Connect KaKu modules without a remote
rvmourik
Post by rvmourik »
Hi There,
I use to have a Kaku remote, and connected all my devices with the learning mode from Domoticz after pairing the remote with a kaku module.
Quick question:
Remote died, and i don''t want to by a new one. I believe it's possible to pair rfxcom/domoticz with kaku modules without the remote. Anyone can give me a quick hint on how to do this?
Thanks in advance.
Robbert
gizmocuz
Re: Connect KaKu modules without a remote
Post by gizmocuz »
Sure thats possible...
From the switches page, click on 'Manual Light/Switch',
and specify:
- the correct hardware (rfxcom),
- name
- switch type: On/Off
- protocol: AC
- Enter a unique ID, like 1 23 45 67
- unit code (1)
Now set your kaku in learn mode (for instance plug it into the power)
now press the TEST button in domoticz, and it should be paired
Next save your switch by clicking 'Add Device'
rvmourik
Post by rvmourik »
gizmocuz wrote:Sure thats possible...
and specify:
- name
- protocol: AC
- unit code (1)
Couldn't be anymore clearer, thanks :D
Quick follow-up question:
I have a KaKu wall-switch (double) http://www.klikaanklikuit.nl/shop/nl/du ... awst-8802/
Is it possible to let Domoticz do an action once, one of the buttons is pressed? So instead of pairing the switch directly to a KaKu module, let Domoticz do something once on of the buttons is pressed?
Thanks in advance.
Robbert
coolwine1962
Domoticz version: 2020.1
Post by coolwine1962 »
Yes, make a group, learn (pair) the switch in the group, and define an action via domoticz for the group switch.
I use this method to switch on zwave via kaku switch.
Beste regards
Jan Arie Koelewijn
1 x Raspberry Pi4 Raspbian
1 x ANT GP433Mhz
1 x Rfxcom
1 x RainSensor
1 x Kaku Doorbel
1 X Aeon Z-Wave USB Stick
25 x Fibaro WallPlug
2 x ZRC90
2 x Aeotec MultiSensor
6 x zWave Greenwave 6
4 x zWave Greenwave 1
1 x Pi slave for Electra and Gas
rvmourik
Post by rvmourik »
coolwine1962 wrote:Yes, make a group, learn (pair) the switch in the group, and define an action via domoticz for the group switch.
Beste regards
Jan Arie Koelewijn
Will try that thanks!
vodor
Post by vodor »
Thanks for this post. Got my kaku switches today. Was wondering how I was going to get them paired. After about 3 minutes of scratching head I googled and found this post. Very helpful and my switch worked first time. :)
mvveelen
Post by mvveelen »
This is the easies way of adding the switches, but.....I can't anymore. I thought I had a broken switch, but a second and a third can't be added as well. I allowed new devices for 5 minutes, set the AC protocol and chose a random code to add them. When I hit the TEST button, it should 'click', but nothing happens. Weird.
b_weijenberg
Post by b_weijenberg »
Try with 1005 firmware.
If no response from the module it is possible that all 6 remote slots in the module are already used. Reset the module and try again.
RFX-433, RFX-433EMC, RFX-868
mvveelen
Post by mvveelen »
I just discovered that the slots were taken. After a reset everything went fine. Thanks ;)
DuDo
Post by DuDo »
strange i have a kaku doorbell and i did what is decribed above i also get the double tone when a command for learning is accepted on the doorbell
both when i then send it nothing happend the doorbell does not respond
have the volume set to high and selected a doorbel tone before hand.. but nothing
the logs files do show me the command is send but the doorbell does not sound
11MeG
Domoticz version: v3.8661
Post by 11MeG »
mvveelen wrote: Sunday 29 May 2016 18:20 I just discovered that the slots were taken. After a reset everything went fine. Thanks ;)
I have the same problem but how do I reset the module without a remote?
HP thin client with ubuntu 16.04
Domoticz V3.8661
USB P1 cable on c.h.i.p. with ser2net
Philips hue with hue/ikea lamps
KaKu switches
sonoff swittches and th sensors
RFXtrx433E USB 433.92MHz Transceiver
Opentherm gateway (work in progress)
Users browsing this forum: eddieb and 1 guest
