when not sure where to post, post here and mods will move it to right forum .
Moderators: leecollings , remb0
Theedoek
Posts: 9 Joined: Wednesday 08 August 2018 22:09
Post
by Theedoek » Saturday 11 August 2018 14:32
That worked thanks. Finally solved it by checking the access rights. My monit control file now looks like this:
## Monit control file
SET DAEMON 300 # check services at 2-minute intervals
WITH START DELAY 240 # optional: delay the first check by 4-minutes (by default Monit check immediately after Monit start)
SET LOGFILE /var/ramdrive/monit.log
SET IDFILE /var/lib/monit/id
SET STATEFILE /var/lib/monit/state
SET EVENTQUEUE
BASEDIR /var/lib/monit/events
SLOTS 100
SET MAILSERVER
<mailserver address> port 465
USERNAME "<username>" PASSWORD "<password>"
SET HTTPD PORT 2812
ALLOW localhost
ALLOW 10.0.0.0/24 # allow local network
ALLOW admin:monit # require user 'admin' with password 'monit'
ALLOW @monit # allow users of group 'monit' to connect read/write
allow @users readonly # allow users of group 'users' to connect readonly
CHECK PROCESS Domoticz WITH PIDFILE /var/run/domoticz.pid
START PROGRAM = "/etc/init.d/domoticz.sh start"
STOP PROGRAM = "/etc/init.d/domoticz.sh stop"
IF FAILED
HOST 127.0.0.1 PORT 8080 PROTOCOL HTTP
AND REQUEST "/json.htm?type=command¶m=getversion"
AND CONTENT = '"status" : "OK"'
FOR 3 cycles
THEN RESTART
IF 5 RESTARTS WITHIN 5 CYCLES THEN EXEC "/sbin/reboot"
Next step is to figure out why monit reboots my Raspberry Pi every exact 3 hours :S
plenkske
Posts: 5 Joined: Saturday 01 February 2020 15:38
Post
by plenkske » Saturday 22 February 2020 16:55
I have followed the steps in the wiki
https://www.domoticz.com/wiki/Monitoring_domoticz
All seems to be fine up to the point of trying
sudo monit start all
Then I get the following message:
There is no service named "domoticz"
Someone knows why ?
I tried the different configs posted in this thread and checked the ip's and all.
And yes, domoticz is running.
EDIT:
I have got it working now.
I think I forgot to realod the monit service. Got it all working after stopping the service and starting it again. No more error messages when I use the reload command or start command.
And I can see the status in both putty and webservice.
Kruu
Posts: 49 Joined: Tuesday 17 January 2017 20:27
Post
by Kruu » Sunday 05 April 2020 13:50
Is it possible thar monit restarts my RPI3 (recently upgraded to Buster, and upgraded Domoticz)?
After all upgrades I get random reboots od RPI, middle of night, during day, every 2-3 days.
Before all updates RPI was allive 180 days.
thx
jake
Posts: 751 Joined: Saturday 30 May 2015 22:40
Post
by jake » Sunday 05 April 2020 20:51
Kruu wrote: Is it possible thar monit restarts my RPI3 (recently upgraded to Buster, and upgraded Domoticz)?
thx
Well, check your monit log it will tell you!
Kruu
Post
by Kruu » Sunday 05 April 2020 21:42
Yes, monit did it. Because domoticz was not running, but havent noticed that domoticz was not running in that period.
Is it possible that monit have some problems with new version of Domoticz?
[CEST Apr 5 12:11:01] error : 'domoticz' process is not running
[CEST Apr 5 12:11:01] info : 'domoticz' trying to restart
[CEST Apr 5 12:11:01] info : 'domoticz' start: '/etc/init.d/domoticz.sh start'
[CEST Apr 5 12:11:31] error : 'domoticz' failed to start (exit status 0) -- '/etc/init.d/domoticz.sh start': Starting domoticz.sh (via systemctl): domoticz.service.
[CEST Apr 5 12:16:31] error : 'domoticz' process is not running
[CEST Apr 5 12:16:31] info : 'domoticz' trying to restart
[CEST Apr 5 12:16:31] info : 'domoticz' start: '/etc/init.d/domoticz.sh start'
[CEST Apr 5 12:17:01] error : 'domoticz' failed to start (exit status 0) -- '/etc/init.d/domoticz.sh start': Starting domoticz.sh (via systemctl): domoticz.service.
[CEST Apr 5 12:22:02] error : 'domoticz' process is not running
[CEST Apr 5 12:22:02] info : 'domoticz' trying to restart
[CEST Apr 5 12:22:02] info : 'domoticz' start: '/etc/init.d/domoticz.sh start'
[CEST Apr 5 12:22:32] error : 'domoticz' failed to start (exit status 0) -- '/etc/init.d/domoticz.sh start': Starting domoticz.sh (via systemctl): domoticz.service.
