Dashticz - Feature Requests
Locked
HansieNL
Re: Dashticz - Feature Requests
Post by HansieNL »
Hello Rob,
Is it possible to have the following options added to the block section?
blocks[IDX]['TextOn'] -> text shown when switch is on
blocks[IDX]['TextOff'] -> text shown when switch is off
blocks[IDX]['IconOn'] -> image shown when switch is on
blocks[IDX]['IconOff'] -> image shown when switch is off
Blah blah blah
DewGew
Domoticz version: V4.10618
Post by DewGew »
HansieNL wrote: Wednesday 27 June 2018 22:43 Hello Rob,
Do you want the icon to show only when device is on or off?
Is it state text you want to change with custom text?
There is a message function:
blocks[IDX]['messageOn'] -> text shown right lower corner when switch is on
blocks[IDX]['messageOff'] -> text shown right lower corner when switch is off
HansieNL
Post by HansieNL »
Do you want the icon to show only when device is on or off? No, I wanna use different icons for on and of.
Is it state text you want to change with custom text? Yep, that's what I mean.
I have several blocks in custom.js. Now I have to edit 2 files to get things done. This is one for example:
//Microfoon
function getBlock_147(device,idx){
   $('.block_'+idx).attr('onclick','switchDevice(this)');
   var html='';
   html+='<div class="col-xs-4 col-icon">';
      if(device['Status']=='Off') html+=iconORimage(idx,'fa-microphone-slash','','off icon');
      else html+=iconORimage(idx,'fa-microphone','','on icon');
   html+='</div>';
   html+='<div class="col-xs-8 col-data">';
   html+='<strong class="title">'+device['Name']+'</strong><br />';
   if(device['Status']=='Off') html+='<span class="state">STIL</span>';
   else html+='<span class="state">LUISTEREN</span>';
   html+='</div>';
   return html;
Blah blah blah
Vomera
Post by Vomera »
Sorry for the long time to repost, but thank you for this feature!!
Now i can reduce the code :)
On the wiki is the right way to use it!
DewGew wrote: Tuesday 19 June 2018 10:08
HansieNL wrote: Monday 18 June 2018 23:32
DewGew wrote: Monday 18 June 2018 23:09
Function is added to latest beta
Can you tell us how to use this function? Or is it gonna be added to the wiki shortly?
I have add this to wiki also.
Open a popup when a device changes to on:
blocks[IDX]['openpopupOn'] = {}
blocks[IDX]['openpopupOn']['url'] = 'http://www.urltocamera.nl/image.jpg';
blocks[IDX]['openpopupOn']['auto_close'] = 5; //seconds
Open a popup when a device changes to off
blocks[IDX]['openpopupOff'] = {}
blocks[IDX]['openpopupOff']['url'] = 'http://www.urltocamera.nl/image.jpg';
blocks[IDX]['openpopupOff']['auto_close'] = 5; //seconds
AlleyCat
Post by AlleyCat »
Hi Rob,
Fantastic application.
I have a feature request:
var _STREAMPLAYER_TRACKS
1) Can you add an auto-play option? It can be triggered by a Domoticz switch state change.
2) Can the auto-play have enabled/disable option
3) When switching stations, the new station starts playing, instead of pushing the Play.
Thank you,
Alley Cat
AlleyCat
Post by AlleyCat »
Hi again,
Please find another feature request. I wanted to keep the requests threads separate.
On Domoitcz motion sensor state change, send xset command to turn the LCD on (from screensaver), the same as if to turn-on LCD with by a touch.
Thank you,
Alley Cat
AlleyCat
Post by AlleyCat »
Hi Again,
I have another feature request that came as a result because of my LCD touchscreen panel went bad. Since I am no longer have a touchscreen I plan to send the screen to a regular TV over HDMI. To control the screen I plan to use an IR remote (lirc of flirc). I will need to be able to change the buttons focus with the keystroke movements (left, right, up, down, enter).
How to set the buttons to having focus (for the enter), and move the focus between the buttons?
Alley Cat
Thuis
Post by Thuis »
I have a feature request, i am just new here, so who am i?
I live in the south of Holland, i am a 42 y.o dad of 2 little girls, my name is Jeroen and I am a plc/hmi programmer with a mechanical background in engines and vehicles. My hobbies are o.a. domotica, electric cycling, CLicks®, Duplo® and LEGO® :lol:
My old X-10 system is getting out dated, so I am trying something new with Xiaomi, LED Wifi dimmers and sonoff and some different sensors.
Just got a new smart meter installed, and I like to change my thermostat for a Tado, in a short while.
Stumbled upon Domoticz and on the very nice Dashticz theme for controlling it all.
I have learned a lot from you guys and girls, by reading many posts and now i like to implement a "Diashow" when Dashticz goes into "standby after" .
Could it be possible to start a diashow when the standby kicks in ? And would it be a nice feature, if this is possible?
Will be monitoring the comments,
Jeroen@Thuis.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
Prutsium
Post by Prutsium »
Thuis wrote: Tuesday 11 September 2018 15:31 I have a feature request, i am just new here, so who am i?
