Ashram56 wrote: Tuesday 02 October 2018 17:24
Good Morning,
Completely new to Domoticz (currently using Jeedom), I wanted to install it on my Synology NAS (a DS1618+), however it looks like your server (and as a result your repository) are down ?
Best regards
DS1618+ use arch-denverton
Only beta for now...
Manual install.
domoticz_denverton-6.2_4.0.10032-7.spk
Here: http://www.jadahl.com
I have seen above that we can modify start-stop-status to send syslog to another file location
But I want to send the log to the Synology log center ?
so you thing it is possible ?
I thinked to change that :
LOGFILE="${INSTALL_DIR}/var/domoticz.log"
or do I change su ${USER} -c "${DOMOTICZ} -www ${PORT} -wwwroot ${WWWROOT} -sslwww ${RSSLPORT} -sslcert ${RSSLCERT} -approot ${INSTALL_DIR}/ -userdata ${INSTALL_DIR}/var/ -dbase ${DB_FILE} &> $LOGFILE
& echo \$! > ${PID_FILE}"
nono212 wrote: Sunday 07 October 2018 14:04
Hello Jumbotroll
I have a question for the domoticz.log
but to what ?
Sorry, I have not tested this..
You can't do anything wrong by testing, i worst case you have to reinstall domoticz so remember to take backup
Gravityz wrote: Sunday 14 October 2018 19:55
v4.10064 fixes gas/energy/water meter read outs which were experiencing a lot of extra digits (which was introduced in the last 5x version i think)
Is possible to keep styles catalogue under update?
or I need to copy this cat and restore after update?
I have themes icons and custom settings pages, which i need to update after update.
Best Regards
Synology NAS
Heating: eq-3 MAX!
Vent: by Sonoff POW R2 & Espeasy
Cam: Foscam C1
frxtrx433XL implementation seems to be done.
any idea which build i need (probably higher then 10085) because i see a commit on the 24th of october and 10085 is 23 october
Gravityz wrote: Wednesday 24 October 2018 16:15
like to try it out to see if it works.
Do you want test with or without python plugin version?
What synology do you want to test it on and I can compile for you..
Gravityz wrote: Thursday 25 October 2018 12:48
got feedback that is should work in version 10100.
is it possible to build that one DS718+ appololake 6.2 WITHOUT Python(same as previous version)
domoticz_apollolake-6.2_4.0.10101-7.spk is uploaded..
