domoticz in synology as package! Available now.
jumbotroll
Post by jumbotroll »
Ashram56 wrote: Tuesday 02 October 2018 17:24 Good Morning,
Completely new to Domoticz (currently using Jeedom), I wanted to install it on my Synology NAS (a DS1618+), however it looks like your server (and as a result your repository) are down ?
Best regards
DS1618+ use arch-denverton
Only beta for now...
Manual install.
domoticz_denverton-6.2_4.0.10032-7.spk
Here: http://www.jadahl.com
https://paypal.me/Jumbotroll
Jumbotroll
Ashram56
Post by Ashram56 »
Many thanks, will test right away
nono212
Domoticz version: 3.6179
Post by nono212 »
Hello Jumbotroll
I have a question for the domoticz.log
I have seen above that we can modify start-stop-status to send syslog to another file location
But I want to send the log to the Synology log center ?
so you thing it is possible ?
I thinked to change that :
LOGFILE="${INSTALL_DIR}/var/domoticz.log"
or do I change su ${USER} -c "${DOMOTICZ} -www ${PORT} -wwwroot ${WWWROOT} -sslwww ${RSSLPORT} -sslcert ${RSSLCERT} -approot ${INSTALL_DIR}/ -userdata ${INSTALL_DIR}/var/ -dbase ${DB_FILE} &> $LOGFILE
& echo \$! > ${PID_FILE}"
but to what ?
jumbotroll
nono212 wrote: Sunday 07 October 2018 14:04 Hello Jumbotroll
but to what ?
Sorry, I have not tested this..
You can't do anything wrong by testing, i worst case you have to reinstall domoticz so remember to take backup :?
Jumbotroll
nono212
Post by nono212 »
Thnanks for your updated Jumbotroll
In that situation i am going not to play with config of Domoticz ...As it becomes critical home ...
I have another idea
what do you thing about using logger to send all domoticz.log lines to syslog ?
But I have no clue how to do that ...
Gravityz
Domoticz version: 2022.2
Post by Gravityz »
v4.10064 fixes gas/energy/water meter read outs which were experiencing a lot of extra digits (which was introduced in the last 5x version i think)
jumbotroll
Gravityz wrote: Sunday 14 October 2018 19:55 v4.10064 fixes gas/energy/water meter read outs which were experiencing a lot of extra digits (which was introduced in the last 5x version i think)
DSM 6.2 packages is updated to v4.10064 beta.
Jumbotroll
Gravityz
Post by Gravityz »
thanks.
tested v4.10064 and can confirm counter bug is fixed
now waiting for the P1 meter implementation for the RFXtrx433XL(which i have)
currently using wifi to read out my meter but that option needs an 5v adapter
michass
Domoticz version: 4.10064
Post by michass »
Hi Jumbotroll!
Synocommunity has problem with armada37xx loolchain, maybe you can help?
https://github.com/SynoCommunity/spksrc/issues/3477
Synology NAS
Heating: eq-3 MAX!
Vent: by Sonoff POW R2 & Espeasy
Cam: Foscam C1
jumbotroll
michass wrote: Monday 22 October 2018 8:27 Hi Jumbotroll!
I don't know why synology has removed toolchain from sourceforge, but I did download toolchain and kernel for armada37xx last month.
Jumbotroll
michass
Post by michass »
Hi Jumbotroll!
Once again me :D
Is possible to keep styles catalogue under update?
or I need to copy this cat and restore after update?
I have themes icons and custom settings pages, which i need to update after update.
Best Regards
Synology NAS
Heating: eq-3 MAX!
Cam: Foscam C1
Gravityz
Post by Gravityz »
frxtrx433XL implementation seems to be done.
any idea which build i need (probably higher then 10085) because i see a commit on the 24th of october and 10085 is 23 october
like to try it out to see if it works.
jumbotroll
Gravityz wrote: Wednesday 24 October 2018 16:15 frxtrx433XL implementation seems to be done.
Do you want test with or without python plugin version?
What synology do you want to test it on and I can compile for you..
Jumbotroll
Gravityz
Post by Gravityz »
Without python plugin
i have a DS718+ (apollolake)
jumbotroll
Gravityz wrote: Wednesday 24 October 2018 16:45 Without python plugin
domoticz_apollolake-6.2_4.0.10089-7.spk is uploaded :-)
Jumbotroll
Gravityz
Post by Gravityz »
ok. will test
Gravityz
Post by Gravityz »
well tested but totally not working.
will report my findings to the domoticz community
Gravityz
Post by Gravityz »
got feedback that is should work in version 10100.
is it possible to build that one DS718+ appololake 6.2 WITHOUT Python(same as previous version)
jumbotroll
Gravityz wrote: Thursday 25 October 2018 12:48 got feedback that is should work in version 10100.
domoticz_apollolake-6.2_4.0.10101-7.spk is uploaded..
Jumbotroll
Gravityz
Post by Gravityz »
thanks.
it is getting better but still not working.
Users browsing this forum: Jeakes and 1 guest
