Excellent news. Ali Express here I come
btw: Would that be on the latest beta or already available on latest stable.
Create a user variable XiaomiMessage Integer and set value 1DAVIZINHO wrote: Monday 10 September 2018 20:59 Hello
I received today one aqara vibration sensor and domoticz not recognized it as device.
In the log this is the message:
2018-09-10 20:54:21.617 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-10 20:54:21.625 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-10 20:54:22.683 Status: XiaomiGateway (ID=2): unhandled model: vibration
Hello,ak97 wrote: Tuesday 11 September 2018 6:45Create a user variable XiaomiMessage Integer and set value 1DAVIZINHO wrote: Monday 10 September 2018 20:59 Hello
restart domticz system and show log with this model
Now im not in home, and i dont move/touch the sensor, but maybe some vibration ocurs2018-09-11 11:19:39.043 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"48,69,1171\"}"}
2018-09-11 11:19:39.045 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 11:19:39.045 Status: {"cmd":"heartbeat","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"voltage\":3105}"}
Need more info ))DAVIZINHO wrote: Tuesday 11 September 2018 11:51 Hello,
this is the info:Now im not in home, and i dont move/touch the sensor, but maybe some vibration ocurs2018-09-11 11:19:39.043 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"48,69,1171\"}"}
2018-09-11 11:19:39.045 Status: {"cmd":"heartbeat","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"voltage\":3105}"}![]()
Jejeje.ak97 wrote: Tuesday 11 September 2018 14:07Need more info ))DAVIZINHO wrote: Tuesday 11 September 2018 11:51 Hello,
2018-09-11 18:12:27.577 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 18:12:27.577 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"vibrate\"}"}
2018-09-11 18:12:27.595 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 18:12:27.595 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"free_fall\"}"}
2018-09-11 18:12:42.655 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 18:12:42.655 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"-58,-48,1191\"}"}
2018-09-11 18:12:43.797 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 18:12:43.798 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"free_fall\"}"}
2018-09-11 18:13:28.947 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 18:13:28.948 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"vibrate\"}"}
2018-09-11 18:13:35.405 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 18:13:35.405 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"-17,47,1176\"}"}
2018-09-11 18:13:37.588 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 18:13:37.588 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"status\":\"free_fall\"}"}
2018-09-11 18:13:50.482 Status: XiaomiGateway (ID=2): unhandled model: vibration
2018-09-11 18:13:50.482 Status: {"cmd":"report","model":"vibration","sid":"158d0002a6e073","short_id":21715,"data":"{\"coordination\":\"-37,52,1174\"}"}
Hello again, in the last post i paste the information. do you need more information?ak97 wrote: Tuesday 11 September 2018 6:45Create a user variable XiaomiMessage Integer and set value 1DAVIZINHO wrote: Monday 10 September 2018 20:59 Hello
If this is just about seeing the switch update in the web UI then it is expected as the UI updates every 10 seconds. However, if you use the switch as a trigger for the event system, the reaction should be close to instant (tenth of a second max).jenssen wrote: Monday 17 September 2018 21:55 ...it will take up to 5 or 10 seconds, before the switch is turning to state "on" in Domoticz.
What you are reporting may be the refresh time of your dashboard.jenssen wrote: Monday 17 September 2018 21:55 Hello,
Just added a Xiaomi Gateway to Domoticz. It seems to work fine, however when I press a switch connected to the XIaomi Gateway, it will take up to 5 or 10 seconds, before the switch is turning to state "on" in Domoticz. When I add an action/scene in the Xiaomi App, the response is within 2 seconds. Is there such a delay between Domoticz and Xiaomi? If not then wireless can be a problem, but the Xiaomi Gateway is within a few meters of the access point. I tested the switch within 3 meter range of the Xiaomi Gateway.
Thanks.
no news. im waiting for this fuctionRecky wrote: Friday 21 September 2018 13:31 Also monitoring progress on the vibration sensor. I'm also getting the error :
XiaomiGateway (ID=7): unhandled model: vibration
Can anyone shed a light on if this is being worked on?
I have one mounted in my external mailbox next to the door, the goal is to get a pushbullet message when I have mail![]()
