Set TimeOut Variable
Ascari
Domoticz version: 4.9
Post by Ascari »
I want to set the variable (JSON) - "HaveTimeout" but I don't find the correct parameters for the URL.
I check the Wiki and try some parameter but not working, if you can help me please
Thx
jvdz
Domoticz version: 4.107
Re: Set TimeOut Variable
Post by jvdz »
What URL have you tried that isn't working?
What did it return when you tried?
Jos
Ascari
Post by Ascari »
look here
for the right syntax.
http://IPDOMOTICZ:PORTDOMOTICZ/json.htm?type=command&param=updateuservariable&vname=HaveTimeout&vtype=2&vvalue=false
vtype 2 is string ; domoticz does not support boolean type user-variables
Ascari
Post by Ascari »
@Waaren,
Thank for you help but it's not a uservariable.
I do a :
http://ip:port/json.htm?type=devices&rid=58
   "ActTime" : 1537523460,
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "18.7 C",
         "Description" : "",
         "Favorite" : 0,
[b]         "HaveTimeout" : true,[/b]
         "ID" : "1401",
         "LastUpdate" : "2018-09-20 22:11:44",
         "Name" : "Temperature Eau",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "idx" : "58"
   "status" : "OK",
   "title" : "Devices"
I want to update the parameter : HaveTimeout.
I try multiple combination and always error here one test I try:
http://ip:port/json.htm?type=command&param=udevice&idx=$58&nvalue=HaveTimeout&dvalue=false
   "status" : "ERR"
My device work good but blinking red beacause HaveTimeout is true and I want to correct this.
Thx
