Other question. I have 2 gateways connectec with a VPN.
Recently i must add the second gateway to detect the new devices. it detects the gateway with mp3,volume,etc... and a termometer
But not detects the door sensor and inmersion sensor. I force the status of this devices (on/off, several times) but the domoticz not detect the sensors.
i use the port 9898 for the gateway and receive info of temperature, i thing this works but not detect the other sensor
Anyone have this problem??
- Domoticz version: latest
@CLEMENT99, @lolomin, @DAVIZINHO
having read the logs, it is not yet clear in what cases this or that event is happening ... I ordered a pair of such devices to understand how they work
Great, thanks a lot!
edit: In the mihome app i can see 3 types of accion:
- Object is touched
- Object drops
- tilt detected
This night i will enable the log again and i will try to identify with of this acction apears in log an the info in the log for each acction.
Hello ak97
I obtain this info and maybe is interesting to you:
In myhome i find 3 diferent action for this sensor y I force this action and see the domoticz log
- Object is touched:
- Object drops2 examples:
2018-09-24 20:03:23.689 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:03:23.689 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"vibrate\"}"}
2018-09-24 20:04:29.883 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:04:29.883 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"vibrate\"}"}
- tilt detected2 examples:
2018-09-24 20:06:25.345 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:06:25.345 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"free_fall\"}"}
2018-09-24 20:06:26.427 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:06:26.428 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"92,118,-783\"}"}
2018-09-24 20:12:19.667 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:12:19.667 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"free_fall\"}"}
2018-09-24 20:12:21.825 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:12:21.826 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"116,-113,1136\"}"}
2 examples:
2018-09-24 20:05:00.339 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:05:00.339 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"tilt\"}"}
2018-09-24 20:05:00.342 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:05:00.342 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"final_tilt_angle\":\"34\"}"}
2018-09-24 20:05:01.412 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:05:01.412 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"-62,-642,917\"}"}
2018-09-24 20:05:13.539 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:05:13.539 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"tilt\"}"}
2018-09-24 20:05:13.543 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:05:13.543 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"final_tilt_angle\":\"33\"}"}
2018-09-24 20:05:13.563 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-24 20:05:13.563 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"-104,-31,1137\"}"}
So I bought a second hand Xiaomi Gateway and installed it today. Everything working fine. Next up is to add a couple of humidity/temp/airpressure sensors around the house and see if I can get that working.
- Ascari
- Domoticz version: 4.9
Any updaate for Vima Door Lock ?
recently i have this error but all works fine (i have 2 xiaomi gateway):
any idea?
apears allways on startup
2018-10-11 11:13:11.106 Error: XiaomiGateway: received data from unregisted gateway!
- Domoticz version: BETA
I also have the same problem, have 3 pieces in domoticz involved, all synonymous, only after the restart, these errors come
DAVIZINHO wrote: ↑Thursday 11 October 2018 11:35 recently i have this error but all works fine (i have 2 xiaomi gateway):any idea?Code: Select all
this is not a xiaomi problem, this is a domoticz problem - it initializes plugins too slowly, but gateways send information all the time ... this error is not a problem and has not yet come up with an elegant solution for this.
Perfect is good to know it. I Will ignore this error. Thanks!!ak97 wrote: ↑Saturday 13 October 2018 9:42DAVIZINHO wrote: ↑Thursday 11 October 2018 11:35 recently i have this error but all works fine (i have 2 xiaomi gateway):any idea?Code: Select all
apears allways on startupthis is not a xiaomi problem, this is a domoticz problem - it initializes plugins too slowly, but gateways send information all the time ... this error is not a problem and has not yet come up with an elegant solution for this.
Do you have any news abiut the vibration sensor?
After upgrading to 4.970 Xiaomi devices got strange Actions and Levels names.Buttons/Switchs not working anymore.
Before update everything works fine.
http://ge.tt/9qMtCDs2
Edit: sorry, i didn't clean browser cache. now everything is fine.
Hi !
I'm having problem adding a second gateway.
I have been using a single gateway with around 20 sensors for a couple of months and it works perfect.
I followed the guide in the Wiki for adding the second gateway but it doesn't show up.
I get this in the log after reboot: "NOT LISTENING TO UDP FOR HARDWARE ID" and ID is the same as my second gateway.
I tried pressing "Accept new hardware" under settings but that didn't help either.
The second gateway works fine in the Mi Home app.
Latest stable Domoticz version and latest firmware on gateway.
Any tips on how to troubleshoot this problem?
I think the second gateway only Works in beta not stable. But im not sure
Hi all. I got a Vima Doorlock cylinder. Without the app its a great device on its own. According to the documentation I should be able to add it to my MI HOME app. But it is missing. On internet I read it disappeared with the latest update. Anyone can check if they can add the lock and sent me the region and version?
If you select the server "mainlad china" not appears??dvangeld wrote: ↑Monday 15 October 2018 15:52 Hi all. I got a Vima Doorlock cylinder. Without the app its a great device on its own. According to the documentation I should be able to add it to my MI HOME app. But it is missing. On internet I read it disappeared with the latest update. Anyone can check if they can add the lock and sent me the region and version?
It did, till the last update......DAVIZINHO wrote: ↑Monday 15 October 2018 15:54If you select the server "mainlad china" not appears??dvangeld wrote: ↑Monday 15 October 2018 15:52 Hi all. I got a Vima Doorlock cylinder. Without the app its a great device on its own. According to the documentation I should be able to add it to my MI HOME app. But it is missing. On internet I read it disappeared with the latest update. Anyone can check if they can add the lock and sent me the region and version?
Can you see it on your home app?
Hello,dvangeld wrote: ↑Tuesday 16 October 2018 9:30It did, till the last update......DAVIZINHO wrote: ↑Monday 15 October 2018 15:54If you select the server "mainlad china" not appears??dvangeld wrote: ↑Monday 15 October 2018 15:52 Hi all. I got a Vima Doorlock cylinder. Without the app its a great device on its own. According to the documentation I should be able to add it to my MI HOME app. But it is missing. On internet I read it disappeared with the latest update. Anyone can check if they can add the lock and sent me the region and version?
You must go to gateway and add it. Not apears in devices in principal menu but apears in add devices in gateway menu. I dont understand....
Huh! You are absolutely right! I thought it was under Add Device....
Am @ work now. Will try tonite
Thx !
Working!dvangeld wrote: ↑Tuesday 16 October 2018 14:34Huh! You are absolutely right! I thought it was under Add Device....
Thx !
Pitty it only shows unlock actions and only with a key. I would like to know if the door is locked!
Is the lock supported by Domoticz?
I finally received my 6 Aqara TBH sensors. I want to place them in the bathroom, bedrooms and also one in my son's terarium. Regarding the rooms: what is a good position to get reliable temperature readings? I remember reading somewhere that a thermostat should be placed about 1.5 m from the floor for reliable temp readings. Anybody any advice on this?