Jeroen@Thuis.
This can already be done if you have an Android tablet and use Fully Kiosk browser.
Can also be triggered by remote:
[IP:2323]/?cmd=startScreensaver&password=[pass]
[IP:2323]/?cmd=stopScreensaver&password=[pass]
The same counts for screen on/off via Domoticz this can also be done by Fully Kiosk Browser.
[IP:2323]/?cmd=screenOn&password=[pass]
[IP:2323]/?cmd=screenOff&password=[pass]
Thuis
Post by Thuis »
Nice, okay, when I am as far to using an Android tablet, i will surely try this out. Thank you.
Thuis
Post by Thuis »
What am i doing wrong ?
127.0.0.1:8080/#/Dashboard works on the server side
192.168.0.11:8080/#/#Dashboard works on the server side
127.0.0.1:8080/dashticz works on the server side
192.168.0.11:8080/dashticz not working on server side, saying something wrong with my config.js, but it is ok, really.
on other client pc's in the same network i can browse to domoticz address and see the standard domoticz dashboard, obviously, no dashticz dashboard.
In my config.js i have:
config['domoticz_ip'] = 'http://192.168.0.11:8080';
Thuis
Post by Thuis »
Got it, in the index.html i had to change 127.0.0.1 to 192.168.0.11 all good ! :rolling-eyes:
moses123
Domoticz version: latest b
Post by moses123 »
I used the openpopupOn and openpopupOff settings to inform the user that something happend. This works, the problem is, that i use the raspberrypi 7" display. It has a height of 480px. The popup has a fixed height of 570px. Is it possible to add a feature to configure the height of an popup?
Bye,
Moses123
Recky
Domoticz version: Latest
Post by Recky »
I have a request. Could you add the option to show the balance of the (anonymous) OV card?
https://www.ov-chipkaart.nl/saldo-terug ... hecker.htm#/
jake
Post by jake »
Recky wrote:I have a request. Could you add the option to show the balance of the (anonymous) OV card?
That is a very interesting one. We have two of those anonymous cards laying around at home and it is always guesswork how much is still on which card.
TapNL
Post by TapNL »
really like this idea. Did some quick research, there is done some work in this direction, check GitHub:
https://github.com/OVChip/ovchipapi-node
https://github.com/OVChip/ovchipapi-python
I will give it a try this week.
HansieNL
Post by HansieNL »
Is it possible to have a User Variable block with the following options to show variable values?
blocks[vIDX] = {}
blocks[vIDX]['width'] = 4;
blocks[vIDX]['title'] = 'Variable Name'
blocks[vIDX]['image'] = 'whateveryoulike.png';
blocks[vIDX]['icon'] = 'whateveryoulike';
blocks[vIDX]['switch'] = true;
See also https://github.com/Dashticz/dashticz_v2/issues/377
Blah blah blah
ArthurNL
Domoticz version: 4.10717
Post by ArthurNL »
I am using 2 Youless Energymeters (http://www.youless.nl/). 1 for measuring Electricity and 1 for Gas.
In the default Domoticz dashboard, they are seen as two separate devices, the one for Electricity using kWh and the one for Gas using m3.
But in Dashticz, they both show kWh.
When I search in main.js, I only see the YouLess Meter one time with the kWh as SubType.
Is it possible to add an second entry for detecting the one for gas too?
Dashticz V2.4.0 Beta
ArthurNL
Post by ArthurNL »
ArthurNL wrote: Saturday 06 October 2018 16:13 Is it possible to add an second entry for detecting the one for gas too?
Fixed this myself. I am filtering on the Device-Name instead of Sub-Type.
In main.js, the function getYouLessBlock is changed as follows;
function getYouLessBlock(device, idx) {
this.html = '';
if (device['Name'] === 'Electra Meter') {
if ($('div.block_' + idx).length > 0) {
allblocks[idx] = true;
var blockValues = [
icon: 'fas fa-bolt',
idx: idx + '_1',
title: device['Name'],
value: number_format(device['CounterToday'].split(' ')[0], settings['units'].decimals.kwh),
unit: settings['units'].names.kwh
idx: idx + '_2',
title: language.energy.energy_totals + ' ' + device['Name'],
value: number_format(device['Counter'], settings['units'].decimals.kwh),
if (typeof(device['Usage']) !== 'undefined') {
blockValues.push({
idx: idx + '_3',
value: number_format(device['Usage'], settings['units'].decimals.watt),
unit: settings['units'].names.watt
createBlocks(blockValues, device);
return ['', false];
if (device['Name'] === 'Gas Meter') {
var blockValues = [
icon: 'fas fa-fire',
idx: idx + '_1',
unit: 'm3'
idx: idx + '_2',
unit: 'm3'
blockValues.push({
idx: idx + '_3',
value: number_format(device['Usage'].split(' ')[0], settings['units'].decimals.kwh),
unit: 'm3'
return ['', false];
The only ugly part, is that I also use ".decimals.kwh" in the gasmeter part; but this works for me :)
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
moses123 wrote: Saturday 15 September 2018 8:16 Hi,
Bye,
Moses123
+1 for this!
Locked