[CEST Apr 5 12:27:32] error : 'domoticz' process is not running
[CEST Apr 5 12:27:32] info : 'domoticz' trying to restart
[CEST Apr 5 12:27:32] info : 'domoticz' start: '/etc/init.d/domoticz.sh start'
[CEST Apr 5 12:28:02] error : 'domoticz' failed to start (exit status 0) -- '/etc/init.d/domoticz.sh start': Starting domoticz.sh (via systemctl): domoticz.service.
[CEST Apr 5 12:33:02] error : 'domoticz' service restarted 5 times within 5 cycles(s) - exec
[CEST Apr 5 12:33:02] info : 'domoticz' exec: '/sbin/reboot'
[CEST Apr 5 12:33:02] error : 'domoticz' process is not running
[CEST Apr 5 12:33:02] info : 'domoticz' trying to restart
[CEST Apr 5 12:33:02] info : 'domoticz' start: '/etc/init.d/domoticz.sh start'
[CEST Apr 5 12:33:04] error : 'domoticz' failed to start (exit status -1) -- no output
[CEST Apr 5 12:33:05] info : Monit daemon with pid [479] stopped
[CEST Apr 5 12:33:05] info : 'raspberrypi' Monit 5.20.0 stopped
[CEST Apr 5 12:33:26] info : Starting Monit 5.20.0 daemon with http interface at [localhost]:2812
[CEST Apr 5 12:33:27] info : Monit start delay set to 300s
[CEST Apr 5 12:38:52] info : 'raspberrypi' Monit 5.20.0 started
[CEST Apr 5 13:05:44] error : HttpRequest: access denied -- client [127.0.0.1]: missing or invalid Authorization header
[CEST Apr 5 13:22:47] info : Monit daemon with pid [466] stopped
[CEST Apr 5 13:22:47] info : 'raspberrypi' Monit 5.20.0 stopped
[CEST Apr 5 13:22:58] info : Starting Monit 5.20.0 daemon with http interface at [localhost]:2812
[CEST Apr 5 13:22:58] info : Monit start delay set to 300s
[CEST Apr 5 13:27:56] info : Monit daemon with PID 477 awakened
[CEST Apr 5 13:27:58] info : 'raspberrypi' Monit 5.20.0 started
[CEST Apr 5 13:28:06] error : HttpRequest: access denied -- client [127.0.0.1]: missing or invalid Authorization header
[CEST Apr 5 13:28:52] info : Awakened by User defined signal 1
[CEST Apr 5 13:28:53] info : Monit daemon with pid [477] stopped
[CEST Apr 5 13:28:53] info : 'raspberrypi' Monit 5.20.0 stopped
[CEST Apr 5 13:30:45] info : Starting Monit 5.25.2 daemon with http interface at [localhost]:2812
[CEST Apr 5 13:30:45] info : Monit start delay set to 300s
[CEST Apr 5 13:31:12] info : Monit daemon with PID 2719 awakened
[CEST Apr 5 13:31:26] info : Monit daemon with PID 2719 awakened
[CEST Apr 5 13:31:28] info : Monit daemon with PID 2719 awakened
[CEST Apr 5 13:35:42] info : Monit daemon with PID 2719 awakened
[CEST Apr 5 13:35:45] info : 'raspberrypi' Monit 5.25.2 started
[CEST Apr 5 13:36:13] info : Awakened by User defined signal 1
[CEST Apr 5 13:36:14] info : Monit daemon with pid [2719] stopped
[CEST Apr 5 13:36:14] info : 'raspberrypi' Monit 5.25.2 stopped
[CEST Apr 5 13:36:25] info : Starting Monit 5.25.2 daemon with http interface at [localhost]:2812
[CEST Apr 5 13:36:26] info : Monit start delay set to 300s
[CEST Apr 5 13:40:24] info : Monit daemon with PID 480 awakened
[CEST Apr 5 13:41:26] info : 'raspberrypi' Monit 5.25.2 started
[CEST Apr 5 13:46:26] info : Awakened by User defined signal 1
goblin
Posts: 38 Joined: Sunday 23 July 2017 14:55
Domoticz version: 2023.1
Post
by goblin » Wednesday 05 April 2023 22:16
hello all,
one way or another but Domoticz main crashes after prox 10 hours since i have been struggling with master/slave RPI.
I cannot find the reason so installed Monit for help.
But the webpage shows domoticz not connected. I have checked the setting in security trusted network and 127.0.0.1 is present.
any idea
(2 x RPI and a boatload of ESPeasy)
