I want to set the variable (JSON) - "HaveTimeout" but I don't find the correct parameters for the URL.
I check the Wiki and try some parameter but not working, if you can help me please
Thx
Set TimeOut Variable
- jvdz
- Domoticz version: 4.107
Re: Set TimeOut Variable
What URL have you tried that isn't working?
What did it return when you tried?
Jos
Jos
- Ascari
- Domoticz version: 4.9
I try this :
http://IPDOMOTICZ/type=command¶m=ud ... eout=false
http://IPDOMOTICZ/type=command¶m=sw ... eout=false
http://IPDOMOTICZ/type=command&¶m=s ... eout=false
Result Domoticz is offline message.
- waaren
look hereAscari wrote: ↑Thursday 20 September 2018 21:06 I try this :
for the right syntax.
http://IPDOMOTICZ:PORTDOMOTICZ/json.htm?type=command¶m=updateuservariable&vname=HaveTimeout&vtype=2&vvalue=false
vtype 2 is string ; domoticz does not support boolean type user-variables
- Ascari
@Waaren,
Thank for you help but it's not a uservariable.
I do a :
http://ip:port/json.htm?type=devices&rid=58
I want to update the parameter : HaveTimeout.
I try multiple combination and always error here one test I try:
http://ip:port/json.htm?type=command¶m=udevice&idx=$58&nvalue=HaveTimeout&dvalue=false
My device work good but blinking red beacause HaveTimeout is true and I want to correct this.
Thx
I do a :
"ActTime" : 1537523460,
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "18.7 C",
"Description" : "",
"Favorite" : 0,
[b] "HaveTimeout" : true,[/b]
"ID" : "1401",
"LastUpdate" : "2018-09-20 22:11:44",
"Name" : "Temperature Eau",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"idx" : "58"
"status" : "OK",
"title" : "Devices"
"status" : "ERR"
Thx
