domoticz in synology as package! Available now.
sakbal
Post by sakbal »
I just tried to do a manual install of 'domoticz_armada38x-6.2_4.0.9700-7.spk.tar' to my Synology DS216j but i get "invalid file format"
How do I resolve this?
I currently have 3.0.8153-7 installed
Sakbal
jumbotroll
Post by jumbotroll »
sakbal wrote: Friday 24 August 2018 7:46 Hi,
Sakbal
Remove .tar the file name should be only .spk domoticz_armada38x-6.2_4.0.9700-7.spk
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Venemans
Domoticz version: V3.7324
Post by Venemans »
@Jumbotroll
Is is possible to make a new version of Domoticz for Synology Dsm version 5.2?
In the latest version there is a problem with sunset and sunrise time. It is now stuck on a fixed time and doesn't follow sunset and sunrise.
Because of that my Milight lamps switch on to late.
I hope you can make a new version of Domoticz for my old Synology DS410.
I am now running version 3.8837.
Thanks in advance.
jumbotroll
Venemans wrote: Sunday 09 September 2018 20:41 @Jumbotroll
Thanks in advance.
Sorry DS410 use arch-ppc853x and have to old gcc from synology to compile newer versions of domoticz.
Jumbotroll
Venemans
Post by Venemans »
@Jumbotroll
But can you compile a newer version then I have of Domoticz
version V3. 0 for DS410?
I think the problem will be solved then.
I understand that compiling a version 4 for DS410 is impossible for you.
Thank you.
michass
Domoticz version: 4.10064
Post by michass »
Please help!
I have DS119J, unit is not available yet.
I can't install domoticz :(
Please prepare proper version for this model
2018-09-20 07_54_29-Domowy - Synology DiskStation.png (61.46 KiB) Viewed 3273 times
Synology NAS
Heating: eq-3 MAX!
Vent: by Sonoff POW R2 & Espeasy
Cam: Foscam C1
jimicek
Post by jimicek »
Hi Jumbotroll,
please what is the last available Domoticz version for Synology DSM-5.2? At www.jadahl.com I found for my DS213 the last stable version Domoticz v3.0.5877-7 and the last beta domoticz_88f6282-5.2_3.0.8922-7.spk.
Is possible to compile some new version for this NAS (either by you, or by me - can you share the experience?) - or are some problems (uncompatible system) ?
Anyway thank you so much for all your work for Syno Domoticz community.
Cheers, Jimicek
jumbotroll
jimicek wrote: Thursday 20 September 2018 10:28 Hi Jumbotroll,
Cheers, Jimicek
I have posted this answer in a lot of post here on the forum..
The toolchain and gcc from synology for arch-88f62xx is to old and is not compatible to build newer version of domoticz.
Jumbotroll
jumbotroll
michass wrote: Thursday 20 September 2018 7:58 Please help!
DS119j use arch-armada37xx and I will build a beta version for you to test.
You can download from my server :D
Here: http://www.jadahl.com/domoticz_beta_6.2/
Jumbotroll
michass
Post by michass »
jumbotroll wrote: Thursday 20 September 2018 10:40
Working:D
Can you prepare stable?
Synology NAS
Heating: eq-3 MAX!
Cam: Foscam C1
jumbotroll
michass wrote: Friday 21 September 2018 10:04
Working:D
I will build stable version for armada37xx when next stable version is ready.
Jumbotroll
michass
Post by michass »
Hi Jumbotroll,
I have 4.0.10007-7 package without Python and i have feeling, that i have conflict with surveillance, Drive, git and download station.
Maybe this is problem with compatibility syno packages with new hardware. I don't know, but i know, when syno packages are disabled Unit works fine and when syno packages run without domoticz also.
Best Regards
Michał
Synology NAS
Heating: eq-3 MAX!
Cam: Foscam C1
jumbotroll
michass wrote: Monday 24 September 2018 11:48 Hi Jumbotroll,
Best Regards
Michał
I use 4.0.10007-7 on DS-712+ with latest DSM version and have none of this problem..
Maybe you have some conflict with webserver port?
Did you change default ports? http-8084 and https-8443.
Jumbotroll
michass
Post by michass »
I have use default 8084 and 8443 ports without webserver
Synology NAS
Heating: eq-3 MAX!
Cam: Foscam C1
jumbotroll
michass wrote: Monday 24 September 2018 23:31 I have use default 8084 and 8443 ports without webserver
Take backup of domoticz.db and try to reinstall domoticz package, maybe something went wrong under update DSM or latest domoticz..
Jumbotroll
nono212
Domoticz version: 3.6179
Post by nono212 »
Hello JumboTroll
I have a small problem with the last image .
I am trying to work with EQ-3 max ( I follow this wiki https://www.domoticz.com/wiki/EQ3_MAX! )
So I was using it on my RPi It works fine but I prefer to work on Synology ( more reliable )
these are the requirements :
sudo apt-get install lua5.2
sudo apt-get install lua-socket
sudo apt-get install luarocks
sudo luarocks install luasec
sudo luarocks install luasocket
sudo luarocks install basexx
when I type lua with the name of the script in the wiki there is no lua program ...
Maybe I am doing it wrong ?
Can you please Help
jumbotroll
nono212 wrote: Wednesday 26 September 2018 19:06 Hello JumboTroll
Can you please Help
Sorry there is no lua spk (package) for synology yet...
You can't use apt-get install commands on synology.
Jumbotroll
michass
Post by michass »
jumbotroll wrote: Monday 24 September 2018 23:44 Take backup of domoticz.db and try to reinstall domoticz package, maybe something went wrong under update DSM or latest domoticz..
Still the same.
I think DS119J have better CPU, same RAM, but have limitations.
On DS115J everything works. maybe not fast but works. They want, to buy more expensive models.
Synology NAS
Heating: eq-3 MAX!
Cam: Foscam C1
nono212
Post by nono212 »
thanks to mzvut for MAX there is a new plugin (viewtopic.php?p=192832#p192832)
so I do not need anymore LUA
I still have a question :In domoticz there is log ... that is logrotated ...
I would like to send the log of domoticz to the syslog of the Synology So It will be kept more long ...
Can you help ?
Ashram56
Post by Ashram56 »
Good Morning,
Completely new to Domoticz (currently using Jeedom), I wanted to install it on my Synology NAS (a DS1618+), however it looks like your server (and as a result your repository) are down ?
Best regards
