Kodi Mediaserver Support
anno
Domoticz version: all
Re: Kodi Mediaserver Support
Post by anno »
00000000000000000000000000
long time domiticz user, running 8 domoticz installations on vm's nuc i3. And espeay hosting more than 30.
Estebus
Post by Estebus »
Dear all,
I need you help about an issue I have since a long time and I don't find solution on it.
I use last version of Domoticz (beta) on a respberryPI, my kodi is en last version 17.6 running on a windows 10 machine.
All remote control option are activated.
it seems my issue is more coming from Domoticz because all json message a properly received and domoticz failed to create the switch.
I never see the switch automatically created and I don't find how to solve it.
Thanks in avance for your help.
here my logs with this error :
2018-07-01 20:46:10.132 Kodi: Starting I/O service thread.
2018-07-01 20:46:10.132 Kodi: (KodiSalon) Handling message: '{"id":1007,"jsonrpc":"2.0","result":{"canhibernate":true,"canshutdown":true,"cansuspend":true}}'.
2018-07-01 20:46:10.132 Kodi: (KodiSalon) Sending data: '{"jsonrpc":"2.0","method":"Player.GetActivePlayers","id":1005}'
2018-07-01 20:46:10.133 Kodi: (KodiSalon) Handling message: '{"id":1005,"jsonrpc":"2.0","result":[{"playerid":1,"type":"video"}]}'.
2018-07-01 20:46:10.133 Kodi: (KodiSalon) Sending data: '{"jsonrpc":"2.0","method":"Player.GetItem","id":1003,"params":{"playerid":1,"properties":["artist","album","year","channel","showtitle","season","episode","title"]}}'
2018-07-01 20:46:10.179 Kodi: (KodiSalon) Handling message: '{"id":1003,"jsonrpc":"2.0","result":{"item":{"album":"","artist":[],"episode":-1,"id":136,"label":"Harry Potter et le Prisonnier d'Azkaban","season":-1,"showtitle":"","title":"Harry Potter et le Prisonnier d'Azkaban","type":"movie","year":2004}}}'.
2018-07-01 20:46:10.179 Kodi: (KodiSalon) Sending data: '{"jsonrpc":"2.0","method":"Player.GetProperties","id":1002,"params":{"playerid":1,"properties":["live","percentage","speed"]}}'
2018-07-01 20:46:10.181 Kodi: (KodiSalon) Event: 'Unknown'.
2018-07-01 20:46:10.181 Kodi: (KodiSalon) Handling message: '{"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":66.76619720458984375,"speed":1}}'.
2018-07-01 20:46:11.033 Kodi: (KodiSalon) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2018-07-01 20:46:11.034 Kodi: (KodiSalon) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2018-07-01 20:46:11.035 Kodi: (KodiSalon) Event: 'On'.
2018-07-01 20:46:11.035 Error: EventSystem: Could not determine switch type for event device KodiSalon
2018-07-01 20:46:41.036 Kodi: (KodiSalon) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
Each time I do "stop" or "pause" there is this error message.
DAVIZINHO
Post by DAVIZINHO »
since recent updates the log of kodi are more continuos with messajes like this:
 2018-08-06 19:04:41.624 Kodi: (Kodi_Salon) Handling message: '{"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":71.87725830078125,"speed":0}}'.
2018-08-06 19:05:11.625 Kodi: (Kodi_Salon) Handling message: '{"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":71.87725830078125,"speed":0}}'.
2018-08-06 19:05:41.628 Kodi: (Kodi_Salon) Handling message: '{"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":71.87725830078125,"speed":0}}'.
2018-08-06 19:06:11.633 Kodi: (Kodi_Salon) Handling message: '{"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":71.87725830078125,"speed":0}}'.
2018-08-06 19:06:41.633 Kodi: (Kodi_Salon) Handling message: '{"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":71.87725830078125,"speed":0}}'.
its posible to not show this log messages?
DAVIZINHO
Post by DAVIZINHO »
Hello again.
Its posible to reduce the log level os kodi?.
I can see a lot of log messages and flod all my log. :-P
jake
Post by jake »
Check your debug level in the Kodi hardware settings page in domoticz
DAVIZINHO
Post by DAVIZINHO »
jake wrote: Wednesday 22 August 2018 12:47 Check your debug level in the Kodi hardware settings page in domoticz
Its on "Error + forced messages". I not changed it the last months. maybe something change in the last betas with this plugin?
jake
Post by jake »
I put it on 'Python only' first, but don't like the update every minutes, so I put it on 'none' today.
