@tileiran: Did you post this? Why?tileiran wrote: Thursday 20 December 2018 7:05 o you appreciate my work and want to buy me a beer?
Send:
- XVG to D8fwNbyV6YxJk1aSiXftWTtdaPipsKn2Fa
- ANY ERC20-TOKEN to 0x9b8ee84329d77765a28bca188218c6c793875a8a
Lokonli
Wolfgang
just starting with dashticz and getting no infos from domoticz , the clock and the openweather on screen 1 is working fine , but the other infos from domoticz ( 623 is a temp sensor ) is not seen on the dashboard , any suggestions ?
CONFIG:js
CONFIG:js
- Spoiler: show
- Spoiler: show
- Spoiler: show
- Minglarn
- Domoticz version: v3.8153
Is it possible to flash the content in the DIV when it changes value etc?
Just like in Domoticz when value changes..
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
- HansieNL
@Wolfgang What version of Dashticz are you using?
You have old and new variabeles in your config.js???
Blah blah blah
Wolfgang
@HansieNL
Thanks for reply , this was only a try because of no clue why there are no values from domoticz shown on the screens ...
I'm using the 2.5.1 version of dashticz on a rapi 3 and version V4.10215 of domoticz on a another raspi.
- HansieNL
@Wolfgang My advice is to start with a default config.js and see if that works. This is the basic start to see if connection is working ok. If that works you can start customizing your Dashticz dashboard.
Blah blah blah
Wolfgang
@HansieNL
Thanks for reply , I've narrowed the error a little bit, its a little bit strange the device 369 is displayed, the device 382 and the following devices are not displayed . I debugged with wireshark and in the url
http://192.168.251.225:8080/json.htm?us ... order=Name
the data is displayed ... strange
- Spoiler: show
Wolfgang
@HansieNL
I'm steps further now , thanks for the support and i think it was a typo ...
sgsdebruijn
Does someone know why i cann't edit Dasticz in the browser? The save button is not working?!
- HansieNL
You can only save if you got PHP running and the config.js is writable.
Blah blah blah
sgsdebruijn
Any tipc&tricks?HansieNL wrote: Tuesday 01 January 2019 20:14 You can only save if you got PHP running and the config.js is writable.
sgsdebruijn
Working, editted the properties of the config.js filesgsdebruijn wrote: Tuesday 01 January 2019 20:28Any tipc&tricks?HansieNL wrote: Tuesday 01 January 2019 20:14 You can only save if you got PHP running and the config.js is writable.
Derik
- Domoticz version: BETA
Dear All..
Try to rebuid my "old" dash to new settings..
Install the last beta....
Only i get some stuff not working:
First the color and the icons
I use:
And in the custom css:
Why is the icon not response on the margin
Why is the color not changing?
edit:
Perhaps some have a solution to use in 1 dash multiple width?
I want a setup 1 dash with:
2 device from the top, the second under the first, a in column 12 width
then 3 times a columns 4 width
And perhaps when possible to set 2 columns 6 width..
Hope there is some..
I use:
blocks['s11'] = {}
blocks['s11']['width'] = 2;
blocks['s11']['title'] = 'Eet'; // schakelt groep eetkamer fel
blocks['s11']['icon'] = 'fas fa-toggle-on';
blocks['s11']['switch'] = true;
blocks['s11']['hide_data'] = true;
blocks['s11']['show_lastupdate'] = false;
blocks['s11']['protected'] = false;
.fas fa-toggle-on { color: yellow;}
.fas fa-toggle-on:before { font-size: 30px;}
.fas fa-toggle-on { margin-top: 15px ;margin-left: 1px;}
edit:
pvm
- Domoticz version: 4.10538
I think you missed adding !important in the css
alarm_guy1
Hi guys, just getting into Dashticz, Looking to create a Single Large button to control 1 switch and Maybe a scene too.
I can seem to make my switch wider but not fatter.
I have cut the Config right down,
The item in Question is a Dimmer, and literally I want it as an on/off switch for this scenario, so you can just come in and touch the screen without
looking particularly and switch the light off (as we do with a switch), so my problem is 2 fold how do I make Dashticz see it as a switch and how do I make it Fill the screen.
Screen Shot attached of how it is presently
Cheers
var config = {}
config['domoticz_ip'] = 'http://xxx.xxx.xxx.xx:xxx';
config['dashticz_refresh'] = '1';
config['auto_positioning'] = '0';
config['user_name'] = '';
config['pass_word'] = '';
var publictransport = {}
var tvguide = {}
var _STREAMPLAYER_TRACKS = [
var buttons = {}
var blocks = {}
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',34]
columns[1]['width'] = 5;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = []
var screens = {}
screens[1] = {}
screens[1]['background'] = 'background_sea.jpg';
screens[1]['columns'] = [1,]looking particularly and switch the light off (as we do with a switch), so my problem is 2 fold how do I make Dashticz see it as a switch and how do I make it Fill the screen.
Cheers
- screenshot.jpg (349.11 KiB) Viewed 5300 times
- HansieNL
@alarm_guy1 :
What if you create a dummy on/off switch in Domoticz and use that one in Dashticz.
Blah blah blah
alarm_guy1
Could do, never thought of that, just need to know how to make it taller now
cheers
cheers
alarm_guy1
dummy switch sorted and working cheers...
- HenriM
A couple of questions to the experts. I tried to search and try out myself but did not find all answers.
1. Change colors of block graphs.
I found that I can configure the graph output of graph block with (hidden) configuration setting (e.g. config['lineColors'] = ['#e00', 'rgba(0,15,0, 0.4)']; ). Can other properties be done via CSS as well?
I already found out that next CSS code has effect:
How can I change the other colors in the graph?
To be honest I prefer the graph output of Domoticz much better.
2. Is it possible to have lines without the measure-points itself (e.g. make them invisible with alpha-channel value 0 in CSS)? Especially when you have many measurements in a day this makes the graph ugly.
3. I have 'gas' bock (from P1 Smartmeter) and applicable 'gas' graph block on my dashboard. I have set 'gas' block to protected, but I can still click it. When I do so the 'gas' graph disappears from the dashboard and the popped up graph does not show anything.
/* Change colors of pop-up graph */
#graphoutput {
background: black;
color:white;
.graphpopup {
background: black;
color:white;
}To be honest I prefer the graph output of Domoticz much better.
rgroothuis
Multiple Screens - button to navigate between screens
I've two screens, swiping between the two screens is not going that smooth, probably because of the performance of the table.
I want to add a button to switch to the next screen. And on the second screen I want to add a button to switch back to the main screen. How can I add those buttons to jump screens? Is that possible? Somebody has an example?
And secondly, after an X amount of time, the setup is always moving back to the main screen. How can I make this longer or even completely stop this. In other words that I stay on the second screen until I move it myself back to the main screen?
