS: -
Try with 1005 firmware.
If no response from the module it is possible that all 6 remote slots in the module are already used. Reset the module and try again.
RFX-433, RFX-433EMC, RFX-868
- mvveelen
I just discovered that the slots were taken. After a reset everything went fine. Thanks
DuDo
strange i have a kaku doorbell and i did what is decribed above i also get the double tone when a command for learning is accepted on the doorbell
both when i then send it nothing happend the doorbell does not respond
have the volume set to high and selected a doorbel tone before hand.. but nothing
the logs files do show me the command is send but the doorbell does not sound
11MeG
- Domoticz version: v3.8661
I have the same problem but how do I reset the module without a remote?mvveelen wrote: Sunday 29 May 2016 18:20 I just discovered that the slots were taken. After a reset everything went fine. Thanks![]()
HP thin client with ubuntu 16.04
Domoticz V3.8661
USB P1 cable on c.h.i.p. with ser2net
Philips hue with hue/ikea lamps
KaKu switches
sonoff swittches and th sensors
RFXtrx433E USB 433.92MHz Transceiver
Opentherm gateway (work in progress)
Domoticz V3.8661
KaKu switches