I think that in the last versions the amount of logging is increased.
DAVIZINHO
Post by DAVIZINHO »
jake wrote: Wednesday 22 August 2018 22:31 I put it on 'Python only' first, but don't like the update every minutes, so I put it on 'none' today.
Sorry but i dont understand you
In my log options in domoticz i only have this options:
- Silent
- Error + forced messages
- Error + minimal execution info
- Error + minimal execution info + generic info
- Debun (everithing)
where you say the options "python only" or "none" ?
jake
Post by jake »
- Silent
I'm sorry for the confusion. Instead of using the built in version, I have the Python plugin version.
DAVIZINHO
Post by DAVIZINHO »
jake wrote: Wednesday 22 August 2018 22:41
- Silent
jejeje, dont worry!
edit: it will be solved in the next beta (24/08/2018)
The developers tell me in github!
:-D
Estebus
Post by Estebus »
Estebus wrote: Sunday 01 July 2018 20:52 Dear all,
I want to come back on my issue here, I found the reason why.
It was my mistake because I disabled this option in domoticz parameter "allow new hardware devices" (because too many devices was discovered through 433mhz)
Due to this option, when kodi was initialiy configured the switch was not created.
kevin91
Post by kevin91 »
I was also facing this issue with my Kodi, thanks for this post. I got the solution but however i am facing one more problem with Kodi. Whenever I am opening kodi addon and trying to watch movie then it is giving olpair Kodi error, how can I fix it
Carthman
Domoticz version: 4.9700
Post by Carthman »
This post helped me to make Kodi plugin working on my Domoticz, but I have a small problem.
When I put a movie on "Paused", when I resume it, the status of Kodi on Domoticz stayed at "Paused".
So I have a problem on the management of the lights !
Dnpwwo
Post by Dnpwwo »
@Carthman,
Can you post a log of you starting, pausing, resuming a movie a few times?
I don't have this problem (my lights go on and off correctly)
Carthman
Post by Carthman »
Hi !
Here is the log of the created Kodi switch !
In the switch, after I paused the movie, even if I resume it, but clicking on play button or with the space key, Kodi stay at "Paused" status.
I have to stop the movie, so Kodi come back to "On", and after I played again the movie and to have "Video" status !
If you need the core logs I could do it this evening !
Dnpwwo
Post by Dnpwwo »
Yes the log from the Log tab is the one I need. Also, can you turn on debugging for the plugin in the Hardware tab as well.
Carthman
Post by Carthman »
I didn't find where to turn on the debugging mode !
I have it on other hardwares, but no with the Kodi one !
Here is the log I've created.
I've launched a movie, paused it, resumed it, and paused it again :
2019-02-12 00:40:15.289 Kodi: (Kodi) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2019-02-12 00:40:15.290 Kodi: (Kodi) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2019-02-12 00:40:20.793 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Playlist.OnClear","params":{"data":{"playlistid":1},"sender":"xbmc"}}'.
2019-02-12 00:40:20.793 Kodi: (Kodi) Message warning, unhandled method: 'Playlist.OnClear'
2019-02-12 00:40:20.793 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Playlist.OnAdd","params":{"data":{"item":{"id":196,"type":"movie"},"playlistid":1,"position":0},"sender":"xbmc"}}'.
2019-02-12 00:40:20.794 Kodi: (Kodi) Message warning, unhandled method: 'Playlist.OnAdd'
2019-02-12 00:40:20.843 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnPlay","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:40:20.844 Kodi: (Kodi) Sending data: '{"jsonrpc":"2.0","method":"Player.GetItem","id":1003,"params":{"playerid":1,"properties":["artist","album","year","channel","showtitle","season","episode","title"]}}'
2019-02-12 00:40:20.877 Kodi: (Kodi) Handling message: '{"id":1003,"jsonrpc":"2.0","result":{"item":{"album":"","artist":[],"episode":-1,"id":196,"label":"X-Men : L'Affrontement final","season":-1,"showtitle":"","title":"X-Men : L'Affrontement final","type":"movie","year":2006}}}'.
2019-02-12 00:40:20.877 Kodi: (Kodi) Sending data: '{"jsonrpc":"2.0","method":"Player.GetProperties","id":1002,"params":{"playerid":1,"properties":["live","percentage","speed"]}}'
2019-02-12 00:40:20.879 Kodi: (Kodi) Event: 'Video - X-Men : L'Affrontement final (2006)'.
2019-02-12 00:40:20.885 Kodi: (Kodi) Handling message: '{"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":0.0,"speed":1}}'.
2019-02-12 00:40:20.891 EventSystem: Event triggered: Kodi_2
2019-02-12 00:40:20.898 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 7 (0x07)
2019-02-12 00:40:20.903 (ZWAVE) Usage (Unknown)
2019-02-12 00:40:20.905 (ZWAVE) General/kWh (kWh Meter)
2019-02-12 00:40:20.920 (ZWAVE) Light/Switch (Lumière HC)
2019-02-12 00:40:21.140 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnAVChange","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:40:21.140 Kodi: (Kodi) Message warning, unhandled method: 'Player.OnAVChange'
2019-02-12 00:40:21.237 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnAVChange","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:40:21.237 Kodi: (Kodi) Message warning, unhandled method: 'Player.OnAVChange'
2019-02-12 00:40:21.237 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnAVStart","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:40:21.238 Kodi: (Kodi) Message warning, unhandled method: 'Player.OnAVStart'
2019-02-12 00:40:21.254 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnAVChange","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:40:21.255 Kodi: (Kodi) Message warning, unhandled method: 'Player.OnAVChange'
2019-02-12 00:40:21.492 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnAVChange","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:40:21.492 Kodi: (Kodi) Message warning, unhandled method: 'Player.OnAVChange'
2019-02-12 00:40:21.496 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnAVChange","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:40:21.496 Kodi: (Kodi) Message warning, unhandled method: 'Player.OnAVChange'
2019-02-12 00:40:26.898 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnPause","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":0}},"sender":"xbmc"}}'.
2019-02-12 00:40:26.900 Kodi: (Kodi) Event: 'Paused - X-Men : L'Affrontement final (2006)'.
2019-02-12 00:40:26.913 EventSystem: Event triggered: Kodi_3
2019-02-12 00:40:26.933 OpenZWave: Domoticz has send a Switch command!, Level: 5, NodeID: 7 (0x07)
2019-02-12 00:40:26.946 (ZWAVE) Light/Switch (Lumière HC)
2019-02-12 00:40:30.554 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnResume","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:40:30.555 Kodi: (Kodi) Message warning, unhandled method: 'Player.OnResume'
2019-02-12 00:40:36.593 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnPause","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":0}},"sender":"xbmc"}}'
I've seen the event Video, the first "Pause", but not the resume and the second "paused" !
I tried again few minutes after, and there is no events, juste messages, and I think that Domoticz react to events from Kodi.
2019-02-12 00:51:30.313 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnPause","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":0}},"sender":"xbmc"}}'.
2019-02-12 00:51:34.200 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnResume","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}'.
2019-02-12 00:51:34.200 Kodi: (Kodi) Message warning, unhandled method: 'Player.OnResume'
2019-02-12 00:51:39.771 Kodi: (Kodi) Handling message: '{"jsonrpc":"2.0","method":"Player.OnPause","params":{"data":{"item":{"id":196,"type":"movie"},"player":{"playerid":1,"speed":0}},"sender":"xbmc"}}'.
Dnpwwo
Post by Dnpwwo »
@Carthman,
I think you are using the Domoticz native Kodi support rather than the Python plugin judging by your log. That said, both should support this functionality.
From your log the Kodi is sending an unhandled 'onResume' message which looks like new behavior because neither the native support or plugin handle it.
What version of Kodi are you running?
Edit:
Found this (https://forum.kodi.tv/showthread.php?tid=324598):
9.2.0
Breaking change (major verion left at 9 as during alpha)
Add player OnResume, OnAVChange and OnAVStart notifications. Be aware that OnPlay will only be called at start of playback now and not when resuming playback.
8th April 2018 13726 (PR)
so I will add a fix to make OnResume act like OnPlay which would be backwards compatible and should restore functionality. I can't test it though because I run an old Kodi version and don't want to upgrade. Will be in the next beta.
Let me know if it fixes the issue
Carthman
Post by Carthman »
Yes, I use the Domoticz native Kodi.
I'm running the last version of Kodi, Leia 18.
So I will have to install the next Beta of Domoticz ?
When it should be fixed ?
Dnpwwo
Post by Dnpwwo »
@Carthman,
Yes, you will need to switch to the Beta version. Change was pushed over 12 hours ago.
Once you start running the Beta version you will be able to tell if it contains the fix because the:
message will disappear from the log (and hopefully the Kodi device state in Domoticz will switch back to 'Video').
